Old 20th December 2007, 00:24   #1
TedM5
Garage: E39 Blue
Correct Bleeding on coolant system?
Hi Guys
Wondering about proper procedure for bleeding coolant system after replacing radiator?
Fellow member sent me some info regarding hidden bleed screw around one of the pollen filters which wasnt on my car, Its a 2001 model.
Many thanks in advance
and a happy Christmas as we say in this part of the world!
TedM5 is offline
Old 21st December 2007, 03:45   #2
nerio02
nerio02's Avatar
Garage: m5 e39 ROYAL RED
yeah the hidden screw is for cars with a seperate heatersystem, dieselcars most off the time(night heater that runs on fuel)we(m5) dont have that i think.but not sure.
normally you just turn on the heater on slowest function. open the radiator and fill it with liquid up to 5 mm above max coolant on the radiator, then close it and run the car to optimal temperature. then let it cool down and look if the water is lowered,iff so ,refill again to 5mm above max and do it all over again. thats what stands in bmw TIS.
hope this helps a bit,
with kind regardes
nerio02/dominique
nerio02 is offline
Old 21st December 2007, 19:51   #3
TedM5
Garage: E39 Blue
Thanks for that have a go at this tommorow, heard horror stories before about Bmw not being bleeeded after a fill of water or coolant blowing heads etc.
Regards
Ed
TedM5 is offline
Carbon buildup FAQ (summary) wilsodh E39 M5 and E52 Z8 Discussion 115 28th August 2009 01:29
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
Feedback on coolant flush techniques? PRAXXUS E34 M5 Discussion 5 9th January 2007 23:57
Key Fob Issue - you too? MAH E39 M5 and E52 Z8 Discussion 15 11th February 2005 21:35
Page generated in 0.11822 seconds with 11 queries
