E39 M5 runs 11.9@121 in the 1/4 - Page 13 - BMW M5 Forum and M6 Forums
Old 20th December 2007, 18:04   #121
Kelster
Kelster's Avatar
Garage: 2003 M5 S3 #24 Jet Black/Volleder Napa Heritage Schwarz
Sales Feedback: (4)
S3 Mods
Enzom, we're also expecting to develop additional HP. We're currently at the 'low' end of the blower psi spec for the S3. We think there is another 0.8 psi that should be available. Having said that I don't see us ever turning in the tens, even with a tailwind and on a 'down hill' track Not with a 4000 lb sedan. Possibly 11.40s @125 mph+
The 3.45 rear is going back in tomorrow morning at MWW. Anyone who wants to watch (and keep me company) is welcome to come.
2003 Jet Black lllM5 Dinan S3 #24
621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2-T Intercooled Supercharger, Speedhut Custom Boost Gauge, S3 Oil Cooler, S3 Engine Management Software, OKD Plasma Direct Ignition Coils and Plasma Spark Boots, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Modified Cats & Free Flow Exhaust, BMW 545 Short Shift Kit, Ground Control Coil-Over Suspension, 430 7" F & 325 10" R, Dinan/Brembo Brakes, Zionesville Radiator, Spal 2-speed Electric Fan, AGA Power Steering Reservoir, Rennline Pedal Set w/ throttle heel/toe ext, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Sub-frame Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, Track: Toyo Proxes RA1 275/35R-18; Drags: Nitto NT-555R Drag Radials 285/35R-18; Street: Michelin Pilot Sport PS2 275/35ZR-18; Laser Interceptor, Dual Head, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v31 Custom 'Beast' screen & Navtech 2009.1 DVD Map, BSW Speakers with iPod integration, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder.
NEW: Howerton Engineering HFS-4 Methanol Injection, Custom Billet Alloy 8-Rib Blower & Crank Pulleys, Aeromotive 'Stealth' High Pressure/Volume Inline Fuel Pump, new rod bearings & ARP Rod Bolts, Schmiedmann EVO Carbon Fiber Hood.
1/4 mile: 11.795 @122.20 mph, 60' - 1.819 03/11/2008 ATCO
Kelster is offline   Reply With Quote
Old 20th December 2007, 19:06   #122
MarkQC
MarkQC's Avatar
Garage: M5 E39 Carbon Black -silver/black interior
Originally Posted by Enzom View Post
Actually, you seem to have found 2 full seconds for Ray's car when you add the component time savings. It should be in the 9's.
With practice and confidence in the car, Harry will shave some time off of the 11.92. But even with a 3:45 rear and drag radials, I don't see how he can find a second's worth of time. That's a very tall order. And if you've spent time at the track and modded cars and tried different techniques, you know just how hard it is to find 2/10's, let alone a full second.
It takes lots and lots of power and skill to see 10's. If C6 Z06's with drag radials and an excellent driver are barely hitting the 10's with traps of 129 mph and 1.6 60' times, weighing in at 3,300 lbs with driver, that tells you something. Figure that the Z06 is putting down 440 rwhp. Even if Ray's car is putting down 20 or 30 more, its carrying an extra 800-1000 lbs.
And everything is a compromise whe you are racing. Cold air isn't the greatest for tire grip, but it sure helps you make power. A numerically higher gear ratio sure helps you on the top end, but it makes it even harder to put the power down at the start. Drag radials give you better grip, but they put more stress on the driveline and can cause you to glaze your clutch. Hard to find a 1/2 second shifting unless Harry is shifting very slowly. And if you speed up your shifting too quickly, are you chirping 2nd and 3rd which costs you time?
I'd love to see Harry (with Ray's blessing, of course) run that car like he stole it on drag radials and 3:45's to get every bloody 1/100th of a second out of it. But even then I doubt we'd see anything quicker than an 11.50 on a perfect run. And that itself would be mighty impressive, btw.
I think Harry and Ray can sleep well even if the car never sees 10's. Just seeing 11's in a heavy 4 door sedan is incredible when you think about it.
...well of course you are pretty much correct. I have spent tons of time working to get hundredths of a second. I don't expect 9's, the estimates were best case for each area, not normally achievable but potential depending on obstacles -so as I said 10's-a second faster.
...and imho - this cars drive line is just not set up right for the drags. So even being heavy, (really just 400, not 800lbs heavier than the Zo6), it would take hard core mods to the driveline to hit 10's.
- - 14"+ slicks, a tougher rear end / suspension etc to put max posi down (also I meant the other direction with the # like 390+ -I was running 4.88 / 5.13) and a transmission like a Lenco that is able to shift as fast as a drag automatic (sorry for the reference to auto SMG guys ). So I still think it is possible.
...as I mentioned - I saw a shoebox 55 Chevy pull flat 10's all day long with a small block on alcohol. The hookup, the mods to the chassis to achieve an amazing hole shot where the front tires didn't rotate until they hit the pavement at about 40 feet is probably not achievable in the mighty M without chopping up this wonderful car...It's unlikely he'd do that...
But it is fun to imagine an M with it's front wheels a few inches off the ground for the first 40...
happy holidays
MarkQC is offline   Reply With Quote
Old 20th December 2007, 19:16   #123
Blue Thunder
Garage: 1999 M5 Avus Blue Metallic
Let´s hope your stock internals like the additional boost.... be careful.
