Knowing the spring rates isn't all you need...you must also know the leverage ratio of both cars, front and rear, in order to determine the spring rate at the wheel. Then you can make some valid comparisons.
__________________ Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
The Following User Says Thank You to CSBM5 For This Useful Post:
The golden setup for mixed street and track from Ground Control is 430 front and 380 rear (linear springs). Many coil-over kits are progressive springs so it's hard to know what they are. Do a search - it's well documented on this board.
The Following User Says Thank You to jaj For This Useful Post:
What keywords, was having a bit of an overwhelming response with most of them.
Behind the Matte Black Kidneys: Active Autowerke Cold Air Intake, Super Sprint Exhaust & X-Pipe from ModBargins, Dinan SSK, Dinan Software, Dinan Lightweight Flywheel.
Modifying and Improving Creature Comforts & Driver Aides: Valentine 1 with Jaric Designs Stealth One, Defi VSD X Heads Up Display, Z8 Engine Start Button, TEC Cup holder, Polk Audio Tweeters, MB Quart Mids, Twin JL Audio 10w3v2's with center port through skipass, Alpine PDX4.100 and PDX 1.600. DVD player with Video Module, Rear Backup Camera and dual 7" head rest monitors along with Intravee for iPod via 2point5 specdoc. Stoptech Big Brake Kit, centric Posi-Quiet Semi-Metallic Brake Pads from Zeckhausen Racing and TC Design Rear Sway Bar Brackets.
Working towards Pure Aesthetics: Hella Euro Clear Headlights with Upgraded 6000K D2S HID Low Beams protected with Lamin-X Headlight & Foglight Protective Film ALL from üm•nitza, Predator ICE Angel Eyes w/K2 LED Mods, 3000K Yellow HID Fog Light kit rolling on Ground Control Coil Overs on a set of Cargraphic 19x9 & 19x10 3 piece forged wheels wrapped in 255.35.19 & 285.30.19 Michelin PS2.
When you turn your car on, does it return the favor? -
The Following User Says Thank You to BMWMPWR For This Useful Post:
