Old 21st December 2007, 16:00   #1
Lscman
Garage: E39
Dinan Swaybar adjustment strategies
As I discussed Dinan swaybar settings at Mid Ohio with Irish m5 something occurred to me....
Anyone ever consider using an uneven left and right position setting on the rear adjustable bar? This is effectively done all the time in Pro SCCA Racing thru one cockpit tuneable end arm on the right or left. The bar ends do not need to be balanced for any reason, so this works great. The swaybar torque spring applies equal and opposing force to both control arms under all conditions, even if the ends are different lengths (rxF). This is because a swaybar is free-floating (swivels freely on the frame mounts).
This would seem to effectively offer a 1.5 and 2.5 setting which folks occasionally mention they wish they had:
1 to 1
2 to 2
3 to 3
1 to 2 = 1.5
2 to 3 = 2.5
Resolve never, screw genuine.
Lscman is offline
The Following User Says Thank You to Lscman For This Useful Post:
M5 London (9th October 2009)
Old 21st December 2007, 18:44   #2
E55AMG2
E55AMG2's Avatar
I leave mine on the middle setting, any tighter and my car is undrivable, but that is due to my having coilovers
E55AMG2 is offline
Old 21st December 2007, 18:56   #3
iconoclast
Garage: M5
Sales Feedback: (10)
iconoclast is offline
Old 21st December 2007, 22:24   #4
Redshift
Redshift's Avatar
Garage: 01 M5 / 02 330Cic / 03 540iT / 94 M3
Sales Feedback: (11)
Interesting idea. I have both cars (540 and M5) set to max oversteer, but lately have been considering going back to the middle setting, to see how it would affect the feel. Let us know if you try this uneven setup and if it works for you.
Brian - CCA #273611
Tarheel BMW CCA Street Survival Chief Instructor
03 540iT Sapphire Black - 01 M5 LeMans Blue - 02 330Cic Orient Blue - 94 M3 w/S50B32 Imola Red 08 F800ST Blue
*** Parting out entire 03 CB/Imola/Black M5 *** - TONS OF PARTS AVAILABLE
Redshift is offline
Old 22nd December 2007, 04:07   #5
drallen
drallen's Avatar
Garage: M5 Jet Black
You have not been happy with the inside hole?...IIRC you and I were the early adapters on our GC shocks...I am now running the #430s up front and the #280s (pain in the arse to change them) in the back (14.5" F/14"R)...am I wrong in thinking that if I add more bar to my rear end that it will help me more in my lateral stability in the turns?...Sometimes I bottom out on the bumpstops and get a little squirrelly...I was thinking of adding more bar to help this with out changing the springs...any thoughts on this?
Thanks,
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman rear differential with changed static and dynamic lock up, stock ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
Jet Black 2002 M5
drallen is offline
Old 22nd December 2007, 05:32   #6
khiroshima
khiroshima's Avatar
Garage: 2001 M5 silver
I guess this might make sense if I only made right (or left) hand turns, seems you would want to optimize for a variety of conditions rather than just one since this is a road vehicle-- JMO, KH
khiroshima is offline
Old 22nd December 2007, 06:24   #7
E55AMG2
E55AMG2's Avatar
more bar in the rear = more bump steer in the rear. More stability = understeer.
E55AMG2 is offline
Old 23rd December 2007, 06:37   #8
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
You can have uneven settings and it will have the same effect on any turn. All you are doing, essentially, is adjusting the torsional stiffness of the bar. they don't have to be even.
I'm pretty pleased with them at the middle setting on both, but haven't been to the track in a while. Used to run 275/285, with the slight stagger, the middle hole was good for me. Now running 275 x4, so maybe i'll back one side off to the softer setting, if the car feels twitchy or loose at the next track event. It's fine as is on the street.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 23rd December 2007, 06:39   #9
mottati
mottati's Avatar
Thanks,
Mark
Mark, are you thinking if you add more torsional stiffness to the bar, it will be like increasing the effective spring rate at the rear? Not sure if that will work, would think it would just make the rear looser, as if you made the rear shocks stiffer.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 23rd December 2007, 07:32   #10
Lscman
Garage: E39
As was explained, uneven setting on right and left swaybar link connection does not result in uneven torque or force applied for right and left turns. The car will behave EXACTLY the same making right and left turns under any conditions. A swaybar does not behave like a torsion bar spring attached to the chassis, where the right and left side must be precisely matched for balanced handling. Don't confuse a spring with a swaybar. A swaybar does not need to be symmetrical R->L to perform properly. This unconventional swaybar adjustment strategy simply offers two extra (perfectly balanced) settings for fine tuning, in addition to the standard 3.
Lscman is offline
Dinan and other Parts Feeler E39 M5 S2 Part Out? mishkinm5 For Sale or Wanted 54 2nd February 2009 20:13
No more Dinan theresajc E39 M5 and E52 Z8 Discussion 34 20th November 2007 07:24
Powerchip vs. Dinan Stage 5 Software pmarin E39 M5 and E52 Z8 Discussion 25 4th January 2005 18:11
Dinan Swaybar Kelvin E39 M5 and E52 Z8 Discussion 2 8th May 2000 03:14
Page generated in 0.13146 seconds with 11 queries
