Old 18th January 2008, 05:13   #11
myztikal47
Garage: 1996 328i Boston Green
Got it, I'll definitely be checking out the vehicle history first. Is there any place where I can check the recalls for each year? Thanks again everyone!
myztikal47 is offline
Old 18th January 2008, 06:40   #12
jclyman
jclyman's Avatar
There is a site on the Internet that lists ALL recalls. Search for it with Google.
Very, very few recalls on the E39 M5s.
- Daniel Boorstin
jclyman is offline
Old 20th January 2008, 05:18   #13
myztikal47
What do you guys think about this:
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
Old 20th January 2008, 05:38   #14
doug
doug's Avatar
Garage: 2003 Sterling Grey M5
Originally Posted by whatheheck View Post
In my case, it is not the repairs that cost me a lot of money, it is the mods and upgrades. It never ends!
Amen, to that... you guys are all a bad influence!
2003 M5 Sterling Grey/Black
V1/StealthOne
Ultimate Pedals Titanium
Factory Brake Duct Upgrade
Supersprint Cat-back race exhaust
UUC Evo 3 SSK/DSSR/Black Tranny Mounts
OEM 9.5" rims x 4 with 275/35ZR18 Pilot Sport PS2, racing metal value stems
OEM MP3-capable CD Changer, Bluetooth (12th Generation), Sirius Satellite radio, DVD Nav 2007.2
doug is offline
Old 20th January 2008, 06:09   #15
PAUL HUGHES
PAUL HUGHES's Avatar
Garage: 2001 M5 Lemans Blue
love the looks of the car! price looks reasonable, too.
figure on $2 - 4 grand for a clutch to be installed by a mechanic, depending on whether you want OEM or the big one that the car should have come with.
PAUL HUGHES is offline
Old 20th January 2008, 06:53   #16
iconoclast
Garage: M5
Sales Feedback: (10)
on the topic of maintenance, is there a pdf or link to what each service interval is and what each service entails?
iconoclast is offline
Old 20th January 2008, 07:29   #17
BMWMPWR
BMWMPWR's Avatar
Garage: Joji Nagashima designed BMW - I hope you know who this guy is!
Sales Feedback: (6)
BMW Inspection I
The BMW Inspection 1 Service is the smaller of the two inspection services recommended by BMW. It includes basically all of the items that assures safety and full functionality of your vehicle. Other makes and models can also utilize this maintenance program to ensure a pleasant drive and ownership (But make sure you mechanic says it is OK first). Inspection 1 could cost in the range of $200+ to $300+ depending on who you go to and also if you have any repairs. (Repair cost are not included in the inspection cost) So be prepared to spend more!. If your mechanical skills are high, just DO-It-Yourself! The items that are generally checked are listed below.
Undercarriage
  1. Change engine oil and filter oil while engine is at normal operation temperature.
  2. Check transmission for leaks.
  3. Check rear axle for leaks.
  4. Visually check fuel tank, lines, and connections for leaks.
  5. Check condition, position, and mounting of exhaust system. Examine for leaks.
  6. Check power steering system for leaks.
  7. Check overall thickness of front and rear disc brake pads.
  8. Examine brake disc surfaces.
  9. Clean brake pad contact points in calipers.
  10. Grease wheel center hubs.
  11. Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc.
  12. Check front control arm bushing for wear.
  13. Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning.
  14. Check for free movement of the parking brake cables. Adjust parking brake if necessary.
  15. Check all tire pressures (including spare). Correct if necessary.
  16. Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required.
Engine Compartment
  1. Read out diagnostic system
  2. Check engine cooling system/heater hose connections for leaks.
  3. Check coolant level and antifreeze protection level; add coolant if necessary.
  4. Check level of brake and clutch fluid in reservoir; add fluid if required.
  5. Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary.
  6. Check air conditioner for operation.
  7. Reset Service Indicator.
Body/Electrical Equipment
  1. Check battery electrolyte level and add distilled water if required.
  2. Perform batter load test.
  3. Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights.
  4. Check instrument panel and dashboard illumination.
  5. Check all warning/indicator lights, check control.
  6. Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch.
