• Latest threads
    • Custom feed
      • Updates
        Old 17th December 2007, 20:15   #1 (permalink)
        iconoclast
        photos of stock airbox...
        does anyone on here have photos of the stock airbox??? secondly photos of the baffles that ppl remove??? ive read in the archives, that some members have removed 'trumpet' and or 'baffle' from the airbox. i am curious, where are these items located?
        iconoclast is offline
        Old 17th December 2007, 20:28   #2 (permalink)
        azaytsev
        azaytsev's Avatar
        under the front bumper
        azaytsev is offline
        Old 17th December 2007, 20:40   #3 (permalink)
        iconoclast
        the items above and behind the lic. plate to the right and left???
        Old 17th December 2007, 20:44   #4 (permalink)
        azaytsev
        azaytsev's Avatar
        that doesn't look stock. some kind of DIY cold "home depot" intake
        azaytsev is offline
        Old 17th December 2007, 20:46   #5 (permalink)
        iconoclast
        i meant these:
        ^there are usually panels over that... these are the baffles ppl discuss removing? where are the 'trumpets' located? (not velocity stacks, but read that theres a plastic trumpet on or in the airbox???)
        Old 17th December 2007, 20:58   #6 (permalink)
        azaytsev
        azaytsev's Avatar
        $20 CAI + Brake Ducts
        first post, 2 and 3 pictures
        azaytsev is offline
        Old 17th December 2007, 21:15   #7 (permalink)
        iconoclast
        thank you...
        for some reason i was picturing ppl doing this: (has anyone done this?)
        and the 'trumpet' being something like this:
        Old 18th December 2007, 02:18   #8 (permalink)
        iconoclast
        mention of 'trumpets'
        took out airbox trumpets
        Old 18th December 2007, 03:05   #9 (permalink)
        DouglasABaker
        DouglasABaker's Avatar
        There is a "trumpet" right inside the stock airbox that is supposed to diffuse the air over the entire filter. It is a detachable piece that sits over the opening from the inlet pipe.
        The baffles are the ones indicated in your picture, but I believe the final resolution was that they were intended to remain there on the M5 even though removal seems to help on other 5's.
        d-
        DouglasABaker is offline
        Old 18th December 2007, 03:13   #10 (permalink)
        iconoclast
        I KNEW I COULD COUNT ON YOU~!
        are there any benefits of removing this piece??? secondly, has anyone around these parts done the drilled holes in the intake or is the favourable intake mod the sinkdrain, and or kit from vendor?
        Old 18th December 2007, 03:58   #11 (permalink)
        DouglasABaker
        The only benefit I can see to removing the trumpet would be that it wouldn't fall out any more while re-installing the cover. From a horsepower / effectiveness perspective, I see no reason why it would matter...
        As for the intake, a lot of people have used sink drains and more people use aftermarket CAI's. I can see that drilling holes would work, but there would still be a lot of the mesh left in the way that would prevent non-turbulent airflow. If money is no object, I'd go Dinan. If you are like me and it matters, then the sink drain is the way to go...
        d-
        Old 18th December 2007, 04:17   #12 (permalink)
        ard
        ard's Avatar
        The holes in the air box would allow hot air from the engine compartment to enter the engine, lowering overall performance and exacerbating heat soak.
        ard is offline
        Old 18th December 2007, 04:21   #13 (permalink)
        DouglasABaker
        Hey ard,
        You mean if he disconnected the tube going to the airbox from the box itself right?
        I was referring to the stupid extra piece inside the box that looks like the end of a trumpet - doesn't seem like it has much effect one way or the other, but removing it wouldn't allow any more (or less) hot air in...
        d-
        Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Add this post to your Facebook Profile
