Air Fuel adaptation error on Peake tool - BMW M5 Forum and M6 Forums
Old 24th November 2007, 18:24   #1
S62M5
S62M5's Avatar
Garage: 2000 M5, Avus Blue Metallic
Sales Feedback: (4)
I get AF - Air fuel adaptation on CYl 5-8 when checked with peake tool, is this related to a fautly MAF sensor?
thanks in advance for your input
2000 M5, Avus blue
2005 GSXR 1000
http://www.youtube.com/watch?v=abo5aLzSRms
S62M5 is offline   Reply With Quote
Old 24th November 2007, 20:30   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
it can be. Have you already cleared it and has it returned? You could also try swapping mafs right to left and see if the code follows it. one last thing is to try the mafs test as outlined by member DavidS (i think that's in the faqs)
mottati is offline   Reply With Quote
Old 26th November 2007, 19:16   #3
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
good advice. Also, it may end up being a pre-cat oxygen sensor which requires replacement.
verhagke is offline   Reply With Quote
Old 26th November 2007, 21:01   #4
S62M5
S62M5's Avatar
Sales Feedback: (4)
i do actually get the pre cat oxygen sensor error too. i guess i should change it first and try and see if this error comes back again. the oxygen sensor error has come back a few times now.
Old 26th November 2007, 21:04   #5
S62M5
S62M5's Avatar
Sales Feedback: (4)
the oxygen sensor would be
REGULATING LAMBDA PROBE 11781742050
correct???
Old 25th August 2009, 04:30   #6
UkraineE39
UkraineE39's Avatar
Garage: E39 BMW M5. Grey
S62M5 , did you fix the problem? what did it end up costing you? Thanks in advance , also was it code AE and code 90 on the peake tool?
UkraineE39 is offline   Reply With Quote
Old 25th August 2009, 05:36   #7
S62M5
S62M5's Avatar
Sales Feedback: (4)
in my case it was the pre cat O2 sensor, i replaced it with a brand new one. that took care of it. cheers
Old 25th August 2009, 17:26   #8
UkraineE39
UkraineE39's Avatar
were you getting codes AE and 90 on your peake tool, s62?
Old 25th August 2009, 17:38   #9
wilsodh
wilsodh's Avatar
There's a report somewhere that 'fuel control' codes can be triggered by a tired pre-cat sensor. I'm guessing that 'fuel control' can refer to both direct delivery of fuel (injector/fuel pump), as well as a confused ECU due to a lazy pre-cat sensor.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
The Following User Says Thank You to wilsodh For This Useful Post:
ard (25th August 2009)
Old 25th August 2009, 17:39   #10
S62M5
S62M5's Avatar
Sales Feedback: (4)
i dont remember the code since it was 2 yrs ago, but the code description was "AF - Air fuel adaptation on CYl 5-8".
Peake tool help S62M5 E39 M5 and E52 Z8 Discussion 5 7th November 2007 01:03
Days 3 and 4 - Final Heat Tests, Conclusions and Recommendations greg E39 M5 and E52 Z8 Discussion 51 28th June 2007 22:06
WTB: Peake Research R5/FCX-II Scan/Reset Tool cosioboy Parts / Other For Sale or Wanted 0 12th November 2006 20:58
Borrowing Peake tool (Jacksonville, FL)? nsxer E39 M5 and E52 Z8 Discussion 2 2nd September 2006 03:45
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 09:23
