Old 22nd November 2001, 08:04   #1
gmajor
gmajor's Avatar
Garage: e39 M5 Carbon Black
AP Racing front brake kit
AP Racing in England now have a kit for the e39 M5's front brakes, retaining the standard wheels. It was not advertised on their web site when I checked just now.
You get 6 pot calipers, DOT5.1 fluid, braided lines to the calipers, pads, and 343mm x 32mm radially grooved, vented discs. These discs have the same diameter as the standard floaters, as the BMW wheels do not have much space on the inside: get roomier wheels and you could go to 362mm I think. The calipers are big, allowing the pads to be usefully bigger than standard.
The splash plate needs a bit of cutting on its trailing edge to allow the caliper bracket to fit, and I've bent the leading edge inwards to funnel more air from the venturi under the bumper in to the disc centre. Opening the proper cooling ducts will be a good idea too.
I've got Ferodo's new fast road pad (cannot remember number), which does work from cold, and there are other pads available. When I can test again, I'll report on the fade characterstic.
geoffrey
2001 e39 M5 Carbon Black/Black
gmajor is offline
Old 22nd November 2001, 10:59   #2
Black B10V8
Black B10V8's Avatar
Garage: Alpina B12 6.0L 2001 Black
Interesting. A few questions:
Do the calipers clear the stock rims (what rims do you use?) or do you need to fit a spacer? If so, how wide?
Price?
Black B10V8 is offline
Old 22nd November 2001, 11:25   #3
gmajor
gmajor's Avatar
There's no spacer and it fits the standard rims. If you had rims with more space inside the spokes you could get a bigger disc in.
I think the retail price is something like GBP1,500 + VAT.
gmajor is offline
Old 22nd November 2001, 12:50   #4
Rallistas
Rallistas's Avatar
Garage: 2000 M5 Lemans Blue
I e-mail them and they told and is what they told me.
The Bmw E39 M5 front brake upgrade will be availbable late December. It will consist of a 6-piston calipers and mounting breackets coupled to a 343x32mm 48vane disc bolted to an alloy bell, Braided hoses and bast road/track pads. The standard Msport 18 alloy can be retained. This set up will restrict the size of the disc used due to the STD wheel radius and spoke offset. Therefore with the disc at a similar size to STD, piston area s;ifhtly increased in the 6-pot calipers and an increse in a pad area it is felt the the BMW brake will be sufficient to work with this front upgrade. Retail Approx. 1600 + vat.
CP555 is the caliper type to look at our own web site.
The next development will be a bigger disc of 355x36 version requiring and AFtermarket 19" rim with adequate spoke depth. We will then look at producing a small bore 4-pot caliper to mount over the standard disc/ drum installation. Available possibly late February. Front Apprx 1600 rear 750, it will include fittings, hoses and pads with the calipers.
2000 Lemans Blue
Kelleners Exhaust, Ecu Tuning, Sport Cats, Sport Suspension & Pedals, Custom done CAI, Brake Ducts, Dinan Front & Rear Stress Bars
Rallistas is offline
Old 22nd November 2001, 13:06   #5
bobafett
bobafett's Avatar
Send a message via ICQ to bobafett
Our very own Basil has had the AP racing kit for almost two years now if I'm not mistaken.
--Dan
bobafett is offline
StopTech E39 4-Wheel brake kit details DZeckhausen E39 M5 and E52 Z8 Discussion 26 20th March 2003 07:11
AP Racing Brake 06 Pistons Kit for m5 e34 munhoz E34 M5 Discussion 2 25th February 2002 14:17
Movit/Porsche front brake kit 01M5 For Sale or Wanted 3 2nd December 2001 04:12
Safety (@ +200km/h, brake kit, etc.) Rodrigo Martinez E34 M5 Discussion 1 11th August 2000 15:16
Page generated in 0.12723 seconds with 11 queries
