• Latest threads
    • Custom feed
      • Updates
        Old 20th January 2008, 23:39   #1 (permalink)
        DRM
        DRM's Avatar
        Exclamation Report: 1 YR+ and 14k+ miles on S3.....
        'Waiting for Charger game to start; so thought I'd share S3 experience since project was completed more than 1 year ago. 'Not a whole lot to say; you know, just a "The Good, The Bad, The Ugly" type summary. To reiterate, I'm the original owner. 'Car was stock almost 3 years; "full monty" S2 mods completed Jan. '05; full S3 conversion done 2 years later at year-end '06.
        She has accumulated almost 70k miles; with only very minor "issues" (leaking review mirror/pixels out/front fan clutch/fuel gauge sending unit/lower front control arm bushings) having required repair/replacement during this entire time. I've never had even an SES light come on; let alone anything major go wrong with this car. 'True, 'been anal about proactive maintenance; replacing every single sensor/filter/plugs (regardless of having no symptoms) @ 53k miles, for example.
        "The Good" - S3 power is "as advertised" (already reported verified on Dinan's dyno when I picked up the car there); 530rwhp and 507 lbs tq (assuming standard 15% drivetrain loss). Locomotive and linear, she's quite docile when just cruising around; but ready to "play", from any gear @ any speed, when it's time to "get it on". I've pegged the speedo a couple of times (in Mexico) in 5th gear; and she was still pulling like a freight train.
        To me, even more impressive than power, are suspension/handling, brakes, clutch, and oil cooling (latter being Dinan's bespoke high capacity oil cooler for S3). Whether "hot foot'n" on back country 2 laners or going 10/10th's @ "Big Willow's" 2.5 mile road race track, she stays completely "glued", oil temp never gets to 210 mark, BBK w/Ferodo pads goes all day with no noise/dust/fade, and Dinan's very beefy, designed for specific S3 application, very smooth clutch/flywheel set-up holds power/torque without protest.
        IMO, 'sum and substance of S3 is that, top to bottom/ stem to stearn, it's a complete pkg that tranforms a stock M5 from an already great car, into a superb performance sedan. 'Economics (cost) of this "transformation" have been well discussed here on the M5Board. For me, it was an easy decision to do an S3 upgrade. 'Cost was far, far less than suffering $$$ differential to acquire a new car. Besides, after having an opportunity to spend several days with a completed S3 (Martin @ AGA had bought S3 #001 from Dinan); and comparing it to all the new sedans/big coupes I'd tested during '06, no car ("M" or otherwise) came remotely close, IMO. It was a "no brainer".
        "The Bad" - A few months ago, 'tranny began experiencing intermittent 1st gear "pop-out"; especially when cold. AGA opened it up and discovered a worn part ('can't remember exactly what) that was the cause. Martin told me he could fix it with some expert welding on the affected part. Fortunately, AGA also had a used M5 tranny (pulled from a wrecked '03 w/14k miles). I opted to buy that as a replacement for mine. So, for WAY less than cost of new tranny, 'replaced my 65k mile Getrag with a relatively fresh one. End result is just like new; "snick, snick, snick", as it should be.
        "The Ugly" - 'Not related to S3, but poor luck. 'Have had to repaint my front end 3 times; 2 blowing sand occurrences and getting caught behind a caravan of gravel trucks spewing pebbles. These were "comprehensive" insurance claims and I have zero deductible; so no cost to me. Each time I took the car to the highest end body/paint shop in San Diego County. And each time it was a fight with State Farm to get them to approve the "right" way to repair/repaint ($8k+ for every instance; example is getting them to relent to completely stripping each affected body part; then 2 primer coats/4 color coats with color sanding between each one/3 clear coats). Well, the shop owner and I were bull dogs about it. 'Good news is the car looks brand new. 'Hope I don't get trapped in any other mishaps. 'Plan to keep her 'till the wheels fall off.
        Anyway, by my count and not including AGA's car, there's only five S3 owners/members on this Board. Other than "Kelster" (who reported tribulations getting his software "dialed in"; then his exploits at 1/4 mile drag racing), nobody has said anything about S3 experience as owners. So 'hope this little summary was informative.
        Dan
        ______________________________________________
        Daily Driver
        '02 M5 (Chiaretto Red Metallic w/black napa full heritage leather/wood trim/leather Euro cntr console/BSW speakers and sub) Sig series Dinan S/C'd S3 package/ Dinan S3 clutch-flywheel/Dinan high capacity oil cooler /Dinan forged aluminum wheels/Dinan SSK/Dinan - Brembo BBK/Stg 3 Dinan - JRZ suspension/monoballs/275-35-18 RA 1's all around
        The "Predator"
        '02 996TT w/X50 (slate grey metallic w/full natural grey leather, small carbon package, aluminum trim pieces, exterior color painted wheels, etc, etc).