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore,
UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis
19" Hamann PG2´s, Strongstrut front Strut Brace, BMW fire extinguisher, Phatbox MP3 player, CF interior trim, Voltphreaks battery
http://www.cardomain.com/ride/2417213/1
1989 E30 M3 White - track toy
S50B32 with a supercharger - 500+ hp, 1300kg rocket for the Ring
Blue Thunder is offline   Reply With Quote
Old 20th December 2007, 19:57   #124
Enzom
Garage: 05 E55 brilliant silver
happy holidays
Photoshop, anyone?
Same to you.
05 E55 - Brilliant Silver/Charcoal; Best e.t. 11.775 @ 118.69 mph, 1.710 60' - BONE STOCK on PS2's http://www.dragtimes.com/2005-Merced...ecs-11697.html; Gone
10 Range Rover Sport SC
Enzom is offline   Reply With Quote
Old 20th December 2007, 20:18   #125
6speed
6speed's Avatar
Garage: 1984 Escort GT (loaded)
happy holidays
Not sure how much your car weighs but a C6 ZO6 with driver is around 3200 lbs. We have a scale at the end of our local dragstrip and I saw it first hand....pretty damn light.
Cheers ///
6speed is offline   Reply With Quote
Old 20th December 2007, 22:50   #126
Enzom
Cheers ///
I will check with Ronnie who was at the rental with his C6Z06. I think the weight with him in his car (he is a big and tall guy) is probably 3,300 lbs. Ray's S3 weighs 4020 without driver. So figure it weighed about 4175 with Harry and his helmet.
E39 M5 runs 12.3@116 in the 1/4
That's a pretty big weight difference.
Old 20th December 2007, 23:11   #127
THRILOS5
THRILOS5's Avatar
Garage: 2001 m5 black
Sales Feedback: (3)
S3 + me = 4,220
I better go on a diet if Ray wants the car to go faster
e39 M5
Audi S4
300ZX tt 580hp@20psi
Mustang GT 5.0L
Suzuki GSXR750
THRILOS5 is offline   Reply With Quote
Old 21st December 2007, 00:20   #128
Kelster
Kelster's Avatar
Sales Feedback: (4)
Originally Posted by multiowner View Post
Mind you, I am not a Civil Engineer but most sites require both the removal and fill of spots to acheive a proper site. When driving on the return road after the traps, you can plainly see a different grade. This difference is not reflected in the finished dragstrip. People will always have something to say about everything. lSCman would like to believe the track is sloped to continue the debate and have someone to research this 100 different ways. I would like to believe that the design phase of a dragstrip would include picking the best location for the strip, drainage issue, parking sites, traffic control, ect.... I would like to end on this, Track prep is a costly item that most owners would rather not spend their money. The chemical is rather expensive. Atco has always prepared the track to be race ready. Other owners choose to skimp on prepwork unless its a money day.
Bob, in researching the grade issue at Atco on Google, I came across the fact that Atco appears to be an 'approved' NHRA dragstrip. I sincerely doubt that NHRA would sanction events at at a track with the start/finish line differential elevations that have been alleged.
Old 21st December 2007, 01:06   #129
Kelster
Kelster's Avatar
Sales Feedback: (4)
Kelster = UFH? Nope
Originally Posted by T Bone View Post
Wow, your post is strangely UFH like..... Bold font.... You guys the same person?
Definitely not the same person. We've even been seen together in the same room at the same time (at Sergio's Christmas Party)... UFH also likes to vary his font sizes whereas I do not. I just happen to prefer Verdana 2 Bold
The pic was the best picture I could find of a soup pot. When you drive a manual car, you are stirring the soup pot....
Stirring the soup pot? Wow, now where did you ever hear that one? I'm guessing it must be a local expression. Midwest? I've never heard it used around the north-east in all my years of drag racing which date back to the late '50s and early 60's (I know, right after the earth's crust cooled).
I was impressed to see Trilos5 launch the car.... What was the 60' foot time in that run on video?
I believe Harry already answered this question (FWIW his screen name is Thrilos5). The boy can really drive that S3 alright and it's gonna get even better with more boost, the new 3.45 rear and drag radials. Harry is already in 4th gear at the timing lights with the present gearing. With the 3.45 he will be much higher in the rpms (and making more boost) at the finish. As it is the S3 is beginning to pull like a freight train at the finish line. Just compare its trap speed with the E60s and AMGs.
Old 21st December 2007, 01:12   #130
maikosg
maikosg's Avatar
Garage: 2003 imola red M3
I will check with Ronnie who was at the rental with his C6Z06. I think the weight with him in his car (he is a big and tall guy) is probably 3,300 lbs. Ray's S3 weighs Lorenzo, were you wearing your contacts last time you saw harry?? His hair alone weighs that much
Guys, with all this talk about atco being downhill i am going to take my car onto 280 between livingston and the oranges to run the quarter.
Anyway, pure logic can tell us that there is no "downslope" at atco because of safetey reasons. Have you ever tried accelarating a 7, 8, 9 or even 10 second car downhill?
maikosg is offline   Reply With Quote
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
Supercar Shootout in Sweden II: [Update:High Defintition Download] Gustav E60 M5 and E61 M5 Touring Discussion 607 24th July 2008 22:34
Movie: 24 hours and six fueltanks with the new BMW M3 V8! [Now with 10 min video] Gustav E60 M5 and E61 M5 Touring Discussion 48 21st October 2007 12:39
M5 / E55 comparison -after owning each- LONG Scott in Houston E60 M5 and E61 M5 Touring Discussion 34 12th April 2007 00:39
RS4 vs S6 vs M5 E39 driving experience (Long) vasbli E39 M5 and E52 Z8 Discussion 13 17th October 2006 18:16
