E39 M5 runs 11.9@121 in the 1/4 - Page 15 - BMW M5 Forum and M6 Forums
Old 21st December 2007, 05:46   #141
phillym5
Garage: 01 Area 51 M5 Le mans.
Kelster....
I think you will be fine with that boost. I know of a couple/few M5's with 10psi running around. They don't post here. D/A has built a few. Stock internals. I have a feeling the S62 is a lot stronger than people believe. If you look at the M3's S54..... they are now pushing over 700rwhp(race gas) on the stock motor using turbo. There are dozens of 500+rwhp(pump gas) stock internal M3's running around. In the early days.. they all thought 10lbs was really pushing the limit. Well........ they were all wrong. They are at 22lbs of boost on 109oct. Pretty impressive. So really.... unless someone has pushed the S62 untill it popped... nobody will know until it happens. But I highly doubt 7.8 psi would do it.
phillym5 is offline   Reply With Quote
Old 21st December 2007, 09:50   #142
Blue Thunder
Garage: 1999 M5 Avus Blue Metallic
Originally Posted by phillym5 View Post
Kelster....
Been there - done that
Expen$ive lesson.
The S62 has a weak block that flexes alot. The cylinders are also placed
very close together with very little material between the cylinders, not good.
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore,
UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis
19" Hamann PG2´s, Strongstrut front Strut Brace, BMW fire extinguisher, Phatbox MP3 player, CF interior trim, Voltphreaks battery
http://www.cardomain.com/ride/2417213/1
1989 E30 M3 White - track toy
S50B32 with a supercharger - 500+ hp, 1300kg rocket for the Ring
Blue Thunder is offline   Reply With Quote
Old 21st December 2007, 11:52   #143
Kelster
Kelster's Avatar
Garage: 2003 M5 S3 #24 Jet Black/Volleder Napa Heritage Schwarz
Sales Feedback: (4)
Atco
Originally Posted by Lscman View Post
I have never driven on the return road. The site grading you apparently noted is a very useful piece of technical information that suggests the track does not follow the lay of the land.
I beg to differ. This is not a 'useful piece of technical information' but merely one person's observation. What about the fact that Atco is an approved NHRA venue? Do you really believe NHRA would sanction events at Atco if the track has the elevation differences you keep harping about?
I am an inherently curious person who believes in thorough research and discussion (beat a subject to death) until everything possible is revealed. Some folks find this annoying and I understand.
It's one thing to be curious and quite another to appear to have an agenda. You have made your points and they have been responded to. You appear to ignore any data that doesn't fit your preconceived notions about Atco, a track you freely admit that you've never visited in person. 'A dog with a bone' would seem to characterize your obsession with the Atco grade issue.
If the track before the traps is flat as ice on a lake, I would like to know that. It is not my intention to prove the track is sloped (or flat) & I have nothing to gain from either. My only agenda is to eliminate unknowns. My opinion is based upon limited information available.
If you are sincere about the forgoing the first thing you should do is to take a drive and visit the track. Bring someone along with you who has some knowledge of civil engineering. And respond to the fact that Atco appears to be an NHRA sanctioned venue.
It was my intention to perform a sanity check that evaluates ATCO from a technical perspective, since it's a notoriously fast track. This may be attributed to good track prep and surface, but I'm not one to blindly assume that.
Your so-called 'evaluation from a technical perspective' is a farce on a par with those who believe 'the earth is flat'. I suggest you go to the library and read up on 'the scientific method.' In of your December 15 post you flat out state
Originally Posted by lscman
It's only 33 feet above sea level at the traps and 90 feet above sea level at the start.
And only later do you waffle and try to suggest that you were merely suggesting that the elevation differential was a 'possible' reason that Atco's ETs are so quick. Be objective and respond to data that doesn't agree with your position - don't just blissfully ignore it.
I admitted to playing the devil's advocate to solicit thought and uncover additional info through futher discussion. Please don't contrive and purport what I "believe". You negative assessment of me is not fair or appropriate.
Rather than playing devil's advocate you come across as someone having a preconceived agenda. I would suggest that you re-read the entire thread and address those points which have been raised and that you have heretofore chosen to ignore, i.e., the matter of NHRA sanctioning the Atco venue and other readings of topo maps that contradict your contentions.
2003 Jet Black lllM5 Dinan S3 #24
621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2-T Intercooled Supercharger, Speedhut Custom Boost Gauge, S3 Oil Cooler, S3 Engine Management Software, OKD Plasma Direct Ignition Coils and Plasma Spark Boots, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Modified Cats & Free Flow Exhaust, BMW 545 Short Shift Kit, Ground Control Coil-Over Suspension, 430 7" F & 325 10" R, Dinan/Brembo Brakes, Zionesville Radiator, Spal 2-speed Electric Fan, AGA Power Steering Reservoir, Rennline Pedal Set w/ throttle heel/toe ext, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Sub-frame Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, Track: Toyo Proxes RA1 275/35R-18; Drags: Nitto NT-555R Drag Radials 285/35R-18; Street: Michelin Pilot Sport PS2 275/35ZR-18; Laser Interceptor, Dual Head, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v31 Custom 'Beast' screen & Navtech 2009.1 DVD Map, BSW Speakers with iPod integration, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder. Coming: Howerton Engineering Methanol/Water Injection, Schmiedmann EVO CF Hood.
