Old 3rd February 2008, 01:08   #1
TiSiBeast
TiSiBeast's Avatar
Garage: 2000 E39 M5 TiSi, 2002 Jeep GC Gray
285/30/18's on front?
I have searched and searched but can't find anyone that has attempted this. I have scored a SMOKIN deal on a set of R compounds in this size, 4 of them. Rear I don't forsee an issue - fronts not sure if they will fit without rolling the fenders. I have rears on all 4 corners.
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
TiSiBeast is offline
Old 3rd February 2008, 04:03   #2
TiSiBeast
TiSiBeast's Avatar
Bump - No one has any input on this? Someone MUST have tried it! If not, I may be breaking new ground here. For the price I am getting these tires for I have to buy them.
Old 3rd February 2008, 05:04   #3
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
Wow, if they are BFG R1s, then they will likely be more like 300mm section width mounted if my experience with the R1 is any guide. I had run 265/35 Dunlop R-comps on my 330i zhp for autox, and so I ordered some BFG R1 265/35-18s for it, and they are simply HUGE. In additon they are "section-width-wide" all the way out to the tread face (as opposed to being tapered like most tires). The mounted section width of the 265s on an 8.5" rim was more than 275mm. They ended up rubbing badly in the rear, so BFG stepped up and sent me some 245/40s (which are much wider than the 255 street tires on the car, lol).
Anyway, back to your request. I've looked at doing 285/30s all around on 9.5" OE wheels on my M5. Based on my experience with 275s all around on 9.5's, you'll need more than a 3mm spacer up front, especially with the R1 285. In order to have enough fender clearance with a spaced out 285, you will need some decent negative camber. I think it will fit on my car as I have a bit more than 2 degrees negative camber up front, but I've not tried it yet.
I would try them up front with a 10mm spacer with the OE 9.5" rear wheel. This gives an effective offset of 12mm. You would need at least 3+5mm to clear the strut, so a 10mm spacer should be the best bet...but again, you have to have serious negative camber.
If this was a 285/30 street tire, I think it would fit fine following the above. If it's an R1 or some other R-comp (which almost all run wider than their stated section width), it might be tough. Use OE rear wheels, 10mm spacer and try it out though!
FWIW, here is a shot of a 265/35 BFG R1 next to a 275/35 Nitto NT-01 R-comp (and the NT-01 is a tad wider than a typical street tire 275!).
Chuck
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
Old 3rd February 2008, 05:15   #4
TiSiBeast
TiSiBeast's Avatar
Thanks for the input Chuck - WOW that's a wide tire! I have 5mm spacers up front currently but clearly I will need more than that. I guess I need to get in touch with Ground control as well and order some camber plates. Anyone want to buy me a full set of coilovers with camber plates? For the money I am getting them for though, I'll flip em to someone else at the same price if they don't work.
Old 3rd February 2008, 07:42   #5
TiSiBeast
TiSiBeast's Avatar
I did some more research, here is the technical spec info from BFGoodrich
According to this it will be 11.4 Inches on a 10" rim. I did a crude measurement on my car with a take and an eyeball, came up with a section width of about 10". That makes it 1.4" wider - that is A LOT more tire to try and stuff into the wheel well. I don't even think the rears would squeeze them without rolled fenders. Maybe I could put the rears on my 993... Hmm.....
