• Latest threads
    • Custom feed
      • Updates
        Old 17th December 2007, 08:31   #1 (permalink)
        jrhaile
        Send a message via AIM to jrhaile Send a message via MSN to jrhaile
        Brake Pad Advice
        Wife is buying me SS lines and brake pads for my birthday on the 22nd. My type of driving is agressive and I do a lot of hard street driving and rallying through some hard corners. I don't road course my beast though and probably won't. 100% Hard-core street addict. I currently have stock rotors. What are my options for best performing pads? I also DD this during the summer months too so really noisey isn't to my liking
        2001 Carbon Black on Black M5 (Magnaflow Exhaust, Dinan Intakes, Dinan Software)
        jrhaile is offline
        Old 17th December 2007, 08:34   #2 (permalink)
        E55AMG2
        E55AMG2's Avatar
        there are carbotechs that fit your needs, the A-something or other series.
        E55AMG2 is offline
        Old 17th December 2007, 08:39   #3 (permalink)
        jrhaile
        http://www.beastpower.com/Merchant2/...Store_Code=BMI
        $350 for a set of pads seems a bit stiff?
        jrhaile is offline
        Old 17th December 2007, 09:15   #4 (permalink)
        palantirion
        Company Representative for BMS
        palantirion's Avatar
        I quite like the Axis pads that StopTech ships with their BBKs. They are a little light for track duty, but for street driving they are fantastic!
        www.ebsart.com
        2007 Z4 M Coupe, Titanium Silver with Imola Red, black and silver interior
        -for details: www.mymcoupe.com
        2003 M5, Imola Red with black and silver interior
        -Dinan S2 drivetrain
        -Dinan stage 3 suspension with JRZ shocks
        -StopTech brakes
        -Rogue Engineering short shift kit and clutch stop
        -275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
        -Progressive window tint
        -Euro dash and armrest conversions
        -CDT/Total audio, NavTv w/ DVD
        -Seat massagers
        2002 540iT, Sapphire Black with black and red interior
        -Dinan stage 3 suspension with Koni shocks
        -StopTech brakes
        -255/40R18 PS2s f/r on 18x8.5 BBS RG-Rs
        -Custom interior trim and seat massagers
        -NavTv with DVD
        Performance mods by: BMS
        palantirion is offline
        Old 17th December 2007, 15:32   #5 (permalink)
        TCM
        TCM's Avatar
        Look into Axxis Ultimates for street duty. Great combination on the M5 IMO. Hope this helps.
        T.C.
        '01 Silverstone M5
        SuperSprint:X-pipe
        TCM is offline
        Old 17th December 2007, 17:52   #6 (permalink)
        E55AMG2
        E55AMG2's Avatar
        For a set of "street" pads, you'd be correct. However;
        1) Those are the track pads, not street
        2) Its cheaper if you buy direct from Carbotech.
        3) CT's last longer than other brake pads (at least in my experience)
        The Bobcat 1521 or the AX6 can be used on the street on our cars.
        $269 for a set of Bobcats (street)
        $327 for a set of AX6's (Technically autocross, but can be run on the street if you dont mind a little noise now and again)
        E55AMG2 is offline
        Old 18th December 2007, 05:23   #7 (permalink)
        jrhaile
        Are the Axxis pads okay to use with stock rotors?
        jrhaile is offline
        Old 18th December 2007, 16:00   #8 (permalink)
        Kin Mak
        Kin Mak's Avatar
        Send a message via MSN to Kin Mak
        Axxis Ultimates for road use. Don't forget to upgrade brake fluid to something like Motul RBF 6000.
        BMW E46 M3 SMG Carbon Black/Cinnamon
        BMW E39 M5 Avus Blue - SOLD
        KinMak.com - Loads of Photos - Elara Online
        Kin Mak is offline
        Old 18th December 2007, 16:06   #9 (permalink)
        mikeoski
        mikeoski's Avatar
        Send a message via Yahoo to mikeoski
        Everything you would want to know and purchase regarding brakes for your M5 can be found here: http://www.zeckhausen.com/BMW/E39_M5.htm. Axxis Deluxe will be very low dust and sufficient for the street. If you really want to drive aggressively in a safe manner, you should be going to the race track with your local BMW CCA club. Give it a drive, you will become addicted which is a good thing
        2000 Avus Blue ///M5
        Dinan S2:
        Stage 5 Software, Carbon Fiber Cold Air Intakes,
        Air Flow Meters, Headers, Throttle Bodies,
        Velocity Stacks, LTW Flywheel, Exhaust, 3.45 Differential,
        Stage 3 Suspension, Front Strut Brace
        UUC Evo3/DSSR Short Shift Kit
        Rogue Power Pulleys
        Euro Brake Ducts
        StopTech ST-40 Front Brakes
        Euro Floating Rotors Rear
        Axxis Deluxe Pads Street/Hawk HT-10 Track
        SSR GT7H 9.5" & Toyo RA1 275/35R18 Street
        SSR Comp 9.5" & Pilot Sport Cups 265/285 Track
        H&R 10mm spacers (front)
        '98 Active Autowerkes SC'd M3 (Daily Driver)
        mikeoski is online now
        Old 18th December 2007, 19:13   #10 (permalink)
        jrhaile
        Already do but not in my M5...
        jrhaile is offline
        Old 19th December 2007, 00:05   #11 (permalink)
        mad dem21
        mad dem21's Avatar
        I have cool carbon pads on my car. I bought them from bavauto.com for 118f 112r. they are low dust and have lots of bite for the street.
        mad dem21 is offline
        Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Add this post to your Facebook Profile Add this post to MySpaceStumble this Post!
