• Latest threads
    • Custom feed
      • Updates
        Old 20th January 2008, 19:30   #1 (permalink)
        m5rangeroverandzx10r
        Post e39 m5 with M6 alloys anyone ?
        has anyone on herefitted the m6 alloys to a e39 m5 ?
        i bought a set and was told they would go straight on.
        WRONG!
        spigot size is bigger on the m5 and wont fit the m6 wheels on !
        however they are so close , i found that by winding the bolts in slightly , one at a time you can get it to pull them on all the way but its very hard !
        once they went on all the way i spun the wheels to make sure they ran true and straight, then removed them and filed the new cut hole smooth,
        was a nightmare to get the wheels off once they had been pulled on so tight buyt with a block of wood and a heavy malet they come off ok, then refitted with 5mm spacers on the rear and 3mm spaces on the front ive now got them on with longer bolts !
        all that work and i now find the fronts rub a bit on the inner plastic arch liner when on lock, so looks like will need to fit lower profiled tyres for clearance !
        i was told someone saw another car with the same conversion and wondered howmany others have done it and how they got round it ?
        justin
        m5rangeroverandzx10r is offline
        Old 20th January 2008, 20:20   #2 (permalink)
        Mattkins99
        Mattkins99's Avatar
        I went with replicas... I think there's one person here with a custom pained yellow M5 that went with OEM M6 wheels but he had the hub bored out.... He should chime in soon enough.
        Matt Atkins
        President Seattle5s (Puget Sound E39 SIG)
        http://www.seattle5s.com/
        '01 Lemans Blue M5 :-)
        -Dinan CAI
        -Dinan Stage 2 software
        '94 Green Pathfinder SE :-|
        Mattkins99 is offline
        Old 20th January 2008, 20:36   #3 (permalink)
        MGZ
        MGZ's Avatar
        It's SirRichi. He had a detailed description how he did it. Including installing brakes from the new series. Hopefully he will chime in soon.
        Modifications: Too many!
        MGZ is offline
        Old 20th January 2008, 22:28   #4 (permalink)
        MikeTrent
        MikeTrent's Avatar
        Only got some pictures of SirRichies M5 from carpassion :
        MikeTrent is offline
        Old 20th January 2008, 23:45   #5 (permalink)
        looks nice, ive just test driven mine and the tyres rub !
        i expect lowprofiles are required but would love to know what ones to go with !
        how do i upload pics ?
        Old 21st January 2008, 00:25   #6 (permalink)
        morals
        morals's Avatar
        Can't help myself....off-topic, and I've said it before, but I have to say it again.
        That Yellow (forgot official color name) is Effing ridiculous! I love it, and I usually can't stand yellow (some E36 M3 Dakars if done right).....
        :drool:
        morals is offline
        Old 21st January 2008, 00:40   #7 (permalink)
        heres mine, ill repost when i get a chance to wash it ! lol
        e39-m5-m6-alloys-anyone-m5018.jpg   e39-m5-m6-alloys-anyone-m5020.jpg   e39-m5-m6-alloys-anyone-m6alloysonm5.jpg
        Old 21st January 2008, 00:45   #8 (permalink)
        and the rears rub like mad when on power !
        Old 21st January 2008, 01:35   #9 (permalink)
        J Irwan
        J Irwan's Avatar
        WRONG!
        justin
        Could you post the Offset of the M6 OEM wheels..
        I think the offset might be already low enough, and since you adding 5mm and 3mm spacer respectively it even lowered the offset.
        Lower offset will move the wheel outward (from the center of the car) thus increased vehicle track width. When this happened, it increase the possiblity of rubbing when doing full lock turn.
        I've read from some other post that couple people running LM 19x8.5 ET17 and 19x10 ET25 running some 255/35/19 and 285/30/19 with no rubbing, althought it seems that wheel/tires clearance already at the limit.
        Regardz,
        J Irwan
        02 Carbon Black ///M5
        J Irwan is offline
        Old 21st January 2008, 02:22   #10 (permalink)
        J Irwan
        J Irwan's Avatar
        okay so I took some liberty and look up the OEM (E63) M6 wheels
        http://www.realoem.com/bmw/showparts...82&hg=36&fg=15
        The specs are as follow:
        19x8.5 ET 12
        19x9.5 ET 17
        I think the offset is too aggressive for E39 chassis, considering the rim width.
        Now with the spacer of 3mm (front) and 5mm (rear),
        your final offsets are as follow:
        19x8.5 ET 9
        19x9.5 ET 12
        So no wonder if the tires are rubbing. I would think even the rear will rub on the fender lip as well when the suspension is compressed (with passenger on the rears or luggages in the trunk).
        Regardz,
        J Irwan
        J Irwan is offline
        Old 21st January 2008, 03:55   #11 (permalink)
        DouglasABaker
        DouglasABaker's Avatar
        If I were you I'd have someone check out a) the center of your rims and b) the holes for your lug bolts.
        You just used bolts to put a 72.5mm hole onto a 74mm post. 1.5mm is not small and it is highly unlikely that your "new hole" is completely centered and true on all 4 wheels. Further, you have put an enormous amount of stress on the threads of the lug bolt holes.
        Perhaps it did no damage and everything is fine, but where it relates to wheels I'd rather be safe than sorry...
        d-
        DouglasABaker is offline
        Old 21st January 2008, 21:34   #12 (permalink)
        point taken and i agree, im getting a tool to open the centre hole up to fit !
        Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Add this post to your Facebook Profile
