E60 M5 brakes for E39 M5? - Page 4 - BMW M5 Forum and M6 Forums
Old 19th August 2008, 00:26   #31
Mposter
Mposter's Avatar
Garage: Titanium Silver '00 M5
Originally Posted by palantirion View Post
-Are they in any way designed to actually work with the M5's weight, load transfer, and brake bias? Or were they chosen simply because they work well on the Z06?
Whats there to design? The only aspect of the design is a single fraction. The ratio of moments generated by the brakes front/rear. And then you ensure the pedal travel and force are a decent compromise.
Here's a great XLS file from Race-Tech that'll help you accomplish your "brake design" needs.
'00 M5 - too stock
'04 Ducati 999 S - too loud
'95 Range Rover LWB - too slow
Mposter is offline   Reply With Quote
Old 19th August 2008, 00:28   #32
palantirion
palantirion's Avatar
Garage: 2003 M5 (Dinan S2), Imola Red
Originally Posted by Mposter View Post
Any "front only" big brake kit will upset the brake bias. The main objective with massive brakes is consistency and fade resistance - not necessarily reduced stopping distances.
Swapping out the proportioning valve, or getting an adjustable one will alleviate this.
Four-wheel BBKs are a waste of money as the rear wheels do hardly any braking, so nearly any stock caliper is sufficient. In fact, the increased unsprung weight will possibly reduce overall performance of your car.
-You're right on the money except for two potential factors:
1) Some BBKs decrease unsprung weight even as they increase the size of components.
2) Some 4 wheel BBKs are significantly more useful than a comparative 2 wheel BBK. This is quite dependent on the vehicle in question and it's spring and longitudinal roll rates. Ideally, you would reduce load transfer to the front as much as possible and thus maximize all four contact patches instead of planting all the load on the front tires. If you can use more rear tire, then more rear brake helps. Stronger rear brakes, in some cases, can even help to reduce load transfer and also allow more control of the car's axis under braking (brake steering).
www.ebsart.com
2011 X3 35i,
Alpine White
with Nevada Chestnut interior and waveline wood trim
-Ceramic tint on all windows
-DVDinMotion DVD software unlock
-245/275 P Zeros f/r on 18x8.5/10 BBS RG-Rs
2007 Z4 M Coupe,
Titanium Silver
with Imola Red interior and silver trim
-for paint details: www.myartcar.com
-for mod details: www.mymcoupe.com
2003 M5, Imola Red with black interior and silver trim
-Dinan S2 drivetrain
-Dinan stage 3 suspension with JRZ shocks
-StopTech brakes
-Rogue Engineering short shift kit and clutch stop
-275/35R18 Michellins f/r on 18x9.5 BBS RS-GTs
-Progressive window tint
-Euro dash and armrest conversions
-CDT/Total audio, NavTv w/ DVD
-Seat massagers
palantirion is offline   Reply With Quote
Old 28th March 2009, 13:48   #33
jfman
Garage: 2000 E39 M5
Originally Posted by THRILOS5 View Post
actually we machined the caliper mounts to fit the car so there are no brackets, adapters or anything like that, you just swap them with your stock ones and use longer bolts.
Im using them for over a year now without any single issue(sometimes I forget I have them) and the bracking performance has been stellar, also had a few board members test drive my car and they can contribute to that
ps
if you're using the stock 18" wheels you will need the 10mm spacers for these calipers to clear(didn't need them with my 18" OZ wheels)
Wow that is amazing. Can you tell us where and how much you machined the calipers?
2000 M5 - 270k miles and counting.
2002 325xit waggen' with a stick
Mods: Powerchip Alpha-N, 545i shifter, V1(in my closet), cracked front bumper, cracked foglight, cracked windshield and sandblasty OEM wheels.
Member of the automatic carwash crew.
Lifetime membership with Pelican and Tischer.
jfman is offline   Reply With Quote
Old 22nd August 2009, 23:03   #34
Exorcist
Garage: E46 M3 '04
Just saw these in ebay: BMW E60 M5 Bremsanlage Sattel ADAPTER auf E39 bei eBay.de: Bremsenteile (endet 12.09.09 17:10:53 MESZ)
Basically it's a complete adapter to mount the E60M5 calipers to E39 front axel. It's also in the ad that saddles/discs are available.
I still think they might be a great mod for those looking for options.
Exorcist is online now   Reply With Quote
Old 22nd August 2009, 23:46   #35
nightkrawler
nightkrawler's Avatar
Garage: 03' M5
Sales Feedback: (3)
the look rather odd with the stock rotor. the new pads seem to be only contacting a bit more than 50% of the rotor surface.
nightkrawler is online now   Reply With Quote
Alpina B7 Review MEnthusiast ALPINABoard.com | BMW Alpina Discussion 49 16th November 2010 15:23
Alpina B7 Review [Copied from the Alpina Forum] MEnthusiast E60 M5 and E61 M5 Touring Discussion 33 4th December 2008 18:10
Looked very close at two M5 E60 as well as met Mr Bangle + BMW M Director Mr Bruhnke! Gustav E60 M5 and E61 M5 Touring Discussion 42 10th October 2004 17:08
New M5 information direct from Mr. Donnie Isley of the BMW Performance Center atomic80 E60 M5 and E61 M5 Touring Discussion 1 15th September 2004 09:45
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
