20th January 2008, 21:31
#1 (permalink)
Braille 15lb. vs BMW OEM
i just recieved my braille 15lb battery and its tiny. i cant wait to get it into the m. To keep it in place im using a small garbage bag and filling it with "GREAT STUFF" and just setting the battery in the middle until it stifens up. i cant take credit for the idea because my step dad suggested it. But i have taken comparison pictures so ill post them on here when i get out of work. btw i paid 164 with shipping from tirerack. they had the best price.
20th January 2008, 22:00
#2 (permalink)
oem is on the left. braille on the right. in case you were unsure...
20th January 2008, 22:59
#3 (permalink)
Specs on the braille in comparison to OE?
Dinan Stage3 suspension and CAI, SS jet coated headers, Evosport UD pulley kit, IATS, PC Gold 93, open brake ducts, Hamann front splitters, TEC cupholder, Euro tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, 2.65 diff w/40% lockup/2x dynamic, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit
21st January 2008, 00:32
#4 (permalink)
Do you think you'll have it installed within the next day or so? It would have been interesting to see how it would have withstood the cold temperatures that we have right now.
I recall member 6speed having trouble with the voltphreaks battery when it got cold ( thread here) and sat without a trickle charger.
21st January 2008, 00:33
#5 (permalink)
braille 1067 crank amps 550 cca 15lbs.
oem 850 i beleive and 650 cca 62lbs.
The Following User Says Thank You to FastPOLAK For This Useful Post:
21st January 2008, 00:34
#6 (permalink)
oh well i dont care about that as i do not drive my girl at all in this upsetting weather. i am all honda these days.
21st January 2008, 00:50
#7 (permalink)
That is kind of what I was getting to. If you let your car sit for more that a couple days without a trickle charge, the voltphreaks ran down to the point where you couldn't start the car.
I have driven my car (on stock battery) once every couple weeks when it was dry and clean enough outside. I don't have it on a trickle charger, but I have had not problems starting.
I was curious if the Braille would be able to withstand longish periods of time (more than a week or two) without a trickle charger in the cold.
21st January 2008, 03:34
#8 (permalink)
850 CCA, 100Ah for the stocker...
d-
21st January 2008, 04:19
#9 (permalink)
The Braille battery is manufactured by East Penn Mfg., it's not designed to be used to start a car. It's got less that 400cca(cold cranking amps@0). It a power sport battery(atvs-motorcycles-light watercraft). If you think it would run the electrial needs of a car like a M5, you're set up for a disapointment. I can't believe they would market it as a replacment battery for a car like a M5. Shame on Braille!!!!!
David---Redy Battery Co.
21st January 2008, 05:48
#10 (permalink)
what cost effiecient/light weight battery would you reccomend? our main goal is to drop as much weight as possible reliably...and cost effectively
-Leo
21st January 2008, 09:30
#11 (permalink)
this battery will start the car without a problem. it wont be plugged in over the winter. when i start driving daily i will plug it up. until then if i feel the need to drive her i will connect it and go for a drive. then just disconnect it again.
21st January 2008, 14:17
#12 (permalink)
I just can't see that lasting very long or being able to supply an M5 with the juice it needs. Sorry, I hope am wrong for your sake.
