Anti-Theft Alarm goes on when I lock the doors and leave it for few minutes!
Yesterday I was driving to work. I parked my car and locked the doors using the remote, walking away from the car to my office and suddenly I hear the car anti theft alarm goes on with the hazard signal. I come back and unlock the door and everything is fine. Again walk away and the same problem occurs and the alarm is triggered. It did it 4 times and I was late for work. I left it finally hope that it will stop. Eventually it did stop.
Then I left work going to home and it happened again then stopped. That was the last time it happened (Yesterday). I will have it checked by the dealer, just curious what can cause such thing?
Thank you guys for your continues support. I parked my car that day on incline. And had the sun shield in front glass + the battery is weak as from my last service the dealer noticed that when he started up the car. I will have to check which one did cause the problem.
Thanks again guys
Having the same issue as the OP since yesterday and I am following the advice in this post. Will keep you updated if something different turns out to be the cause.
As stated above, the hood sensor is a major culprit for this, mostly if you live in a hotter climate. My alarm was going off randomly during the daytime only as the temps started heating back up here in South Florida...sure enough, yanked that hood sensor out and all is quiet. The system thinks the hood is permanently closed so your alarm is satisfied.
Got a new sensor on order, it's about $15:
BMW #61314158205
good luck!
SP
Sean Paul
2003 M5 LeMans Blue/2-tone blue & black
Interesting in that we have just had two 92F humid steamy days. I did jiggle the hood sensor and also dusted around the motion sensor and it has not gone off since.
