Old 30th March 2008, 15:08   #51
nerio02
nerio02's Avatar
Garage: m5 e39 ROYAL RED
damn that sucks mate...mine is still ok,(well it was ok ,until a friend tryed to flasch my dme for latest update,before i took it to my other friend for chipping. its dead now. ecu/dme killed )
maybe try to get it on a dyno mate ,and see what the running curves are like.whp/torque/Air to Fuel Ratio.
maybe you have; a injector broken ,fuel issues, or a vacuumproblem and the engine makes to mutch pressure or something ,i'm just random guessing here,your problem is so strange . after all those replacement parts and tons off $$, its still not good.
so, still no codes that comes up ??
i have no clue anymore, what could be the problem.
i hope that you will find it soon.
i wisch you the best of luck mate in this search...
with kind regardes
nerio02/dominique
nerio02 is offline
Old 30th March 2008, 15:27   #52
jcdavis
Garage: '00 M5, '98 540i-6, '04 K1200RS,
No codes at all. I know the MAFS have to be pretty bad before throwing a code. I did the on board MAFS test and it came up 109 for three pulls in third gear. As I understand it, I should be around 130-140. I have also noticed a healthy oil consumption. I have had my car to 2 different dealers and they said the same thing. "That is just how that engine runs". I can hear the change in my ash tray shaking. That isn't normal. Both dealers also said that the VANOS is just fine. I am at a loss.
jcdavis is offline
Old 30th March 2008, 15:34   #53
AfricaOffroad
AfricaOffroad's Avatar
Garage: 1991 E34 M5
Am I missing the obvious?
Your are only flowing 109L/H at WOT.
Thats waaaaay too low.
Why aren't you changing them.
So say when you unplug the one MAF it makes no difference, that also dont sound right, clearly this MAF is not reading properly - maybe the ECU is just ignoring it???
AfricaOffroad is offline
Old 30th March 2008, 15:50   #54
nerio02
nerio02's Avatar
yep 109 l is way to low my friend...
2 gear is about 135-140 L, i thought that 3 gear must be in the 125L regions.
try to clean them up and see what happens. (temporary fix)
but then you know a bit more.
on those numbers i also would say, mafs.
with kind regardes
nerio02/dominique
nerio02 is offline
Old 30th March 2008, 15:53   #55
jcdavis
Like I have said, I have had my car at two different BMW dealers. Both of them said my car was "OK". I have replaced the MAFS with new ones and even switched sides with them. Yesterday I pulled off the plenum and followed the MAFS wiring as far back as I could to see if I could find an obvious problem. I cleaned out the plenum pretty good, but no change in the cars performance.
jcdavis is offline
Old 30th March 2008, 16:09   #56
nerio02
nerio02's Avatar
someone who isn't used to drive our cars will allways say its ok, even iff we run 50 hp down.
but the 109L is to low.why?? i dont know. iff the mafs where getting bad you could have misfire codes, engine fail safe mode,pinging. you dont have those you said + they are new, so thats not it.
(iff one of the 2 is broken and you switch them , then 1 is still broken ) right..
dont you know anybody in your neighborhood that can help you out and switch his as a experiment?
can you get a voltmeter on those mafs jc?? mafs schould have a 5Volt current.
when my mafs where shot , i dident have codes,or misfires and engine fail safe mode either, and they found out after 14 days that the mafs only gave a 3,5Volt current .
109L is not good , now we got a location to search on
maybe check that out. doesnt cost you a cent.
with kind regardes
nerio02/dominique
nerio02 is offline
The Following User Says Thank You to nerio02 For This Useful Post:
jcdavis (30th March 2008)
Old 30th March 2008, 16:33   #57
Kelleyo
Kelleyo's Avatar
Garage: 2002 M5 Sterling Grey
At the rate you are going you will have a new car (in terms of replacing every part)
Just teasing though. Good luck...
2002 ///M5 Sterling Grey - Caramel Full Leather
K40 Stealth with front/rear difusers
Angel iBright 3.0 and Xenix fogs
MKIV Nav Computer Upgrade
E60 545is Short Throw Shifter with ZHP Knob
LeatherZ Shift and Ebrake boots with M stitching
SuperSprint Xpipe
Magnaflow 14816's
Kelleyo is offline
Old 30th March 2008, 16:58   #58
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
I put on the new oil separators and it helped for about 20 min or so. I did notice that when I unplug the left bank MAFS the car stumbles and almost dies, but when I unplug the right bank MAFS nothing happens. I tried the same trick on my 1998 540i and the car didn't stumble. I think I am back at square one. I can't believe I am the only one that has ever experienced this.
I seem to remember one side has a different or additional function. Someone will chime in I am sure.
In the meantime, simpy swap the sensors. If the problem switches sides, then it is a MAF issue.
gsfent is offline
Old 30th March 2008, 18:51   #59
jcdavis
I have switched sides with both sensors and then replaced them both. I don't know if the car is getting the signal from the right side sensor or what. If there was an air leak, would it be before the sensor or after?
jcdavis is offline
Old 30th March 2008, 20:39   #60
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
One of the MAF banks has the air temp sensor in it, so that may be why it's stumbling. The car will run with the MAFs unplugged
John Baas
2001 Anthracite Metallic M5
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Page generated in 0.14241 seconds with 10 queries
