Old 10th February 2008, 19:19   #1
Mike S.
Mike S.'s Avatar
Garage: "Bugslayer" 2003 M5 Titanium Silver
Send a message via AIM to Mike S. Send a message via MSN to Mike S. Send a message via Yahoo to Mike S.
First DIY Oil Change Experience
Hello all - A little background first. I've owned my '03 for nearly a year now, and when I bought it, it had 23K miles on it. At that time, it was getting close to Inspection I, and when that happened (at 29K miles) I took it to the dealer. The main reason I took it in was to make sure it had everything up to date (like the DME recall, which it did not) and to have them give it a once-over. The dealer did the Inspection I, and I felt as though I was slightly overcharged, so I decided that from that point on, I would do my own maintenance. I have done my own maintenance on all my previous cars, so I wasn't worried about this.
After reading many posts on the subject of oil, frequency of changes, and the like, I decided that I would change every 5K miles and switch to Mobil 1 0W-40. 34K came pretty quick, so I planned on doing the oil change yesterday (Saturday).
In preparation, I ran over to the dealer, which is about an hour round-trip for me, and picked up an oil filter kit. Then on Saturday morning, I went in search of Mobil 1 0W-40. I found it at Autozone for about $6.50/qt. I tried Wal-Mart, but they did not carry that weight.
So into the garage, and up in the air. I still don't have any ramps that will work (in plan) so I went through my ritual of getting her up on two jack stands, and set about the job.
Based on what I read in the TIS, the oil service / inspection sheets, and on this board, I started by removing the oil filter housing cap. Man, was that thing tight! It took quite a bit of effort to break it loose. In fact, I noticed that one of the rubber mounting grommets was broken, causing my oil filter housing to be slightly wobbly. I will replace that part shortly.
I then removed the oil fill cap, and proceded under the car to drain the crankcase. I love the trap-door concept. The oil drain plug was also extremely tight, but I was successful in breaking it loose without rounding it off (thank you six-point socket) and drained the oil. My favorite part of the oil change was the realization that replacing the drain plug after drainage was the end of my under-car experience. In other words, I was happy that the filter was handled from up above. Never had that on a car before.
Now came the first glitch. And it was totally my fault. I was replacing the drain plug, and it slipped out of my hand and into my drain pan. Not a big deal, you say, but I use drain pans that are enclosed, with just a hole in the center for the oil to enter. Well, drain plugs can also enter in there! Yikes. So I spent several minutes pouring the oil from the drain pan into some gallon jugs I had in the garage in order to rescue the wayward plug. That accomplished, I successfully replaced the drain plug (with new metal washer) and closed up the trap door.
Now for the second glitch. The parts guy sold me the wrong oil filter kit. I took the filter out of the box, and the proceeded to take the old filter out of the cap, and noticed that they were very different sizes. Dammit. Double dammit. So, pack up the old one, take the incorrect one, and off to the dealer before they close. That's the last time I do that. Pelicanparts, here I come. Anyway, got the correct filter and back to the garage. Hey, it fits! Novel approach.
So, after she's all buttoned up, proceed to fill with the Mobil 1, fire it up, and check the level. 7 quarts put it about 1/2 way up the dipstick, but that could be because I didn't really warm it up and let it idle for a minute before checking. I will recheck when I gas up today or tomorrow.
Overall, I was very happy with how easy it was, and I wanted to say thanks for all the great advice from this board on oil choices and change intervals. There are many to choose from, and everyone is free to pick what works for them, but I believe for me, I made a good choice.
For those who actually read this whole post, have a cold one on me.
Mike S.
"Bugslayer" 2003 M5 - Engine: Magnaflow 14816, Driveline: E60 545i Short Shifter Suspension: TCDesign Rear anti-roll bar brackets Exterior: Stealth Auto Black Kidneys, 30% Ceramic Tint Interior: Hardwired V1, Ultimate Cupholders, OEM AUX Audio Input, Diny custom radio knobs.
Mike S. is offline
The Following User Says Thank You to Mike S. For This Useful Post:
Respect the M (19th February 2008)
Old 10th February 2008, 20:16   #2
Racerxjling
Racerxjling's Avatar
Garage: 03 M5 Silver/black/blue
Sales Feedback: (16)
Hi Mike
I also do the maintenance on my car. Oil change is very easy on this car. Consider getting a new drain plug esp. if the previous wrench monkey somewhat rounded the corners. It's cheap insurance. Also, don't be hesitant to do the fuel filter, spark plugs, cabin filters, and air filters on your own. Check $$ with Evan at Tischer BMW (www.getbmwparts.com or mileoneparts.com). They have good $$, fair/free ground (if substantial order) shipping, and great communication).
