Old 1st February 2008, 18:41   #1
MfiveLeo
MfiveLeo's Avatar
Garage: 00 ///M5, Black
HPF maf's??
has anybody tried out these maf's? i wonder how the fitment is.
also does anyone know the diameter of the oem maf's?
http://www.horsepowerfreaks.com/pric...r_Flow_Sensors
MfiveLeo is offline
Old 1st February 2008, 23:18   #2
E55AMG2
E55AMG2's Avatar
I'd assume they'd work just the same if there is a "translator" harness included. However, you'd still need software of some kind to compensate for the larger tube.
you might give them a ring to see what's up.
edit:
I just called them. They need a translation box (or something like that) to work properly. Basically it would be something like $1100 for 2 MAFs + 2 Translation boxes (139.99 for each MAF and 399 for the box). Im sure that these could work with any CAI, or with a step up/down hose and the stock intake.
E55AMG2 is offline
Old 6th February 2008, 08:05   #3
MfiveLeo
MfiveLeo's Avatar
edit:
i wonder how this setup would compare to dinan's larger maf's
MfiveLeo is offline
Old 6th February 2008, 16:05   #4
E55AMG2
E55AMG2's Avatar
me too...I guess it just comes down to me coughing up the cash and trying this
E55AMG2 is offline
Old 6th February 2008, 20:02   #5
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
You need to be careful with MAFs, those are GM MAFs, which I think use a PWM output type, completely different than a 0-5V output of our MAFs.
To take full advantage of a larger MAF, you will need the rest of the intake tract to be the same size as well.
John Baas
2001 Anthracite Metallic M5
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Old 6th February 2008, 21:13   #6
E55AMG2
E55AMG2's Avatar
Exactly, you have to get a conversion box for it to work properly. I was thinking maybe going to a Dinan CAI, but AFE seems like it will fit my budget a little better. I dont knw about the AFE box though, as it still breathes thru the stock snorkels (where the restriction point of our intake system really is).
E55AMG2 is offline
Old 6th February 2008, 22:45   #7
xr4tic
xr4tic's Avatar
If you were looking for alternate MAFs, I would look into the Ford MAFs.
They can be had pretty cheap, operate from 0-5V+, are rescalable, and are damn near bulletproof.
It may even be possible to have a Ford MAF re-curved to match the factory MAF curve.
If you think about it, the cost of 2 translator boxes is almost the same as getting a reflash though.
Plus, you don't want a MAF that is scaled to flow too much, or you lose a lot of resolution, since we will have 2 MAFs, the max airflow is halved
John Baas
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Old 6th February 2008, 22:55   #8
xr4tic
xr4tic's Avatar
Or, just get a new housing:
3" -
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
3.5" -
If it wasn't for the fact I bought a used Dinan MAFs kit, this is probably the route I would go, then get Powerchip software to match
John Baas
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Page generated in 0.12839 seconds with 10 queries
