Old 28th February 2008, 21:12   #1
m5 deamon
m5 deamon's Avatar
Garage: 2001 e39 m5 carbon black on black sport interior
Send a message via AIM to m5 deamon
Question on accumulator oil valve for vanos?
Hello gentalmen,
I have used the search function and wound up empty handed on the info im looking for. I did a tsat on my beast yesterday and i noticed when i cracked the vanos line loose there was no oil a litte dribbled out. My initial thought was WTF. So upon that i searched tis and it stated the there is a accumulator valve that stores oil upon shut down and opens upon start up and purges the vanos units. ok i thought then it must be normal for no oil to be in the line cause its in the valve. so i calmed down alittle but wanted to ask some of you vet guys on the board that have done your tsats yourself is that normal or if you guys had pressureized oil in the vanos line? and the particulars are my car is a 2001 m5 with 90455 miles I have no codes for vanos and on cold start up or after an oil change i do Not Have a vanos rattle. i am just curious if that is normal or if i should take pre emtive strike and change a 300 dollar valve and looking for your imput.
kind reguards
G
2001 m5 Carbon Black, Black sport interior, m audio
AA cai with bmc air filters
AA software going to change to either ess or pc
UUC Light Weight FlyWheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmisson mounts
Steelbraded clutchline
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braded brake lines
Dinan rear sway bar
Dinan stress bars front and rear
Tc swaybar brackets
PS2 tires
Axiss ult pads front and rear
Dinan JRZ suspention kit
Euro head lights
Predator ice v2.1 angel eyes
Bimmian black kidney grills
DDM xenon fog lamps
Solaris amber bulbs
led lic plate lights
v1 hardwire
m45 blinders updated version
To Come... dinan headers, stoptec bbk
m5 deamon is offline
Old 28th February 2008, 21:17   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i was under the impression that the accumulator stores oil under pressure for the initial cold start to reduce vanos noise. I would have thought you'd have oil under pressure if you open a line.
My 99k mile 00 had this accumulator done under warranty (it was not installed at the factory until 9/00 production, iirc), but over the past year, i've gotten more cold start rattle, so i too wonder if this could fail. It doesn't hurt anything, so there's no reason to replace it other than the noise.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 28th February 2008, 21:29   #3
m5 deamon
m5 deamon's Avatar
moatti did you just do your tsat recently was there oil in the line
Old 28th February 2008, 22:05   #4
mottati
mottati's Avatar
i didn't do it myself.
mottati is offline
Old 29th February 2008, 00:09   #5
gmakishima
Garage: 2002 M5 (E39) Sterling Gray
i read someplace that the vanos stores oil under extreme pressure... 200psi or so! if that's true, wouldn't it be extremely dangerous to disconnect any of those pressurized lines without first bleeding the pressure off? i heard bmw techs use the gt1 computer to open release the vanos pressure. does anyone know if this is true?
gmakishima is offline
Old 29th February 2008, 00:17   #6
m5 deamon
m5 deamon's Avatar
thats only if the car is running the pressure is that high. they use the gt1 to put the vanos into assembly mode and to operate the selinoids so they can bleed out the air in the system upon reassembly
Old 29th February 2008, 17:15   #7
m5 deamon
m5 deamon's Avatar
bump
Old 1st March 2008, 23:50   #8
m5 deamon
m5 deamon's Avatar
anyone ???? still havent found my answer
Page generated in 0.12660 seconds with 10 queries