        EVOMS Stage 4 (640hp/615tq)
        PSS9 w/F&R H&R sways and EVOMS F&R shock tower braces
        Sachs clutch and Porsche SSK
        Mich PSC's 235/18 fronts; 295/18 rears
        DRM is offline
        The Following 15 Users Say Thank You to DRM For This Useful Post:
        AfricaOffroad (21st January 2008), alquazi (21st January 2008), BKH (13th June 2008), El Diablo (21st January 2008), enzopain (26th January 2008), gbogh3 (14th June 2008), Gustav (21st January 2008), intrepid one (21st January 2008), IRISH M5 (21st January 2008), Kelster (21st January 2008), mfizzlenyc (13th June 2008), Para (21st January 2008), rassi (21st January 2008), Rcl4668 (20th January 2008), wilsodh (21st January 2008)
        Old 21st January 2008, 00:19   #2 (permalink)
        s1rch
        s1rch's Avatar
        cool!
        nice read and glad to hear your M is running strong.
        Carbon Black/Black Extended
        s1rch is offline
        Old 21st January 2008, 00:21   #3 (permalink)
        gsfent
        gsfent's Avatar
        Great to see she is holding up as advertised and you are still having a blast. With the upcoming horsepower wars, 620 will just be "adequate". Unbelievable!
        Keep enjoying her and keep us updated so we can enjoy vicariously!
        Dinan Stage3 suspension and CAI, SS jet coated headers, Evosport UD pulley kit, IATS, PC Gold 93, open brake ducts, Hamann front splitters, TEC cupholder, Euro tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, 2.65 diff w/40% lockup/2x dynamic, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit
        gsfent is offline
        Old 21st January 2008, 00:56   #4 (permalink)
        Gustav
        Administrator
        Gustav's Avatar
        Thanks for the report, its an excellent car you have!
        BMW M5 2003 with complete Supersprint exhaust system and StopTech brakes, delimited by Hartge.
        gtboard.com DVD II (NTSC) Best Price $25.00
        gtboard.com DVD II (PAL) Best Price $30.00
        Webmaster LinkedIn Facebook
        m5board.com Facebook Group
        At your service: comments, suggestions or feedback: gustav@bmwm5.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
        Gustav is offline
        Old 21st January 2008, 01:14   #5 (permalink)
        Laidback
        Guys i was lucky enough to get a ride on Dan's S3 ( for awhile i was hesitant to go because i will know the outcome ) and yes my hunch was right ...it's a Monster!...It was very comfortable, feels like nothing till Dan opens her up and all bets are off n(it pulls and stops on a dime) i was trying not to hold the arm rest too tight (playing it cool) but my toes are trying to grip on my shoes...very clean car and a sleeper S3 indeed
        (New) Mfest featured on Las Vegas Review Journal
        Click here for the article...
        For the latest talk about Mfest pls click here Mfest forum
        myspace
        "Illegitimus non carborundum"
        Laidback is offline
        Old 21st January 2008, 05:50   #6 (permalink)
        EM5PWR
        EM5PWR's Avatar
        Dan , time flies when your having fun huh?? Great write up..
        EM5PWR is offline
        Old 21st January 2008, 10:11   #7 (permalink)
        greer
        greer's Avatar
        Hi Dan,
        About the clutch, is the effort to depress it much greater then the stock E39 M5 clutch?
        Also, if you drive with the DSC on, does the system cut down the power before you can get some serious speed going?
        Thanks,
        Gene
        2003 E39 M5
        Ti. Silver over Silverstone 2 tone interior.
        Gene - AKA "Greer"
        "Fortune favors the brave"
        greer is offline
        Old 21st January 2008, 16:27   #8 (permalink)
        CSBM5
        CSBM5's Avatar
        Thanks for the update Dan. It sounds like everything Dinan claims for the S3 has worked out, so that's great to hear. It lends support to the argument (that this board has gotten into in the past) about Dinan pricing and why it is worth buying a fully sorted, well-engineered product with a complete warranty (and CARB approval) which is never the cheapest product on the market.
        The only sad part about the E39 M5 to me is that we are entering the "decline" phase of the majority of them. Prices have fallen to where people who will not maintain them are buying them, low mileage cars are now rare, etc. All to be expected of course but a bit sad still.
        Thanks again for the update and go enjoy the S3!
        Chuck
        Current stable:
        Ground Control camber plates
        Stoptech front brake kit
        Brake ducts opened
        TC Design brackets
        OE 9.5" rear wheels all around & 275/35-18 PS2s street
        275/35-18 Nitto NT-01 R-comps track
        1996 Volvo 850R wagon
        CSBM5 is offline
        Old 21st January 2008, 19:14   #9 (permalink)
        wilsodh
        wilsodh's Avatar
        Dan! What a nice report. You indeed have a real gem. As one who has experienced 'Martin's Wild Ride' in your car, I can say I'm honored to have experienced her at 10/10ths. Just amazing.
        Another way we might look at it is that the S3 keeps the old gal relevant, even with the upcoming horsepower orgy..
        On the other hand, the economics of taking a nice, depreciated e39 and upgrading her to an S3 look more attractive. As Dan alluded, it can make more sense than going out and buying new.
        Dave
        '00 Royal Red/black/walnut M5
        'El Diablo'
        ’00 Black/black DA s/c M5
        Carrillo rods, Arias pistons,
        Schrick cams, Vortech T-trim,
        Supersprint headers/exhaust,
        wilsodh is offline
        Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Add this post to your Facebook Profile Add this post to MySpaceStumble this Post!
