• Latest threads
    • Custom feed
      • Updates
        Old 16th December 2007, 20:51   #1 (permalink)
        Stack
        Stack's Avatar
        Will I do any damage?
        Guys,
        Last night I got a flat tire, luckily it happened right in front of my girlfriends house so it's sitting there right now until tomorrow morning when I can get it fixed.
        Since i don't have a spare to drive it to the tire shop for them to replace my tire under road hazard; I have a spare 540 rim with no tire on it then i brought over and was going to jack up the car take off the rim and tire and place the 540 Rim (style 66 that fit) and lower the car to rest on the rim until i get it fixed and come back and switch it back on. By the way the old rim has a slight bend in it so i am not worried about scratching it up.
        I want to make sure if I leave it like that for a few hours i wouldn't be damaging anything letting it sit like that?
        Thanks for your input.
        Stack is offline
        Old 16th December 2007, 20:58   #2 (permalink)
        synacide
        synacide's Avatar
        Send a message via AIM to synacide
        i dont see anything wrong with that except for the fact the the rim will be right up against the pavement.
        synacide is offline
        Old 16th December 2007, 21:23   #3 (permalink)
        mottati
        mottati's Avatar
        i don't think you'll hurt the car, but the car sitting currently on the flat is not good for that tire. I came back from a vacation to find my car in the garage with a flat, pulled the wheel off, found a nail, brought it in for repair. After the repair, reinflated the tire and got a nasty sidewall bulge, separation occured probably from the car sitting on the flat.
        Engine:
        Suspension:
        Interior/Misc:
        mottati is offline
        Old 16th December 2007, 22:57   #4 (permalink)
        azaytsev
        azaytsev's Avatar
        don't worry, you should be just fine.
        azaytsev is offline
        Old 17th December 2007, 08:48   #5 (permalink)
        ReflexGTI
        ReflexGTI's Avatar
        Why not leave the car on the jack?
        ReflexGTI is offline
        Old 17th December 2007, 09:11   #6 (permalink)
        Stack
        Stack's Avatar
        Just got done putting it on the rim. By the way the Style 66 rims will clear the brakes by a very slight margin so you can use them for spares and winter tires.
        I just didn't trust leaving it on the jack for and extended period of time while i am not there. Never know when it might fall and do a lot more damage. So i figure having it on the rim sitting still should be a better way.
        Stack is offline
        Old 17th December 2007, 12:10   #7 (permalink)
        gherardini
        gherardini's Avatar
        Send a message via ICQ to gherardini Send a message via Yahoo to gherardini
        uh.... didn't you have the number for roadside assistance? it's in the trunk. and don't we have free lifetime roadside assistance for flats??
        '02 M5 TiSi-SBI [Sexy Black Interior] - "Audrey"
        BMWMOA iBMWr IBA#7268 LPR#71 SEAT#17
        - Valentine1 - hardwired
        - StealthOne
        - SS Exhaust
        - GrafxWerks ///M5 Lighted Door Sills, all 4 doors
        - Hella Euro clear corner headlights
        - Steath Auto Turn Signal Bulbs
        - Predator ICE v2.1
        - Xenon fog lights
        - CNS Racing clutch
        - TC Designs Sway Bar Brackets
        '87 K75S - "Maybellene"
        '00 R1100S - "Tresor!"
        Sierra Vista, AZ
        gherardini is offline
        Old 17th December 2007, 18:16   #8 (permalink)
        Beemer Guy
        Beemer Guy's Avatar
        +1
        2003 LMB M5 R.I.P. 01/02/08
        2008 Jet Black 335 Coupe (replaced the M5)
        2002 Slate Grey 911 Cabriolet
        Beemer Guy is offline
        Old 17th December 2007, 18:24   #9 (permalink)
        jclyman
        jclyman's Avatar
        LIFETIME assistance for flats, I believe ...
        - Daniel Boorstin
        jclyman is offline
        Old 18th December 2007, 00:15   #10 (permalink)
        Stack
        Stack's Avatar
        Well if I am not mistaken it would just tow me to the nearest dealership correct?
        I was already at my GF's house and it was safe so I didn't need it towed anywhere. Just took the rim with tire to Discount tire and had them look at it.
        Stack is offline
        Forum Jump