Tire Size Service
Description
Sidewall MSPN Rim Width
Range (inches)
Section
Width on
Measuring
Rim Width
Overall
Diameter
Tread
Depth
(in/32nds)
Revs/Mile
at 45 mph
Max Load
(lbs@psi)
P205/50ZR15 84W BSW 62485 5.5 - 7.5 8.4 on 6.5 22.8 4 912 1113@51
P225/50ZR15 90W BSW 06811 6 - 8 9.1 on 7 23.6 4 881 1301@51
P205/55ZR16 89W BSW 21509 5.5 - 7.5 8.4 on 6.5 24.5 4 849 1279@51
P225/50ZR16 91W BSW 12323 6 - 8 9.1 on 7 24.5 4 849 1367@51
P245/45ZR16/LL 88W BSW 22748 7.5 - 9 9.57 on 8 24.65 4 844 1235@51
P225/45ZR17/LL 84W BSW 09627 7 - 8.5 8.9 on 7.5 24.8 4 839 1102@51
P235/40ZR17/LL 84W BSW 19220 8 - 9.5 9.5 on 8.5 24.2 4 860 1102@51
P245/40R17/LL 86W BSW 39601 8 - 9.5 9.8 on 8.5 24.2 4 860 1168@51
P255/40ZR17/LL 89W BSW 27377 8.5 - 10 10.2 on 9 24.8 4 839 1279@51
P275/40ZR17/LL 93W BSW 95479 9 - 11 10.9 on 9.5 25.5 4 816 1433@51
P315/35ZR17/LL 93W BSW 96664 11 - 12 12.6 on 11 25.5 4 816 1433@51
P225/40ZR18/LL 83W BSW 09117 7.5 - 9 9.1 on 8 24.9 4 829 1074@51
P245/40ZR18/LL 88W BSW 15639 8 - 9.5 9.8 on 8.5 25.4 4 819 1235@51
P265/35ZR18/LL 85W BSW 03040 9 - 10 10.7 on 9.5 25 4 832 1135@51
P275/35ZR18/LL 87W BSW 26533 9 - 11 10.9 on 9.5 25.4 4 819 1201@51
P285/30ZR18/LL 86W BSW 39643 10 - 11 11.4 on 10 24.9 4 829 1168@51
P335/30ZR18/LL 95W BSW 42166 12 - 13 13.5 on 12 25.7 4 809 1521@51
Old 3rd February 2008, 14:23   #6
CSBM5
CSBM5's Avatar
...and if anything, they will be a bit wider than the tech spec shows. I think it will definitely take some serious effort to make them fit in the rear too now that I think about it. One thing you have going for you is their smaller diameter however.
If you go with GC coilovers, get the "jaj" style (i.e. board member jaj worked with GC to come up with a clearanced front strut design so no spacers are needed for 9.5/275 up front, hence that would help with room up front).
FWIW, here's another R1 picture...this time of the 245/40s they sent me compared to the 255/35 street tire on the zhp (which is a BFG KDW2).
Current stable:
Brake ducts opened
TC Design brackets
CSBM5 is offline
The Following User Says Thank You to CSBM5 For This Useful Post:
SleepRM3 (3rd February 2008)
Old 3rd February 2008, 16:36   #7
SleepRM3
SleepRM3's Avatar
Garage: 1997 BMW M3/4-door Cosmos Black
Man, the BFG R1s are the teets; gotta try these on my M3 at my next DE.
SleepRM3 is offline
Old 3rd February 2008, 17:00   #8
EM5PWR
EM5PWR's Avatar
Garage: 02 M5
Nice tires.. Can I ask why would you want that big of tire in the front?? Isn't the 275 big enough?? Other than the fact your getting a killer deal on them..
EM5PWR is offline
Old 3rd February 2008, 17:46   #9
TiSiBeast
TiSiBeast's Avatar
Great deal plus I am DYING for a set of R Compounds for the track. You can NEVER have too much tire...
Old 4th February 2008, 01:31   #10
CSBM5
CSBM5's Avatar
By the way, BFG has a manual you can download about the R1. If you have decent front camber (-2.0 or more negative), so you don't have to be compensating proper tire pressures too much, I would shoot for 39psi up front and 37psi rear hot pressures as a starting point (probably 32/30 cold or so depending on ambient temp and driving style). You may have to go a bit higher if you have street rate springs and less than ideal camber...check sidewall wear/roll over.
Here's the link to the R1 manual.
The R1s are VERY sweet R-comps. They are extremely communicative -- much better than a Hoosier A6 in that regard. They are great at trail braking since you can so finely feel what the contact patches are doing, plus they are somewhat forgiving if you go over the peak of the tractive force/slip angle curve unlike a Hoosier that just says goodbye, good luck. The generate lots of grip at low slip angles, so the steering response is fantastic. If you've not ever driven on R-comps before, take it easy, work up to speed, and DO NOT over do it.
Chuck
Current stable:
Brake ducts opened
TC Design brackets
CSBM5 is offline
Page generated in 0.19663 seconds with 10 queries
