E60 M5 brakes for E39 M5? - BMW M5 Forum and M6 Forums
Old 9th December 2007, 22:21   #1
Exorcist
Garage: E46 M3 '04
I need to upgrade the brakes for my beast. I would be able to get almost new E60 M5 brakes for 'cheap', but how hard it is to fit them to E39 M5?
Atleast he has them installed: http://www.carpassion.com/de/usergarage.php?no=567
Have anyone done this?
Exorcist is offline   Reply With Quote
Old 9th December 2007, 22:47   #2
azaytsev
azaytsev's Avatar
Garage: 996 C4S 6MT
why don't you ask the owner of the yellow M5 this question. Check the for sale section, that car is for sale now. he is the member of this board.
azaytsev is offline   Reply With Quote
Old 9th December 2007, 22:54   #3
vitiokas95
vitiokas95's Avatar
Garage: '01 M5 Carbon Black/Black
Sales Feedback: (7)
Let us know what did he tell you
2008 M3
Alpine White/ Black
2010 X5 Diesel
Black/ Tabacco
2001 M5
Carbon Black/Black/Aluminum Trim
SOLD
Winter beater:
1994 530 auto
Sold
vitiokas95 is offline   Reply With Quote
Old 9th December 2007, 22:59   #4
Exorcist
Garage: E46 M3 '04
Asked the owner.. will get back to you.
Old 9th December 2007, 23:25   #5
mfizzlenyc
mfizzlenyc's Avatar
Garage: 2000 m5 silverstone
Sounds Good Let us know
2013 Subaru wrx Cobb tuned Daily beater
2009 135 "Worlds First Frozen 1ER" ESS Tuned stage 2
RIP MFIZZLENYCMOBILE - 12/5/2012 2000 Silverstone M5 extended Leather
213,500 miles !!!!!
Evolve Stage 3 Tune
BBS LMs 19s
Michelin Pilot Super Sports ,StopTech BBK,Dinan Headers, CF Plenum cover with clear windows, Dinan CF -CAI,Dinan Air Mass Meters ,Dinan light weight flywheel,Dinan stage 3 suspension ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
mfizzlenyc is offline   Reply With Quote
Old 10th December 2007, 16:58   #6
Exorcist
Garage: E46 M3 '04
"I haven't done the work by myself, but the tuner was very quick... Did the whole thing like a normal brake job
I think you just need some adapters, but I don't see any @ my brakes... BUT you need bigger wheels. 19" because most of the 18" are too small on the inside "
So anyone know better?
It seems to be an easy task...
Old 10th December 2007, 19:36   #7
vitiokas95
vitiokas95's Avatar
Sales Feedback: (7)
Who can give us straight answer?? Anyone?
Old 10th December 2007, 19:41   #8
M540i
M540i's Avatar
Garage: 2002 BMW M5, Sterling Gray Metallic; 2001 BMW 540i 6-Speed, Jet Black
Doesn't sound like it's worth the hassle to me. By the time that you (or whomever you are paying to do this work) are finished fabricating brackets for the E60 M5 calipers to fit the factory mounting points, you would have spent some pretty serious bucks on it. Then you have to buy wheels (19") to accommodate the new rotors that you have installed. And for what reason? When it comes to stopping the car, "cheap" generally doesn't exactly enter my mind in the list of adjectives for what I would want. But then again, expensive isn't at the top of my list either.
But what I can say is that UUC has developed a cost-friendly Big Brake Kit for the E39 M5 and 540i cars. Having spoken with him at length last week, I can attest to this statement. Even though I am not sure if it has been released yet. No, don't take the website's word for it either, because that hasn't been update for a while.
Aren't the E39 wheels hub centric anyway? So would it even be possible to use E60 M5 rotors on an E39 M5?
M540i is offline   Reply With Quote
Old 10th December 2007, 21:55   #9
SirRichi
Garage: BMW M5 E39
Hi there
As I worte in the PM, a tuner made that for me. I had the same decision like a lot of others here --> Get a Stoptech/Brembo/whatsoever or get the e60 system fitted. The e60 system is a LOT cheaper than a proper Brembo kit and the ultimate thing for me to do it this route -> e60 discs and pads are available everywhere and every BMW dealer can check it etc.
Best regards
Richard
BTW: The system DOES work superb I only used the car for long distance trips with a lot of km in Germany, there's no fading anymore. I also made two trips to the Ring --> No problems again
SirRichi is offline   Reply With Quote
Old 10th December 2007, 22:41   #10
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
Agreed. My perfect brake upgrade would include Stoptechs 355mm up front only, more aggressive pads and stainless lines all around, and cooling ducts in front. Should be lots cheaper than an E60 setup as you won't have to upgrade the wheels also.
One thing to keep in mind: If you change the brakes to the E60 setup, you will most likely have to do all 4 wheels as it's unlikely that the brake bias is correct only doing one end. If you change all 4, you should also check on your master cylinder as the piston size may be too small for the E60 calipers. If you don't change the master, your pedal will probably travel more than with the stock setup as the E39 master cylinder is not designed for the larger pistons in the E60 calipers.
lots of headaches avoided by just buying a properly engineered after market upgrade.
verhagke is offline   Reply With Quote
Alpina B7 Review MEnthusiast ALPINABoard.com | BMW Alpina Discussion 49 16th November 2010 15:23
Alpina B7 Review [Copied from the Alpina Forum] MEnthusiast E60 M5 and E61 M5 Touring Discussion 33 4th December 2008 18:10
Looked very close at two M5 E60 as well as met Mr Bangle + BMW M Director Mr Bruhnke! Gustav E60 M5 and E61 M5 Touring Discussion 42 10th October 2004 17:08
New M5 information direct from Mr. Donnie Isley of the BMW Performance Center atomic80 E60 M5 and E61 M5 Touring Discussion 1 15th September 2004 09:45
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
