or just the typical optomistic e39 speedo. Next time, have someone reset the avg speed on the obc, it is more acurate.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
Fuddy,
where in NJ where you able to get it up to 175mph, without being tagged by the state troopers?
Better yet, why are you so irresponsible on a highway that you share with other INNOCENT drivers? Please read the e60 M5 and an airstrip in Florida thread and then SLOW DOWN.
__________________ 01 Black on Black M5: Custom Exhaust with Straight Pipe & Magnaflow 14816 Mufflers, Angel iBright v3.0, 19x9.5/15mm All Four Beyern Mesh Custom Painted Silver Gray Metallic w/ Kumho Ecsta SPT's 275/30/19's, Dinan Springs, Koni Yellows, Hamann Replica Front Lip custom painted
I don't know a lot about speed limiters (just what I have read here for the last 5 years).
I understand there are two ... one top speed limiter, and one RPM limiter. The top speed limiter hits us at 155 MPH actual (plus up to 10 % error, which would be 170 MPH). The RPM limiter has a limit of 7,000 RPM in 1st, 2nd, 3rd, and 4th gear. It's limit in 5th is 6,800 RPM, and in 6th is 6,500 RPM. (Per a post a long time ago by Gustav.)
And, I have read that the Dinan reprogram adds 500 RPMs in each gear and unlimited top speed.
