Old 20th December 2007, 02:39   #1
JAKPAK
JAKPAK's Avatar
Garage: 2000 M5...Silver
Peake Codes...Help!
I am the new owner of a 2000. I bought it with 57,500 and put about 1,000 on it in the last few months. Today I had the SES light turn on; I used the Peake Reader and was given the following codes:
Chart 18:
Code AE
Code b2
From what I've read, AE means Air-Fuel Adaptation, Cyl #1-4, and b2 means Catalyst system efficiency, cyl # 1-4
Can anyone help me with what the problem may be?...anyone have experience with these codes? And, if so, how much did it cost to fix?
Thanks for your help!
JAKPAK is offline
Old 20th December 2007, 03:17   #2
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
B2 sounds like an O2 sensor.
AE I just don't know...
d-
DouglasABaker is offline
Old 20th December 2007, 03:55   #3
drfv
drfv's Avatar
Garage: m5 carbon black metallic
both could be possible result of a misfire iirc.
Dave (babalu)
2001 m5 carbon black
2001 s40i topaz blue metallic
drfv is offline
Old 20th December 2007, 08:16   #4
gherardini
gherardini's Avatar
Garage: 2002 M5 Titanium Silver
Sales Feedback: (5)
Send a message via ICQ to gherardini Send a message via Yahoo to gherardini
there's a sticky post here...
Knowledge base on Peake codes for E39 M5
that we are trying to keep all the peake codes listed in. check there, list yours and add to our online "database" of knowledge.
'02 M5 TiSi-SBI [Sexy Black Interior] - "Audrey"
BMWMOA iBMWr IBA#7268 LPR#71 SEAT#17
- Valentine1 - hardwired
- StealthOne
- SS Exhaust
- GrafxWerks ///M5 Lighted Door Sills, all 4 doors
- Hella Euro clear corner headlights
- Steath Auto Turn Signal Bulbs
- Predator ICE v2.1
- Xenon fog lights
- CNS Racing clutch
- TC Designs Sway Bar Brackets
'87 K75S - "Maybellene"
'00 R1100S - "Tresor!"
Sierra Vista, AZ
gherardini is offline
Old 20th December 2007, 11:48   #5
RoundelM5
RoundelM5's Avatar
Garage: 2003 M5 - LeMans Blue
Sales Feedback: (8)
b2 can also be thrown by exhaust leak (at least it was for me) - which may be the culprit if you have an aftermarket exhaust...or a bad cat - though I doubt it at less than 60K miles
'03 Lemans Blue/Black
Dinan: Stage 3/Koni suspension, Stage 2 software, 3.45 differential, LTW wheels, LTW flywheel, strut bar
Stoptech 4-wheel BBK
AA CAI and brake ducts
Tubi Regular exhaust
Rogue Engineering SSK w/ WSR
AngeliBright v2.0 w/ matching fogs and highbeams
TC Design Rear Swaybar Brackets
BMW Bluetooth, Sirius, First Aid Kit
RoundelM5 is offline
Old 20th December 2007, 14:47   #6
JAKPAK
JAKPAK's Avatar
Thanks for the replies. As a new owner there are a couple of things that I have noticed, that I just assumed were unique to the M5. For example, I have noticed that the smell of exhaust is very strong when starting cold. In addition, when starting cold I have noticed that for about a minute, while warming up, the engine mildly idles up and down. Are these cause for concern?...possibly connected to the codes?
Thanks again!
JAKPAK is offline
Old 20th December 2007, 15:21   #7
DouglasABaker
The idle hunt is normal...
I don't specifically recall noticing that my M5's exhaust is any stinkier than any other vehicle I've ever owned...
d-
Old 20th December 2007, 17:24   #8
JAKPAK
JAKPAK's Avatar
Thanks Doug!
Anyone else ever have these codes? Thanks!
JAKPAK is offline
Old 21st December 2007, 04:59   #9
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
d-
Interesting. Mine is rock steady, just elevated when (what passes for) cold here in south Florida. About 1100, then settles down to 600. Checked MAF's?
gsfent is offline
Old 21st December 2007, 05:22   #10
emccallum
emccallum's Avatar
Garage: 2001 m5, 2003 525it
you may want to reset the codes and see what comes back first....as said earlier O2 seems to ring a bell as b2. I do recall teh first time I used my Peake I had a hard time figuring out the tables. If it turns out to be an O2 just replace both precats..thats what I did around 40K
emccallum is offline
Knowledge base on Peake codes for E39 M5 kees E39 M5 and E52 Z8 Discussion 322 30th October 2009 02:51
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
Lumpy idle,SES, then PEAKE codes 90 and 91 Michael William E39 M5 and E52 Z8 Discussion 2 30th March 2007 18:09
Peake Codes Question SeeSure E39 M5 and E52 Z8 Discussion 8 26th January 2007 21:08
Peake Tool and Resetting Fault codes QUESTION SACM5 E39 M5 and E52 Z8 Discussion 2 15th April 2005 19:13
Page generated in 0.15972 seconds with 11 queries
