Old 2nd February 2008, 19:13   #1
Kmac
Kmac's Avatar
Garage: Alpine White E39 M5; Carbon Black E46 M3
Common modifications - why?
There are a few mods that i have seen done that i dont quite understand what they do:
IATS relocation - what does this solve?
Tranny mounts - understand what they do, but is this a track use mod only? or will it extend the life of the notoriously weak clutch?
TY - KMac
E39 M5 MY'00 (FOR SALE)
Rogue Engineering SS Kit/Rogue Clutch Stop/M Aluminium Pedals/Hardwired V1/TEC Cupholder/Titan Trim & door handles/Bimmian Knob & E-brake/Euro Arm Rest/Alutec Strut Bar/M3 Steering Wheel/35% tint/Centric Rotors/Axxis ULT's/SS Brake lines/16:9/MKIV/IntraveeII/Tubi Exhaust/AA Cai/Conforti Shark Injector/TC Design Brackets/Dinan Stage 1 Suspension/Bavarian Auto Poly Trailing Arm Bushings
E46 M3 MY'01/100k miles
TCKline Double Adjustable Coilovers/TCKline Adj Camber Plates/Delrin bushings/TCKline Racing wheels (18x10 - 19lbs)/Bridgestone RE01A 265/35r18's/Wheel Studs/Goodrich SS Lines/UUC SS Kit/ZHP Knob/Hardwired V1/XM Radio/CF Hood/CF Fenders/Dust cover delete\Dinan Front strut brace/GC Sway Bars/Superprint Stepped Headers/Rougue Midpipe w/dump valve/Random Cats/Supersprint Race pipe/Rogue Diablo Exhaust/Rugue Pullies/CSL CF Airbox/Alpha N software/StopTech BBK
E90 M3 MY '08
Bone stock
"For Sale: 20th Century French Rifle - never fired, dropped twice."
Kmac is offline
Old 2nd February 2008, 19:28   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
trans mounts are probably unnecessary. I had them, took them back out. Only thing i noticed was more noise and vibration in the cabin, no difference in shift quality or effort. They do nothing to help the clutch.
the factory iats is in the drivers side (US) mafs, so when the mafs gets hot, during heat soak conditions, the iats will show an elevated reading, causing inconsistant performance. Dinan and UF motorsports have a kit to relocate it to get a more 'true' intake air temp reading, so performance can be more consistant in warm weather.
Honestly, i didnt notice much difference when i did mine.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 2nd February 2008, 19:32   #3
Kmac
Kmac's Avatar
Ok - that would mean the tranny mounts are a no, i would only do it if necessary for clutch life.
IATS makes some sense, just need to decide if i will put the car in conditions where it would make a difference.
Thank you.
E90 M3 MY '08
Bone stock
Kmac is offline
Old 2nd February 2008, 20:26   #4
jclyman
jclyman's Avatar
The only thing that really helps the clutch is proper use ... make sure your left foot is OFF the pedal before you hammer the loud pedal ...
- Daniel Boorstin
jclyman is online now
Page generated in 0.10029 seconds with 10 queries