1/4 mile: 11.795 @122.20 mph, 60' - 1.819 03/11/2008 ATCO
Kelster is offline   Reply With Quote
Old 21st December 2007, 16:30   #144
Lscman
Garage: E39
Listen Kelster,
You are unfairly characterizing me in a negative way and making totally false accusations against me. I did not attack anyone here in a personal fashion & neither should you. I absolutely do not have a preconceived agenda. Initial information I found suggested the track was not flat & I posted it, including various track elevations that I found and other's did too that vary between 95' and 33'. I tried to search and solicit more technical information about the track and this was challenging. Spotty & sometimes divergent (contrary) information was collected from many sources. This is not grounds for a personal attack.
Your quotations of my posts are cleverly flopped out-of-order, so progress looks encumbered (duh). The fast track inquiries were posted first, followed by slope, prep, NHRA and site grading discoveries. In an ongoing effort to denigrate me, you "blissfully" ignore my prior reply to CSBM5 about track slope:
Perhaps the first 1/4 mi is nearly flat then. I did not realize the track was that long in total.
I still consider first-hand comments about uneven site grading near the traps to be useful information that suggests the track has been elevated to level on uneven site ground because this is NOT how tracks are built in my area. Around here, some farmer's corn field was turned into a track long ago and it is rarely level. AMAZINGLY, you selectively dismiss information that supports a level track scenario while attacking me for considering & acknowleging it. You really need to do a self-assessment before taking such a stance because hypocricy comes to mind. I am not going to visit ATCO to satisfy you.
NHRA track approval is impressive & indeed notable, but it may or may not be significant wrt level track. Do you know if NRHA tracks have a slope/level specification? After hours of searching, I am unable to effectively filter through the reams of NHRA safety guidelines to find ANYTHING relating to track construction/design wrt max slope specifications or anything remotely similar. How long have you spent searching for that? I do not know what technical guidelines the NHRA uses with respect to approving a track layout, but likely exist. These rules may include track surface type, runoff distance, timer accuracy and levelness, but this is purely a guess. All I can find is millions of rules relating to track safety and classes. Perhaps a NHRA rulebook needs to be purchased. Track design parameters are NOT contained in any pro or amateur racing rulebook I've owned, so this info may be difficult to get.
If you have ANYTHING to provide aside from personal attacks and the acronym "NHRA", why not share it? Technical information about superchharged M5's, ATCO or drag racing is appreciated and would seem to be on-topic. Attacking me is not on-topic.
Resolve never, screw genuine.
Lscman is offline   Reply With Quote
Old 21st December 2007, 16:53   #145
Lscman
Garage: E39
Originally Posted by rneedham1979 View Post
Is the M5 FI set up speed density?........Ryan
I was only pointing out that speed density with marginal mixture control under boost may even work well on a drag strip while often failing miserably on a road course. There is more safety margin in drag racing for a given motor setup. As you noted, the drivetrain may take a greater beating in drag racing. Accurately guesstimating air flow through speed density algorithms is much more difficult than measuring actual air flow.
It's easier to maintain a safe mixture under a flat-footed drag racing sprint condition. Even if the mixture momentarily goes lean for a couple seconds, it's less likely to harm the motor compared to road racing where the throttle may be mashed for 5x as long and for periods of 30 minutes or more. Prolonged lean condition or pre-ignition is what tends to lift heads. As the pressure is increased, tolerance for timing error or lean condition approaches zero.
Old 21st December 2007, 17:41   #146
multiowner
multiowner's Avatar
Garage: 2009 MB Cl63 Artic White
Kelster and Lscman, why not have lunch together. Seems like you two have a great deal of time to kill. You can meet each other half way. I calcalated it to be exactly at Atco Raceway.
2009 MB CL63 Artic White Cashmere
2006 M5 Sapphirre BlacK/BlacK Traded 4/09
2007 MB SL550 Iridium Silver/Ash Traded 4/09
2008 335xi Alpine/Beige
2005 Porsche Cayenne S Gray/Black
multiowner is offline   Reply With Quote
Old 21st December 2007, 17:53   #147
THRILOS5
THRILOS5's Avatar
Garage: 2001 m5 black
Sales Feedback: (3)
I say lets meet at Atco in March
e39 M5
Audi S4
300ZX tt 580hp@20psi
Mustang GT 5.0L
Suzuki GSXR750
THRILOS5 is offline   Reply With Quote
Old 21st December 2007, 17:54   #148
M5 Dan
M5 Dan's Avatar
Garage: 2002, M5, Silver
Some cracking times there, I bet you are very proud. Great News..
2002 Silver M5
M5 Dan is offline   Reply With Quote
Old 21st December 2007, 19:10   #149
Lscman
Garage: E39
Originally Posted by Kelster View Post
.........Don't you just love the navel-gazing analysis of the S3 motor by people who don't have a fu*king clue as to what makes it tick? Here's a big clue folks - the S3 doesn't have MAFs.
Your maturity and ego is beyond measure.
Old 21st December 2007, 20:08   #150
rneedham1979
Banned
rneedham1979's Avatar
Garage: 2005 4.8IS, 2000 STOCK M5
I would have to agree.
rneedham1979 is offline   Reply With Quote
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
Supercar Shootout in Sweden II: [Update:High Defintition Download] Gustav E60 M5 and E61 M5 Touring Discussion 607 24th July 2008 22:34
Movie: 24 hours and six fueltanks with the new BMW M3 V8! [Now with 10 min video] Gustav E60 M5 and E61 M5 Touring Discussion 48 21st October 2007 12:39
M5 / E55 comparison -after owning each- LONG Scott in Houston E60 M5 and E61 M5 Touring Discussion 34 12th April 2007 00:39
RS4 vs S6 vs M5 E39 driving experience (Long) vasbli E39 M5 and E52 Z8 Discussion 13 17th October 2006 18:16
