13th December 2009, 12:01
#262
2001 Carbon Black M5
Originally Posted by Infamous Q
It is the Shift linkage I can not remove the two and I don't want to damage the shifter...
In the picture above, you see the "circlip" which is the U-shaped silver part. That part keeps the shifter attached to the shift linkage through the hole at the bottom of the shifter. Make sure it is removed by prying it off with a flat-head screwdriver (from under the car), pulling the shift linkage sideways a bit to dislodge it from the hole at the bottom of the shifter, then pull the shifter out (from inside the car). Does that make sense?
If you have done that and the shifter does not pull out from inside the car, make sure you turned the white bushing (from inside the car) with a set of needle-tip pliers.
Again, here is the installation link for reference. http://bmwtips.com/tipsntricks/tips_...er_install.htm
2001 Carbon Black ///M5
Supersprint 4-1 Headers
Magnaflow 10416 Resonators
Timmay77 Signature Muffler Delete
Custom Software Tune
Bilstein PSS9 Coilovers
Ground Control Camber Plates
BBS CH in Custom Satin Black
Hankook Ventus V12 255/35/19, 275/30/19
Wheel Stud-Conversion Kit F/R
15mm Front + 5mm Rear Spacers
E60 545i SSK + UUC DSSR + ZHP Knob
SLIMM C63 AMG Style Diffuser V1
SLIMM Front Splitters
SLIMM 3.5" Fog Light Air Ducts
SLIMM OEM Euro Armrest
