Old 2nd February 2008, 20:47   #1
140.6
Garage: 2002 e39 M5 - Titanium Silver
Vanos Problem or Something Different?
First off I have spent lots of time reading everything I can find on the forum regarding the vanos issues, unfortunately what is happening with mine seems to be a little different.
A little background to begin with. I was fortunate enough to find a 2002 M5 that had never been put into service (long story which there is a thread on) and so I have the original manufacturer's warranty until December of 2010 or 50,000 miles. So my I am confident that this will get fixed, eventually.
The noise my car makes is only when the car is cold. However, where mine differs from others is that the noise does not go away fully until the engine temp is running at its 'normal' levels and the oil temp is into its 'normal' operating range. So where others only experience the rattle for a few seconds my lasts for a couple of minutes and only happens when the car is under load and moving. There is no rattle if I just sit in my driveway or a parking lot and rev the engine, the car actually has to be moving.
So I am looking for some thoughts, suggests, etc. my tech so far says no worries that this is not hurting anything (not sure I believe him).
Thanks,
Pete
140.6 is offline
Old 2nd February 2008, 21:05   #2
Kmac
Kmac's Avatar
Garage: Alpine White E39 M5; Carbon Black E46 M3
Does the noise increase with speed or stay the same?
E39 M5 MY'00 (FOR SALE)
Rogue Engineering SS Kit/Rogue Clutch Stop/M Aluminium Pedals/Hardwired V1/TEC Cupholder/Titan Trim & door handles/Bimmian Knob & E-brake/Euro Arm Rest/Alutec Strut Bar/M3 Steering Wheel/35% tint/Centric Rotors/Axxis ULT's/SS Brake lines/16:9/MKIV/IntraveeII/Tubi Exhaust/AA Cai/Conforti Shark Injector/TC Design Brackets/Dinan Stage 1 Suspension/Bavarian Auto Poly Trailing Arm Bushings
E46 M3 MY'01/100k miles
TCKline Double Adjustable Coilovers/TCKline Adj Camber Plates/Delrin bushings/TCKline Racing wheels (18x10 - 19lbs)/Bridgestone RE01A 265/35r18's/Wheel Studs/Goodrich SS Lines/UUC SS Kit/ZHP Knob/Hardwired V1/XM Radio/CF Hood/CF Fenders/Dust cover delete\Dinan Front strut brace/GC Sway Bars/Superprint Stepped Headers/Rougue Midpipe w/dump valve/Random Cats/Supersprint Race pipe/Rogue Diablo Exhaust/Rugue Pullies/CSL CF Airbox/Alpha N software/StopTech BBK
E90 M3 MY '08
Bone stock
"For Sale: 20th Century French Rifle - never fired, dropped twice."
Kmac is offline
Old 2nd February 2008, 21:05   #3
Kmac
Kmac's Avatar
oh - and i assume its coming from the engine compartment...
E90 M3 MY '08
Bone stock
Kmac is offline
Old 2nd February 2008, 21:17   #4
140.6
The noise sounds and feels like it is forward and to the right of the shift lever. I am not sure the the engine compartment is accurate. At first I thought it was a catalytic converter but I was assured after a trip to the dealer the catalytic converters were functioning normally. And the noise does increase with speed or throttle pressure (but not when in neutral).
Thanks.
140.6 is offline
Old 2nd February 2008, 21:47   #5
Kmac
Kmac's Avatar
Did a couple of searches and the only thing i found is something called a guibo - need to do some checking but apparently its connected to the driveshaft and wears out. Given the fact that i am technically challenged, i may not be helping but just adding questions.
-Kmac
E90 M3 MY '08
Bone stock
Kmac is offline
Old 2nd February 2008, 21:48   #6
Kmac
Kmac's Avatar
Here is a link that I found describing what it is:
http://www.rogueengineering.com/Merc...ory_Code=GUIBO
E90 M3 MY '08
Bone stock
Kmac is offline
Old 2nd February 2008, 23:07   #7
140.6
Definitely not the guibo. But thanks for the effort.
When I am driving it for the first time after several hours rest (i.e. when its cold) you can actually hear the noise as well as feel it come from the underside of the vehicle near the transmission and firewall. To me it feels like it would be where parts of the exhaust system are, hence the reason I originally thought it was the catalytic converter.
140.6 is offline
Old 2nd February 2008, 23:38   #8
Kmac
Kmac's Avatar
Couldnt be as simple as an exhaust hanger could it?
E90 M3 MY '08
Bone stock
Kmac is offline
Old 2nd February 2008, 23:55   #9
140.6
I can only hope. The only reason that I don't think that would be the case is that if it were a hanger i would expect the noise regardless of engine/oil temp.
140.6 is offline
Page generated in 0.12087 seconds with 10 queries
