Had my car in for what I thought would be a wheel bearing swap today. But they checked and found no noise from the bearings, albeit without any load on them spun with the car on the lift. They did find some cupping to the front tires, but also did an alignment check and found everything within spec. So, any ideas where this rumbling sound is coming from? It is definitely rotational with the tire rotation frequency, not engine or driveline (it's there also when coasting w/clutch in or trans in neutral, with no brakes applied), but what else could it be? It sure sounded like bearings. Is it possible they only make noise when under load but not on the lift? My indy is super and basically talked me out of a bearing swap rather than take my money. He doesn't have suggestions other than possibly going to different tires in the future (presently using Goodyear F1 GSD3s). I have heard that the Goodyears can get noisy after a while. Also, I recently installed new rotors, but can't see how these could cause noise.
Need4Spd
I would guess it is tire noise, especially if it is a low rumbling sound at slow speeds.
__________________ Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
its either a bad tire or a sturt... if you have weak strut or a bad strut mount you will definatly get cupping of the tires... but from the sound of it, it's most likely a tire with a belt shift, both situations will cause cupping of the tires... get the tire and the struts checked out... im calling a tire with a belt shift!!... good luck!
Then something else is amiss. I would suspect worn shocks if all the bushings are good.
I am trying to think if it could be guibo, it is rotational. If you think tires (perhaps because of the cupping), swap left and right and remount inside out so they are facing the same way, but the cupped side ( I assume outside) is now on the inside. If the noise is different, then it is tires.
Good luck.
it is possible but not probable or not likely that the bearings only make noise under load.. if its on a lift and you spin a wheel or a hub of a bad bearing you will hear and feel the ruffness of a bad hub bearing...
and if you say ur indy is super... and he is as good as i am, lol, then hes more then likely right and u should trust him... i can't know 100% without seeing the car, but im tellin you what i know...
Thanks for the replies, guys. I'm thinking tires, too, but not struts. While it is possible a strut went bad, these are Koni FSDs with less than 15k miles on them. I have another pair of wheels/tires in the garage (my OEM rears which I used to run up front; yes, another story - gotta go find where I put those spacers and longer lug bolts now), so when I get time I'll mount 'em up again and see if the noise goes away.
BTW, interesting alignment readout (I asked them to check it out b/c of the cupping). Ride height is spec'd at 573mm rear, and the measured height was 583mm, 10mm taller than stock with FSDs and stock rear springs. Ride height front is spec'd at 600mm, and measured at 590mm with H&R springs and Dinan camber plates, so it sits 10mm lower in front for a +20mm rake front to rear (compared to stock). Yet, visually the front looks much lower than just 10mm lower than spec. Must be the rake. Front camber with Dinan plates and H&R springs comes out to -1.9 degrees. I wonder if the rake or neg. camber has anything to do with the cupping?
Need4Spd