  7. Check wiper and washer system(s); wiper blades, washer jet positions.
  8. Check condition and function of safety belts.
  9. Oil hood, trunk/tailgate, and door hinges.
  10. Grease hood, trunk/tailgate and door latches. Check operation of all latches.
  11. Check central locking/double lock.
  12. Replace microfilter or Acc. Cabin Filter.
  13. Check heater/air conditioner blower, rear window defogger.
  14. Check rear view mirrors
  15. Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories.
Final Inspection
  1. Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
Inspection II
The Inspection 2 Service is the larger of the two Inspection Services and basically includes all of the items performed on the Inspection I Service along with some extras like differential oil change; fuel filter and air filter replacements; Replacement of spark plugs. Inspection 2 generally runs around $400+ to $500+. Below are the items that are normally performed.
Undercarriage
  17. Check thickness of parking brake linings.
  18. Half-shafts; check for leaks at flexible boots.
  19. Inspect entire body according to terms of rust prevention limited warranty.
Engine Compartment
  8. Replace spark plugs.
  9. Replace intake air cleaner element.
  12. Replace microfilter or Acc Cabin Filter.
Final Inspection
These are the recommended interval for models years from 1986 through 1998 models, more frequent inspections are essential if driven in extreme conditions:
5,000 miles - intermediate oil service (O/F)
10,000 miles - Oil and Safety Service (O/S)
15,000 miles - intermediate oil service (O/F)
20,000 miles - BMW Inspection I (I/1)
25,000 miles - intermediate oil service (O/F)
30,000 miles - Oil and Safety Service (O/S)
35,000 miles - intermediate oil service (O/F)
40,000 miles - BMW Inspection II (I/2)
45,000 miles - intermediate oil service (O/F)
50,000 miles - Oil and Safety Service (O/S)
55,000 miles - intermediate oil service (O/F)
60,000 miles - BMW Inspection I (I/1)
65,000 miles - intermediate oil service (O/F)
70,000 miles - Oil and Safety Service (O/S)
75,000 miles - intermediate oil service (O/F)
80,000 miles - BMW Inspection II (I/2)
85,000 miles - intermediate oil service (O/F)
90,000 miles - Oil and Safety Service (O/S)
95,000 miles - intermediate oil service (O/F)
For 1999 and later models, the recommended service/inspection intervals are as follows:
10,000 miles - intermediate oil service (O/F)
15,000 miles - Oil and Safety Service (O/S)
20,000 miles - intermediate oil service (O/F)
30,000 miles - BMW Inspection I (I/1)
40,000 miles - intermediate oil service (O/F)
45,000 miles - Oil and Safety Service (O/S)
50,000 miles - intermediate oil service (O/F)
60,000 miles - BMW Inspection II (I/2)
70,000 miles - intermediate oil service (O/F)
75,000 miles - Oil and Safety Service (O/S)
80,000 miles - intermediate oil service (O/F)
90,000 miles - BMW Inspection I (I/1)
100,000 miles - intermediate oil service (O/F)
Inspection I Service (I/1)
Inspection II Service (I/2)
Intermediate oil service (O/F)
Here is the link
I think the same information is given when you log into the BMW owner's circle.
BMWMPWR is offline
The Following User Says Thank You to BMWMPWR For This Useful Post:
ickyfehmleh (14th December 2008)
Old 20th January 2008, 07:39   #18
Laidback
Garage: Camaro lol:)
Sales Feedback: (25)
+1...
"Illegitimus non carborundum"
Laidback is offline
Old 20th January 2008, 07:53   #19
iconoclast
Garage: M5
Originally Posted by BMWMPWR View Post
Here is the link
thank you, i appreciate it...
Old 20th January 2008, 09:47   #20
myztikal47
The clutch wouldn't be changed out under warranty?
Vanos issues (long rant) mokushiroku E39 M5 and E52 Z8 Discussion 73 25th April 2008 01:10
DON'T buy this car! Back stabber!!! TireFryer E34 M5 Discussion 44 27th October 2006 01:02
Opinions on Full Leather? drewzMMM E60 M5 and E61 M5 Touring Discussion 54 13th March 2006 01:22
Question: What's the worst sales tactics you've been through for new car sales? GradX GTBoard.com: General Sportscars 42 28th March 2003 04:37
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Page generated in 0.30512 seconds with 11 queries
