Old 21st December 2007, 17:49   #1
Osodog
Osodog's Avatar
Garage: M5
No low ambient temperature warning
For some reason, in the last 2 weeks my 01 M5 is no longer giving me the low temp warning. The temp reading seems to be fine (car registered 36 and my outside home thermometer registered 34). No other codes, car running fine. Just no bing when it gets below 37 and then 32 I think. Thoughts?
Osodog is offline
Old 21st December 2007, 18:46   #2
jclyman
jclyman's Avatar
NORMALLY, a "beep" at 37 degrees but NOT at 32.
Do any of the other "buzzers" work? (i.e., the exceed Speed Limit, the Memo) I suppose you could have blown a fuse for the sound ... but, I am not into "fuses." There is also a console test for "gong" ... you might try it to see if you can hear all of them. (NOT sure how many there are, but that's one I would check.)
Good luck, I think electrical gremlins are the absolute worst to track down ...
- Daniel Boorstin
jclyman is offline
Old 21st December 2007, 23:36   #3
Osodog
Osodog's Avatar
Garage: M5
The speed alarm went off fine...oh well...here in CA, its pretty easy to tell when its 37. Anything below 50 its heavy coat time.
Osodog is offline
Old 22nd December 2007, 00:38   #4
jclyman
jclyman's Avatar
Heavy coats, what are they ??? Heck, I pump gas in the snow with my walking shorts on ... all the time ... Well when I go to Idaho ...
- Daniel Boorstin
jclyman is offline
Old 22nd December 2007, 01:18   #5
Osodog
Osodog's Avatar
Garage: M5
I grew up in Hawaii, what do you expect
Osodog is offline
Low fuel warning drives me crazy! Radioman E60 M5 and E61 M5 Touring Discussion 33 29th February 2008 01:45
low oil warning during break-in period ! Black M5 E60 M5 and E61 M5 Touring Discussion 20 27th October 2006 16:49
Feedback on "speed limit exceeded" warning? M-POWER 77 E60 M5 and E61 M5 Touring Discussion 13 19th September 2006 01:47
Low Oil Level Warning?!? Help! Venom77 E60 M5 and E61 M5 Touring Discussion 5 20th June 2006 00:40
tire defect warning SteveM5NC E39 M5 and E52 Z8 Discussion 15 28th August 2001 01:53
Page generated in 0.11024 seconds with 11 queries
