Old 31st January 2008, 17:36   #1
maxrpm
maxrpm's Avatar
Garage: m5 e39 blue
slight steering wobble at low speed
my car has a slight wobble at low speed not all the time just now and then i checked brake discs with dile gage and they are fine wheels and tires and fine too not really sure wot to do next,anybody ever had same prob or anybody any ideas ya can feel it on floor pan too nearly sure it pass front it coming from ?/???
maxrpm is offline
Old 31st January 2008, 18:07   #2
innoSINce
innoSINce's Avatar
Garage: 03 E39 M5 Le Mans Blue
Check your tire pressure, let me know if that helps.
Sin
innoSINce is offline
Old 31st January 2008, 18:09   #3
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (5)
Does this wobble happen when you brake?
Diny is online now
Old 31st January 2008, 18:24   #4
maxrpm
maxrpm's Avatar
Garage: m5 e39 blue
yeah seems once car driven a while not as bad and really bad at times when ya brake its weird times car fine times it shakes your hands tires pressures seem fine tried diff rims and the same but was same tires
maxrpm is offline
Old 31st January 2008, 18:29   #5
Diny
Diny's Avatar
Sales Feedback: (5)
Okay, try this:
Does it also happen when you engine brake (meaning you dont even touch the brake pedal)?
If it only happens with your brakes, sounds like rotors. If it happens all the time, then you may have a thrust arm bushing going out.
I've had wobbling but it went away once i got new rotors. Car would wobble only when I used the brakes, though.
Diny is online now
Old 31st January 2008, 18:31   #6
jetblack01m5
jetblack01m5's Avatar
Garage: '84 911, '06 Cayenne TT
How many miles on your car? I had a wobble like that and I had to change the thrust bushings and that took care of it.
When I first bought the car I had a shake that happened at all speeds... ended up all 4 of the rims were bent (not by me and a fairly long story...).
Current: 2006 Porsche Cayenne TT, 1984 Porsche 911 Carrera
Sold: 2001 BMW M5, 2007 Mazda Miata, 2004 Subaru Impreza WRX
jetblack01m5 is offline
Old 31st January 2008, 18:40   #7
maxrpm
maxrpm's Avatar
Garage: m5 e39 blue
ya could be free wheeling and it would happen and wot is rotors car has 97k but not long through cat2 inspection which cost £2500 pound
maxrpm is offline
Old 31st January 2008, 18:45   #8
Diny
Diny's Avatar
Sales Feedback: (5)
Rotors are the brake discs.
Diny is online now
Old 31st January 2008, 18:52   #9
maxrpm
maxrpm's Avatar
Garage: m5 e39 blue
keep thinking brake discs myself cos bad when cold,are they soild could i skim them
maxrpm is offline
Old 1st February 2008, 11:36   #10
mohan
Garage: e39 M5, silverstone blue
need more details mate.... is it a wobble through the steering, and only on braking gently, or though the pedal, or the whole car.....
if under gentle braking, and discs are not warped, could be residue on the discs...
Vibration when cruising
'99 E39 ///M5 (ex-mistress, sorely missed)
mohan is offline
Page generated in 0.13912 seconds with 10 queries
