Old 2nd February 2008, 22:19   #1
djtroy
djtroy's Avatar
Garage: 2001 BMW M5
Send a message via ICQ to djtroy Send a message via AIM to djtroy Send a message via MSN to djtroy
ping, knock, detonation??
I noticed today when I really step on the gas I hear the car pinging or knocking. It only does it sometimes and it only does it when I am hard on the gas. I run 93 octane in the tank and I have a SES light that comes on and off once and a while. Do you think something might be causing the sounds and triggering the SES light. The light goes away and comes back every other day.
________________________
Stoptech BBK
Kelleners Exhaust
Black Chrome Kidney Grills
djtroy is offline
Old 2nd February 2008, 23:47   #2
jclyman
jclyman's Avatar
I would suspect a knock sensor. Either the wire has fallen OFF, or it is broken, or the sensor has gone south.
- Daniel Boorstin
jclyman is offline
Old 2nd February 2008, 23:55   #3
djtroy
djtroy's Avatar
Garage: 2001 BMW M5
Wouldn'tthis be a timing issue? I remember getting a timing is ******ed code.
Its going into the shop for diag but I was looking to bring some knowledge with me. Thanks for the tip
Stoptech BBK
Kelleners Exhaust
djtroy is offline
Old 3rd February 2008, 00:35   #4
Ladykats
Ladykats's Avatar
Garage: M5 Lemans Blue
Normally a knock sensor is a crystal, if it breaks... it is broken not intermittent. Do you know the company you buy your gas from... there are alot of stations that cheat. I know all the cheaters in my area from one of my old trucks, needed super or it pinged like crazy on accellation, at least now I know exactly where to go to buy gas for my ///M. It could be a miss fire in one of the cylinders, I haven't had a problem with timing issues on BMWs, but hey it could happen I guess.
Ladykats is offline
Old 3rd February 2008, 02:58   #5
djtroy
djtroy's Avatar
Garage: 2001 BMW M5
Could be bad gas but I think I have had it for a few fill ups. Ill see if I notice it again.
Stoptech BBK
Kelleners Exhaust
djtroy is offline
Old 4th February 2008, 13:57   #6
Envisage0
Garage: E39 M5 Avus Blue
I had this and my Camshaft Positioning Sensors (exhaust) were shot. Cured it completely.
**** it, let's do it - Australian proverb
Envisage0 is offline
Old 5th February 2008, 01:39   #7
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
With most modern cars, you should not be able to hear any pinging; the knock sensor should take care of it long before it becomes audible. I would suspect either broken knock sensors, in which case you should get a code, or more something else, like CPS suggested above.
gsfent is offline
Old 5th February 2008, 06:26   #8
ard
ard's Avatar
Bingo.
You will never hear detonation. If the KS goes bad the car automatically assumes it is detonating and ******s timing to protect the engine!
No Peake? Yet?
ard is offline
Page generated in 0.12465 seconds with 10 queries