Jeff
Racerxjling is offline
The Following User Says Thank You to Racerxjling For This Useful Post:
Mike S. (10th February 2008)
Old 11th February 2008, 00:09   #3
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Hi Mike,
Congrats on your first change
Now probably isn't the best time for me to tell you that Autozone also carries the oil filter, huh?
Next time, skip the dealer (especially at that distance!) and stay local!
d-
DouglasABaker is offline
Old 11th February 2008, 00:24   #4
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
d-
Do you know what brand of oil filter does AZ carries for the beast?
Thanks,
Jim
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
Old 11th February 2008, 01:48   #5
DouglasABaker
STP, Fram, Beck, and K&N. I specifically recall they don't have Mobil1 filters...
d-
Old 11th February 2008, 02:31   #6
Mike S.
Mike S.'s Avatar
Hey Doug - thanks for the heads-up. No, I didn't realize that AZ also carried the filter. Does what they carry include the new washer and O-ring? Never mind. I checked the link, and it looks like the K&N and the Beck Arnley both do.
Jeff
- thanks for the links. The drain plug was fine. This car has only had, by my count, four oil changes in its life. I've had the car for about 12K miles and changed the oil twice, and before that it had it's 1200 mile service and one Oil Service. I'm also not worried at all about performing the other maintenance bits. I've already done the O2 sensors. Yes, I know it was early, but one was throwing a code, so I changed both.
All in all, it's not too bad a car to wrench on. Not as open an engine bay as my 70 Mustang, but no worse than my 2000 Suburban, either.
Mike S.
Last edited by Mike S.; 11th February 2008 at 02:35. Reason: Checked Autozone link
Mike S. is offline
Old 11th February 2008, 02:48   #7
chowdah
Garage: sweetness
Sales Feedback: (3)
Your first paragraph reads like a mirror of myself, except I got Insp 1 in before the factory coverage expired.
Optional questions:
1. did you bother to torque wrench anything, or just hand tight?
2. did you consider a mityvac top-side siphon instead of draining properly?
3. did you drain with her front two wheels in the air?
4. how much did your dealer charge for the filter kit?
Thanks.
chowdah is offline
Old 11th February 2008, 03:11   #8
DouglasABaker
Mike - they all do. I've never used the K&N or the Beck, and the ones I've gotten have the O-Ring and the crush washer...
d-
The Following User Says Thank You to DouglasABaker For This Useful Post:
Mike S. (11th February 2008)
Old 11th February 2008, 06:05   #9
ssittig
Garage: 2002 Carbon Black
Sales Feedback: (4)
Send a message via AIM to ssittig
I had a similar experience loosing the drain plug on an oil change. Knowing that I'll do it again sometime in the future, I went to Sears and got a telescoping magnetic retriever, so I can just dip it into the drain pan and retrieve the plug. Comes in handy for nuts/bolts that I drop in the engine bay and now I don't have to try to get that stuff back with needle nose pliers.
ssittig is offline
The Following 2 Users Say Thank You to ssittig For This Useful Post:
Mike S. (11th February 2008), morals (11th February 2008)
Old 11th February 2008, 08:45   #10
bng4god
bng4god's Avatar
Garage: M5
I changed my oil this weekend and found out my oil drain plug hole is stripped....ARGH!!!! Previous owner took it to the dealer but the last oil change, the drain plug bolt was on way too tight. When I finally wrenched it loose, the threads in the oil drain hole were stripped.
So I am going to have to add a threaded insert - most likely a helicoil. And, yes, I was searching on this forum all weekend for the best solution...
01 Black on Black M5: Custom Exhaust with Straight Pipe & Magnaflow 14816 Mufflers, Angel iBright v3.0, 19x9.5/15mm All Four Beyern Mesh Custom Painted Silver Gray Metallic w/ Hankook Ventus V12 Evo K110 Tires 275/30/19's, Dinan Springs, Koni Yellows, Dinan Rear Sway, Hamann Replica Front Lip custom painted
bng4god is offline
Page generated in 0.16361 seconds with 10 queries
