Old 13th January 2008, 00:54   #1
jcdavis
Garage: '00 M5, '98 540i-6, '04 K1200RS,
Where are the throttle bodies and how to clean
I have done a search and I cannot find anything showing where the throttle bodies are or how to clean them. I have read about people cleaning them and getting good results, but they don't tell how they did it. Any help would be appreciated.
Jeff
jcdavis is offline
Old 13th January 2008, 01:00   #2
E55AMG2
E55AMG2's Avatar
Under the intake plenum, they've got runners bolted to each one, and dont bother...you're wasting your time.
E55AMG2 is offline
Old 13th January 2008, 01:13   #3
Jasoncrx
Garage: 2000 M5 - Carbon Black
Try cleaning your MAF's, thats probably what they are referring to.
Jason
National Sales Manager - FastCo USA
www.fastcousa.com
Jasoncrx is offline
Old 13th January 2008, 01:31   #4
Panos
Panos's Avatar
Garage: 1999 540i 6-speed Biarritz Blue/Sand Beige
If you have less than 60k miles on the car and you use good fuel, than dont bother cleaning the throttle bodies. I cleaned mine on my 540i around 90k miles and it was a bit dirty on the outside of the throttle plate. DO NOT DROP ANYTHING PAST THE THROTTLE BODY. Otherwise you will be disassembling the engine to get it.
Panos
1999 540i.6 Biarritz Blue/Sand-Beige
M5 Grills, 17" Staggered Radial Spoke Style 32 Wheels, M5 Rear Stabilizer Bar, Rogue Transmission Mounts, Rogue Short Shifter & Wieghted Selector Rod, CDV Deleted, Stop Tech Stainless Steel Lines, Dinan Engine Software, Bluetooth Telephone, Valentine One Radar/Laser Detector, StealthOne Interface, Debadged.
R. I. P.
2002 M5 Carbon Black/Caramel
Retired: 1997 540iA, 1994 540iA
Panos is offline
Old 13th January 2008, 01:47   #5
rneedham1979
Banned
rneedham1979's Avatar
Garage: 2005 4.8IS, 2000 STOCK M5
you can clean your throttle bodies. I just did because as everyone knows these cars have a weak crankcase ventilation so it allows oil to build up in the intake plenum and on the throttle bodies. Just remove the upper intake plenum and the velocity stacks. once you remove them just spray the throttle blades down. just keep in mind that you may have a slightly difficult time starting the car once its all back together.
Hope this helps
Ryan
rneedham1979 is offline
Old 13th January 2008, 14:52   #6
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Hope this helps
Ryan
I assume you spray with something like carb cleaner. Any reason you cannot spray into a running engine??
gsfent is offline
Old 13th January 2008, 19:16   #7
rneedham1979
Banned
Yes you use a carb or throttle body cleaner. If you start the car with the plenum off you will be running with un-metered air (no maf). You will most likely throw a code and I am pretty sure it will not run very good at all and i do not think yo will be able to keep it running when you spray the blades even by applying throttle. I'm sure it can be done but I didn't and wouldn't bother doing it while it was running.
Ryan
Old 13th January 2008, 22:08   #8
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
Be sure to use a cleaner made for Fuel Injected engines.
I've heard that the throttle bodies have a coating on them that normal carb spray can eat away.
If the throttle body is dirty, just imagine how the inside is.
Has anyone tried Seafoam on our cars?
Has anyone tried cleaning out the Oil Separators on our cars?
John Baas
2001 Anthracite Metallic M5
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Old 14th January 2008, 01:49   #9
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
Someone did have a cut view of the oil separators(tornado valve), its just a couple baffles.
Seafoam is used by a couple to help carbon build up(do a search), its basicly Naphtha and a pale oil blend. I have been using Berryman 0116 which is toluene,acetone,methanol,MEK, isopropanol and it has been working great for years.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline
Old 14th January 2008, 02:50   #10
xr4tic
xr4tic's Avatar
interesting, I did a search, found the link with the cutaways
http://www.m5board.com/vbulletin/sho...74#post1115674
I figured there would be some sort of stainless mesh inside to help trap the oil, but I guess not. I wonder if going to an aftermarket catch can (a proper one, with baffles) would help any.
John Baas
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Page generated in 0.16809 seconds with 10 queries
