Old 1st December 2001, 00:21   #1
Steve Beswick
Steve Beswick's Avatar
Garage: 2001 M5 Titanium Silver w/Black Interior
Tire Pressure Indicator
So . . .having just gone to aftermarket rims and tires, I assume my tire pressure indicator will not function.
Are there sending units inside the stock wheel/tire combination that should be removed and re-installed inside the new aftermarket wheels and tires?
I know many of you have replaced your stock wheels and tires. What have you done to enable the stock tire pressure indicator on the dash to work?
SteveB
Titanium Silver Ext/Black Luxury Int
Cross-Drilled Rotors Front & Rear
Red Brembo's w/Hawk Street-Track Pads
Stainless Steel lines
ACS Pedals/ACS Short-Shift
SS X-Pipes with ACS Exhaust
SSRGT3 19"9 1/2"w/275-30F&285/30RS-03's
Blacked Kidney Grille
Silvervision Front & Side Turn Signals
M-Technic Grille w/Brake Ducts
K & N Filters
Valentine V1
RMS ECU Software
Steve Beswick is offline
Old 1st December 2001, 00:40   #2
tfung
tfung's Avatar
this has been discussed quite a lot on the board already... The way the tire pressure monitor works is it senses the rotational speed on each tire.. when one tire differs from the others, it will send the warning.. so putting on aftermarket wheels shouldn't be a problem.. you just have to make sure you reset the tire pressure monitor and calibrate it again, as per instructions in the manual...
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
tfung is offline
Old 1st December 2001, 06:42   #3
stever
this raises a really good point though, and if i'd thought about it in time, i would have really looked at the aftermarket pressure sensor that really measures tire presssure when i put on the new wheels -- much more accurate than the OEM estimate or rolling radius -- and tells you the accurate pressure for each tire, can't remember who makes it
anybody with experience?
stever is offline
Bridgestone S03's and track tire pressure rprellwitz E39 M5 and E52 Z8 Discussion 20 20th June 2003 09:28
droppping tire pressure M'nd E39 M5 and E52 Z8 Discussion 4 31st October 2002 18:06
What is the correct tire pressure? Cerberus E39 M5 and E52 Z8 Discussion 19 17th April 2002 05:32
New owners: You MUST calibrate the tire pressure monitor greg E39 M5 and E52 Z8 Discussion 2 25th October 2001 02:46
Did you check your tire pressure today? SteveP E39 M5 and E52 Z8 Discussion 6 7th November 2000 20:28
Page generated in 0.08883 seconds with 11 queries
