If you had it and beat it, what have you done to fix it?
Well I've not had it, but the Peake reader book says "Intake camshaft VANOS position control, cyl 1-4". This sounds like a defective CPS to me. From my readings on the board, it seems that CPS failures are common.
"B" and "8" can look alike from what I remember. Make sure it's an alpha character and not a numeric character (or vice-versa) - could send you on a goose chase.
This is the thing that really sucks about the Peake - the display is hard to read, and the lookup book is poorly organized. It must be made by Microsoft...
Maybe its just me, but I dont think its poorly organized. First, you get a table, and then a code. And even if there is b8, there is no 68, so confusion is nearly impossible. At least thats how it was when I got codes. Whipped out the book and found them right away. while the tool was still plugged in.
Behind the Matte Black Kidneys: Active Autowerke Cold Air Intake, Super Sprint Exhaust & X-Pipe from ModBargins, Dinan SSK, Dinan Software, Dinan Lightweight Flywheel.
Modifying and Improving Creature Comforts & Driver Aides: Valentine 1 with Jaric Designs Stealth One, Defi VSD X Heads Up Display, Z8 Engine Start Button, TEC Cup holder, Polk Audio Tweeters, MB Quart Mids, Twin JL Audio 10w3v2's with center port through skipass, Alpine PDX4.100 and PDX 1.600. DVD player with Video Module, Rear Backup Camera and dual 7" head rest monitors along with Intravee for iPod via 2point5 specdoc. Stoptech Big Brake Kit, centric Posi-Quiet Semi-Metallic Brake Pads from Zeckhausen Racing and TC Design Rear Sway Bar Brackets.
Working towards Pure Aesthetics: Hella Euro Clear Headlights with Upgraded 6000K D2S HID Low Beams protected with Lamin-X Headlight & Foglight Protective Film ALL from üm•nitza, Predator ICE Angel Eyes w/K2 LED Mods, 3000K Yellow HID Fog Light kit rolling on Ground Control Coil Overs on a set of Cargraphic 19x9 & 19x10 3 piece forged wheels wrapped in 255.35.19 & 285.30.19 Michelin PS2.
When you turn your car on, does it return the favor? -
I changed all CPS's myself. I still have the b8 come up on my peake reader. I have a hammering noise coming from the area, which is very scary.
I have ordered a vanos solenoid and I hope that should do the trick. I am getting the parts from pelican, but am expecting a minor delay due to xmas.
Good luck with your car, and pleaase post when you get the problem solved, I will definately keep you posted when my fix is completed.
Norm.
