Down... as the outside comes in from the top an thru the filter as it comes out the other side, the air flows to the large duct opposite the fender side and on to the fan/cabin.
There are no dumb questions...
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
I'm going to say UP. On my car, the arrow is pointing up, and the bottom side is dirty, leaf particles etc.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
if the cleaned air flows to the snorkels which leads to the cabin, then the air flow must be UP as the the filters sits BELOW the snorkels. My guess...
Normally I'd go look, but the inch of ice on my hood prevents it.
In any case, look at the round tube going to the firewall - that is the "out" from the box. The arrow should be pointing to the space that feeds that tube.
you are correct. (i am too :p , i checked before i replied).
Now I need to look.... I had spent two days bleeding the clutch and brakes, the reservoir is below the filter assy. I stand corrected!!! The dirty side of the filter is to the bottom side, also the water drain is on that side too. Clean air side is up.
