• Latest threads
    • Custom feed
      • Updates
        Old 22nd January 2008, 20:08   #1 (permalink)
        IceMan8247
        IceMan8247's Avatar
        Hood badge delaminated
        While driving on the highway today my BMW hood badge delaminated and flew off. Now I'm left with the silver circular badge without a decal. Anyone have experience replacing the hood badge?
        IceMan8247 is offline
        Old 22nd January 2008, 20:16   #2 (permalink)
        Laidback
        Yes i have replaced my hood badge and trunk...fairly easy...
        (New) Mfest featured on Las Vegas Review Journal
        Click here for the article...
        For the latest talk about Mfest pls click here Mfest forum
        myspace
        "Illegitimus non carborundum"
        Laidback is offline
        Old 22nd January 2008, 20:35   #3 (permalink)
        jclyman
        jclyman's Avatar
        It has happened multiple times on other BMWs of mine. (Not on the m5, though.)
        The "jolt" of a slamming hood is the most likely cause. (I should say multiple slamming hoods.)
        The replacement is inexpensive, and easy to install. The difficult part is removing the old Roundel.
        It is held in place by two rubber grommets (buy two of them as well), and the only way I have figured out how to remove the old one, is to use a small flat blade screwdriver AND PROTECT THE BODY FINISH WITH A RAG. (Masking tape may work.) The problem is getting the blade under the Roundel.
        Actually, there may be another way ... I just tought of it while writing the above. Drill a small hole in the center of the old Roundel. Pull out with a hook device. It is just held in place by two rubber grommets gripping two "stubs" on the back of the Roundel.
        Good luck.
        - Daniel Boorstin
        jclyman is offline
        Old 22nd January 2008, 20:40   #4 (permalink)
        Diny
        Diny's Avatar
        Oh man if I was a car behind you, I wouldve been laughing my *** off if I saw your badge fly off
        Diny is offline
        Old 22nd January 2008, 20:45   #5 (permalink)
        Racerxjling
        Racerxjling's Avatar
        Find the thinnest screwdriver possible and wrap the tip w/ electrical tape to avoid scratching the paint. Be sure to be VERY patient as it's easy to slip and scratch the paint. It may even help to use 2 thin screwdrivers. While you are at it, replace the rear if it's cracking/worn.
        Jeff
        Racerxjling is offline
        Old 22nd January 2008, 21:27   #6 (permalink)
        IceMan8247
        IceMan8247's Avatar
        Thanks,
        Where can I buy replacements?
        BMW Part #s?
        Old 22nd January 2008, 22:14   #7 (permalink)
        MGZ
        MGZ's Avatar
        I used tooth thread? to remove the roundel: Doubled it up and see-sawed it under the roundel. Got it up after a few tries. A thin screwdriver can easily dent the paint.
        Modifications: Too many!
        MGZ is offline
        Old 22nd January 2008, 23:20   #8 (permalink)
        E60M5ATL
        E60M5ATL's Avatar
        happend to my 01 540i, I took it the dealer and watched them remove the silver badge with some flat plastic 'tape' (not sticky). the kind you see wrapped around large boxes for support for shipping or transport.
        he basically slipped the plastic tape underneath the badge, worked it as close to the middle as possible, then pulled up on the ends in his hands. it popped right off. (he did have to pull pretty hard)
        E60M5ATL is offline
        Old 23rd January 2008, 18:27   #9 (permalink)
        rneedham1979
        rneedham1979's Avatar
        get it at bmw they all have a bunch of these. just make sure you get two ruber grommets that go in the hood
        rneedham1979 is offline
        Old 23rd January 2008, 19:18   #10 (permalink)
        BillyBimmer
        Thanks,
        BMW Part #s?
        Bavauto.com sells the replacement emblems and I believe has instructions on website to remove/install. I used old credit cards to slide under and remove. I believe replacements are $10-$12 each. Good Luck.
        Regards, Bill
        2000 M5 Imola Red, Dinan CAI, Software, Exhaust
        1999 328IS Avus Blue (kid's drive, I pay)
        1998 540i Alpine White (kid's drive, I pay)
        2001 330ci Topaz Blue (daily driver)
        2004 Yukon XL (wife's)
        BillyBimmer is offline
        Old 6th May 2008, 21:54   #11 (permalink)
        FredW
        FredW's Avatar
        Actually the hood is $34. The grommets are $.95 each and shipping to NW NJ is $7.95
        That's my opinion, although I might not agree with it.
        2001 M5, Titanium Silver, Black, Stock.
        2003 X5 3.0, Grey Green Metalic
        1994 B757-200
        2001 B757-300
        1999 B767-200ER
        2002 B767-400ER
        FredW is offline
