Old 14th February 2008, 07:43   #1
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
Bad Fuel / Filter
So my engine wasn't too happy today. It wouldn't rev up over 4k, 6th gear at 40 mph caused major vibrations--all around not happy. This happened when I filled up.
SES light came on--all sorts of misfires (startup and fuel cut off) in cylinders 1, 3, 4, and 6.
Put in "Lucas" fuel treatment and after 30 miles, drives fine. Expect SES light to go out soon.
I guess I'll do a precautionary fuel filter change. Because of multiple cylinder misfires, I assumed it was fuel.
everycredit is offline
Old 14th February 2008, 07:55   #2
Kmac
Kmac's Avatar
Garage: Alpine White E39 M5; Carbon Black E46 M3
You will most likely have to clear some fault codes also. Had this happen to me previously, it was BP fuel and the alcohol content was around 17%, the max the engine can take is ten. BMW recommeded to me to use Shell or Sunoco.
-Kmac
E39 M5 MY'00 (FOR SALE)
Rogue Engineering SS Kit/Rogue Clutch Stop/M Aluminium Pedals/Hardwired V1/TEC Cupholder/Titan Trim & door handles/Bimmian Knob & E-brake/Euro Arm Rest/Alutec Strut Bar/M3 Steering Wheel/35% tint/Centric Rotors/Axxis ULT's/SS Brake lines/16:9/MKIV/IntraveeII/Tubi Exhaust/AA Cai/Conforti Shark Injector/TC Design Brackets/Dinan Stage 1 Suspension/Bavarian Auto Poly Trailing Arm Bushings
E46 M3 MY'01/100k miles
TCKline Double Adjustable Coilovers/TCKline Adj Camber Plates/Delrin bushings/TCKline Racing wheels (18x10 - 19lbs)/Bridgestone RE01A 265/35r18's/Wheel Studs/Goodrich SS Lines/UUC SS Kit/ZHP Knob/Hardwired V1/XM Radio/CF Hood/CF Fenders/Dust cover delete\Dinan Front strut brace/GC Sway Bars/Superprint Stepped Headers/Rougue Midpipe w/dump valve/Random Cats/Supersprint Race pipe/Rogue Diablo Exhaust/Rugue Pullies/CSL CF Airbox/Alpha N software/StopTech BBK
E90 M3 MY '08
Bone stock
"For Sale: 20th Century French Rifle - never fired, dropped twice."
Kmac is offline
Old 14th February 2008, 17:39   #3
everycredit
The problem came back after the car warmed up and then went away after driving about 20 miles.
I should drain the fuel and use it in my lawn mower. Can't imagine unspent fuel being good for the cats.
Old 16th February 2008, 10:05   #4
dhl93449
Garage: 2002 M5 oxford green/caramel
Wouldn't do that. My Honda mower is more sensitive to gas octane and fuel "freshness" than my cars. Same with my Stihl saws and trimmers.
dhl93449 is offline
Old 16th February 2008, 17:33   #5
Kmac
Kmac's Avatar
Feed it to the neighbors cats. Or, put it in your neighbors lawnmower, or GM product. Should would well for all three applications.
E90 M3 MY '08
Bone stock
Kmac is offline
Page generated in 0.11459 seconds with 10 queries
