Old 21st December 2007, 12:58   #1
rassi
rassi's Avatar
Garage: '02 BMW M5 (Carbon black / black leather)
Coolant temperature: Thermostat open?
Noticed that the coolant temperature gauge is sitting at the first 1/4 mark, while in the summer it was just to the left of the 1/2 mark. Oil temperature is per normal, just under the 100 degree C mark (212 F) just a bit left of the middle).
The cabin warms up quickly, but I would be happier if the coolant gauge was closer to the 1/2 mark. The digital readout gives me a coolant temperature of 75-77 degrees C (170 Fahrenheit), with an ambient temperature of -5 degrees C (23 F) and cruising on the motorway.
As per some other threads the culprit could be the thermostat that is stuck open, but would appreciate if anyone else could give me some references for what their temperature is (the readout).
Thanks!
Anders
Stock apart from Eisenmann Sport, E60 545 short shifter mod, MKIV nav and Intravee II
ex '01 BMW 530D Touring (Sterling grey / beige leather)
ex '98 Mercedes C43 T AMG (Smaragd schwarz / black leather)
ex '99 BMW M Coupé (Cosmos black/ black-kyalami leather)
ex '93 Alfa Romeo 164 24V Super (Silver / black leather)
rassi is offline
Old 21st December 2007, 15:21   #2
TopEnd
TopEnd's Avatar
Garage: 2005 M.Benz E55 AMG
With my experience working on other automobiles. The thermostat would be the culprit. However it hasn't happened to me in the M5 as yet....
TopEnd is offline
Old 22nd December 2007, 01:33   #3
nerio02
nerio02's Avatar
Garage: m5 e39 ROYAL RED
i just got my car back rassi from the stealer after a termostat replacement last monday and mine is now a little under the middle. its minus 4°c for now , i think its just the weather thats doing it.
iff you stand still does the temperature rise up to the middle??..iff so i'd guess its the weather ,they say its going to be better by sunday, maybe wait a other few days,
iff you want a estimated price for a replacement by the stealer, mine was 385 euro+btw.they replaced termostat housing 118euro+btw,termostat 88euro+btw,coolant 12euro+btw and termostat sensor15 euro+btw and the rest is workfee/1,5 hours.
mine was stuck on 1/4 open so the car always overheated. maybe yours is 3/4 stuck open . could be a possibility like you say.
strange whe both have this now it bigins to get a bit colder.anyway hope you find the problem
with kind regardes
nerio02/dominique
nerio02 is offline
Old 22nd December 2007, 01:46   #4
captainsin
captainsin's Avatar
Garage: 2001 M5 Jet Black/Caramel
It should be at the half way point. Even though the air temp is cold, the fire inside the engine is still the same temp. It may take a little longer to warm up, but the whole point of the thermostat is to get your temp up to that point.
captainsin is offline
Old 22nd December 2007, 01:59   #5
nerio02
nerio02's Avatar
hehe yeah thats true, i dident drive more then 20 km with the car up and from work, so it maybe it doesn't warms up that fast nowadays from the cold. i have to drive it longer to check it out
with kind regardes
nerio02/dominique
nerio02 is offline
Old 22nd December 2007, 02:03   #6
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
If it gets to the 1/4 mark quickly, then your thermostat is likely fine. If it takes a long time to get there, then it is probably stuck open.
The symptoms of an open thermostat are usually long time to warm up, but typically not any change in overall engine operating temperature.
I suspect you might have a faulty sending unit...
Doug
DouglasABaker is online now
Old 22nd December 2007, 02:54   #7
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
My temp needle often sits below half way on cool days, or easy highway runs. Best way to check temps is to check the OBC. From memory, test #7 is water, #16 is oil. I typically see somewhere around 80 C.
gsfent is offline
Old 22nd December 2007, 08:06   #8
rneedham1979
Banned
rneedham1979's Avatar
Garage: 2005 4.8IS, 2000 STOCK M5
usually if the thermostat is bad you will get a code. it still could be bad though and it is an easy change so give it a try,
Ryan
rneedham1979 is offline
Old 15th April 2008, 13:37   #9
Terabass
Terabass's Avatar
Garage: M5 Black
Just got an M5...so new to this. 55 miles
Engine runs a little cold-- little before halfway on thermostat (it's about 50 F outside) and then the heater is not fully heating, even at 90 F i'm not getting a blast furnace.
What I really notice is that at the air ducts in the middle are sending cool air out, the air ducts to the feet are sending war air and the air ducts to the window are sending warm air.
What could cuase this ? let me know plz if you got any ideas
Terabass is offline
Old 15th April 2008, 15:02   #10
Fuddy
Fuddy's Avatar
Garage: Silver E39 M5
have you turned the temp control wheel to the red marks... ? it's in the center of the middle air ducts...
Fuddy is offline
Engine coolant temperature, Plausibility KevN23 E39 M5 and E52 Z8 Discussion 72 10th October 2009 03:17
Engine coolant temperature, plausibility felip E39 M5 and E52 Z8 Discussion 32 23rd July 2009 01:24
Winter Protection - Antifreeze & Similar? IvanDias E34 M5 Discussion 25 16th February 2006 20:16
? coolant temp gauge mottati E39 M5 and E52 Z8 Discussion 4 18th December 2003 04:32
Open Air Filters m5 rus E39 M5 and E52 Z8 Discussion 1 5th November 2003 16:56
Page generated in 0.17850 seconds with 11 queries
