i have a question for unlocking the cluster.now dont say DO A SEARCH , i did, but i have a problem that i cant find nowhere by searchfeature.
little story..
2 days ago i went to a friend to do a dyno test on his new bench, and the result was 367 hp and 480nm/torck. he says that this numbers are converted already to motor hp, no whp.so im missing 33 pony's and 20 nm/torck on the motor.
the curve on the dyno is nice, no peaks,no hesitations,etc, straith to the top ..but where are my 33 pony's.??
so i did a read out on my gt1, no codes..nothing,i thought on a bad/dieing cps or something.Mafs where replaced last year and have now max 10 000miles on them so in theorie, they must be ok. but i want to check them thru the cluster to be sure.
now... i did my bit off searching and found the cluster/maf tread.did all the instructions and i can open/unlock the cluster thru number 19 etc....but then when i go to test number 4 (i think thats the one i need for checking the incoming air/fuel ratio) and i press the left button ,it wont open it just asks lock/on and iff i press further lock01,lock02,lock03...and further(number is code corresponding with my cluster.when i come to my numbercode and i let the left button loose it stays displayed on lock XX(xx is my codenumber, to be clear) .
NOW my question.
what must i do then??? or what am i doing wrong?? because i dont know it anymore. can anybody chime in from here please, and help me out further.my car goes in tommorow for chipping and i want it to go in healthy.
SO iff any body have an idea about the cluster or a remark about the dyno ...go for it
thank you very mutch in advance.sorry for the long story.
add up the last 5 digits of the vin, thats the code
hi E55AMG2
yes i know the VIN part(code) that is no problem.my code is 16.i go to test 19 and followed the instructions in the tutorial from david ,afterwarts i can open it no problem. for instance test2(cluster lights and max speed/rev thing works after unlocking) but iff i then go to test4 the cluster asks lock/on. i press further left, then it says lockXX and i press up until lock 16 comes up.then its stays on lock16 and nothing else happens. when i press left again i go to lock 17 and further ,so thats not good, and iff i press right , i end the session on the cluster.
so in between the two things i'm missing something
do you have to do the unlock thing for every testnumber or just 1 time unlocking by test19 and the whole cluster is unlocked??
test number4 is the one i need right??maybe im just doing one testnumber that means nothing
with kind regardes
nerio02/dominique
The button to the lower left of the speedometer is the Reset button for the trip odometer, the button to the lower right of the tachometer is the Check control key.
To unlock these tests, go to Test 19, add up the last five digits in your VIN number, producing a number from 0 to 45. With "LOCK: ON" displayed, hit the Reset button again. The display will change to "LOCK: 00". If the VIN sum was 0, press Check. Otherwise, press Reset until your VIN sum is displayed, then press Check. Press Check again until you get back to test 03. You'll know you got it right when you press Reset at this test and get the following displays (or something like them):
E39 Instrument cluster test functions
Test functions
Menu
Sub menu
Sample
Meaning
Test 1: Vehicle specific data
1.0
12345
VIN
1.1
4812
Body number
6_1.2
834762
Part number of cluster
1.3
010203
Coding/Diagnosis/Bus index
1.4
3495
Manufacturing data (calender week/year
1.5
04_600
Hardware/software number of cluster
3_1.6
415_06
Injection status, number of cylinders, engine factor
Test 2: Cluster system test
Activates test for gauge drivers, indicators and LEDs
Indicated value and tank phase.
1 = Both sensors OK. 2 = One sensor fault.3 = implausible input
Test 7: Temperature and speed
7.0
032
Coolant temperature input 32C (90F)
7.1
245
Outside temperature input 24.5C (76F)
7.2
5283
Engine speed 5,283 RPM
7.3
085
Vehicle speed 58 km/h (36 mph)
Test 8: Input values in HEX code
8.0-8.3
XXX
Hex code, instrument cluster inputs
Test 9: battery voltage
9.0
125
12.5 Volts
Test 10: Country coding
10.0
02
US 02
Test 11: Cluster code
11.0
000003
Cluster code
Test 12: Not used
Test 13: Gong test
13.0
GONG
Activate gong by pressing button (gong response is delayed)
Test 14: Fault memory (not used for diagnosis)
Test 15 - 18: Not used
Test 19: Lock/unlock
19.0
L-On L-Off
Lock/unlock specific test functions
Test 20: Average fuel consumption correction factor
20.0
XXX9
Press button when correct 1s position is attained
20.1
XX5X
Press button when correct 10s position is attained
20.2
12XX
Press button when correct 100s position is attained
Test 21: Software reset
21.0
reset
Reset software
Instrument cluster, self testing
Perform the following steps to access the instrument cluster self test functions:
Remove and insert ignition key (ignition OFF)
Press and hold RIGHT cluster button. “CHECK CONTROL OK” is displayed.
Without releasing button, turn ignition switch to first dent (RADIO position). “TEST-NR. 01″ is displayed.
Press LEFT cluster button for the test sub-menus.
Press RIGHT cluster button to scroll to next test.
Note:
Test 1 and 2 are always unlocked
Test 3-21 are only accessible after unlocking using TEST-NR. 19 lock/unlock function. See Instrument cluster self test, unlocking. Instrument cluster self test, unlocking
To unlock a specific test:
Use RIGHT cluster button to scroll to TEST-NR. 19 (lock/unlock)
Press LEFT cluster button once to access TEST-NR. 19 submenu. “LOCK : ON” is displayed
Use LEFT cluster button to scroll to test you wish to unlock.
Press RIGHT cluster button once to unlock desired test. Display returns to TEST-NR. 01.
Scroll to unlocked test using RIGHT cluster button.
Press LEFT cluster button to perform desired test or access that tests submenu.
Repeat unlock sequence for each test required.
Switch ignition OFF to cancel self test mode.
Note: Display shows no visual confirmation of test unlock. Instrument cluster, software reset
To reset instrument cluster software:
Use LEFT cluster button to scroll to TEST-NR. 21. “LOCK : 21″ is displayed
Press Right cluster button to unlock TEST-NR. 21. Display returns to TEST-NR. 01.
Use RIGHT cluster button to scroll to TEST-NR. 21.
Use LEFT cluster button to access TEST-NT. 21 sub-menu. “REST ?” is displayed.
Press LEFT cluster button again to perform reset.
Anders
'02 BMW M5 (Carbon black / black leather)
Stock apart from Eisenmann Sport, E60 545 short shifter mod, MKIV nav and Intravee II
ex '01 BMW 530D Touring (Sterling grey / beige leather)
ex '98 Mercedes C43 T AMG (Smaragd schwarz / black leather)
ex '99 BMW M Coupé (Cosmos black/ black-kyalami leather)
ex '93 Alfa Romeo 164 24V Super (Silver / black leather)
The Following 3 Users Say Thank You to rassi For This Useful Post:
Great post. Sounds like the OP has not properly unlocked the OBC. For the OP, other than test 1 and 2, are any of the other tests working?
Not sure if seatbelt needs to be buckled to shut off the light in the check control display, and obvioulsy the tests can all be run with the ignition on.
