Old 24th November 2001, 04:25   #1
RAREM5
RAREM5's Avatar
Garage: 2001 DINAN M5
Send a message via AIM to RAREM5
Clutch regulator?
Gentlemen,
Does anyone know anything about removing clutch regulator? I hear that removing the regulator makes the clutch engages "quicker" Is this true and safe?
Should I do this or not? I don't want to harm my clutch since the clutch is the weakest link in M5.
Thanks in advance,
Rare M5
RARE ///M5
2001 LMB DINAN ///M5 Gone but never forgotten!
2005 Honda S2000 (Silverstone/Black)
2005 Ducati 749S (Red)
RAREM5 is offline
Old 24th November 2001, 06:22   #2
AMP
AMP's Avatar
Garage: '08 M5 - Silverstone
Are you referring to the Clutch Delay Valve? This little wonder made my 540/6 most unpleasant... The good news is that yhe M5 doesn't have one
'08 M5 Sedan Silverstone/Black
'07 M6 Coupe Silverstone/Black (gone)
'07 Z4 M Coupe Sapphire Black/Black (gone)
'06 330i Sapphire Black/Black
'03 M5 Sedan Imola Red/Black
'93 M5 Sedan (3.6) Sterling Silver/Black
AMP is offline
Old 25th November 2001, 21:06   #3
RAREM5
RAREM5's Avatar
Yes
Amp,
Yes, Clutch Delay Valve... I hear that if you remove it then you can shift "faster"? What's the catch? Are you sure about M5 not having one? Someone (who has M5) told me to remove it. Maybe called something else?
Thanks in advance
RARE ///M5
RAREM5 is offline
Old 25th November 2001, 21:55   #4
AMP
AMP's Avatar
Hi RAREM5
The whole point of the CDV was to slow the flow of hydraulic fluid into the clutch master cylinder to a constant rate. This would make the clutch engagement more predictable and reduce driveline shock due to dropping the clutch (no matter how fast you release the pedal the clutch plate engages at a contant rate).
In theory it sounds good... the problem is that most people who buy $50K+ sport sedans actually know how to drive a manual and end up fighting with the clutch when trying to modulate on a launch. In general it makes the car hard to drive and increases the amount of slip on the clutch.
Fortunately this little deamon only made its way into the 540 & 530. I've confirmed (via the parts CD) that the M5 doesn't have one. Once I have my M5 (looking like it will arrive sometime between 12/24 & 12/26 I'll confirm in person. If you would like to crawl under your car to verify yourself checkout the Tips & Tricks section of www.bmwtips.com for some pictures of what the CDV looks like.
Have fun!
-Andrew
AMP is offline
Old 25th November 2001, 22:04   #5
RAREM5
RAREM5's Avatar
Hi Amp,
Thanks for your reply and links to the www.bmwtips.com. It looks to complicated for me and I will take your word for it. I'm going to leave the beast as is for now.
Thanks again,
Rare M5
RARE ///M5
RAREM5 is offline
Im back! -- with a clutch story.... 1C00lVC E39 M5 and E52 Z8 Discussion 5 9th June 2003 23:33
TECH: those w/ non-original clutch --> light clutch pedal? Teutonaddict E39 M5 and E52 Z8 Discussion 0 31st July 2002 20:44
TECH: attention, clutch afficianados.... Teutonaddict E39 M5 and E52 Z8 Discussion 16 13th May 2002 06:01
Front Brake inner Cooling Ducts & TRACK CAM. Installed M5@ksa E39 M5 and E52 Z8 Discussion 7 10th April 2002 05:34
Once again: Anyone with an aftermarket clutch? Ilya Zverev E39 M5 and E52 Z8 Discussion 16 20th September 2001 04:23
Page generated in 0.16094 seconds with 11 queries
