the dinan velocity stacks do fit without the spacer. I have the stacks and larger throttle bodies, but no spacer (dinan d/c'd the spacer long ago). What kind of velocity stacks are you using that don't fit? If they're dinan, somthing is not right.
I'd either call the seller if parts are missing, or call dinan.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
