Oil problem - BMW M5 Forum and M6 Forums
Old 18th November 2007, 22:36   #1
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
Oil problem
Sorry to bring this back up but you guys remember my last post about my car smoking when I use the engine to slow the car down (engine braking) and then accelorate hard afterwards, well today I noticed that one of the bolts that you remove to get to the spark plugs has a little oil on it, the rest dont. Sorry to ask again but could you guys chime in with your thoughts on this.
andy777 is offline   Reply With Quote
Old 19th November 2007, 00:34   #2
Stika
Stika's Avatar
Garage: E39 M5/Jet Black on Black
Sounds like you need valve cover gaskets.
...i wanna go fast...
Stika is offline   Reply With Quote
Old 19th November 2007, 03:05   #3
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Which bolt? Is it one of the bolts that holds the Bremi in place on the spark plug? Or is it one of the bolts that holds the cover on? Or a different bolt?
d-
DouglasABaker is offline   Reply With Quote
Old 19th November 2007, 13:45   #4
andy777
andy777's Avatar
It is one for the spark plug I assume because there are four in a row on each side. It is the one nearest the front of the car on the right hand side. Also as you guys may remember this only happens when I use the engine for braking and only between 2000rpm and 3000rpm, however today I tried letting the clutch up quickly instead of slowly which I normally do and hardly any smoke. Could it be my driving style?
Old 19th November 2007, 15:31   #5
DouglasABaker
Do you also have oil all over the inside of that same area, or is it just on the bolt holding the Bremi?
d-
Old 19th November 2007, 16:31   #6
andy777
andy777's Avatar
No oil anywhere else just on the bolt, but I think I have finally cracked it, my car is smoking because of my driving style. I am taking to long to disengage the clutch when using the engine to brake. Just drove home from work and let the clutch up quickly several times and NO SMOKE! Now I am going to monitor the black spots of carbon on the rear bumper for the next few weeks. This problem has never been consistent and now I might have found out why. If I am correct, I know there are a few guys on this board having the same problem so I will let you all know soon. FINALLY!!!!!!!
Old 19th November 2007, 17:51   #7
ard
Super Moderator
ard's Avatar
No, this is not it. You may find that driving this way prevents this symptom, but you have an underlying problem.
Old 20th November 2007, 08:49   #8
andy777
andy777's Avatar
The problem I have is no one on this site can give me answer and BMW have run all tests diagnostics and compression and have found nothing wrong!
Old 20th November 2007, 12:48   #9
intrepid one
intrepid one's Avatar
Garage: '01 M5 Carbon Black
Andy, I have a solution. You have run all the diagnostics and there is no problem. It appears you may have a slight valve cover gasket leak which is annoying, but thats all. Your oil consumption is reasonable, and the car runs fine..Perhaps you should accept it and just enjoy the ride...
intrepid one is offline   Reply With Quote
Old 20th November 2007, 14:50   #10
andy777
andy777's Avatar
The problem does not get to me that much and you are right it can't be a big problem or BMW would have found something wrong with car, believe me they have serviced it enought times, I just wish I could get to the bottom of it. Besides the fact it is burning perfectly good oil and costing me money I don't really mind.
Now I have found out how to stop it smoking I suppose that is somthing and it should help with the oil consumption.
Engine oil lewisng E60 M5 and E61 M5 Touring Discussion 21 1st September 2007 19:11
Engine Oil Leak Suspected - Non-Linear Oil Usage 507bhp E60 M5 and E61 M5 Touring Discussion 12 10th December 2005 21:05
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav E60 M5 and E61 M5 Touring Discussion 31 4th July 2004 21:23
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 21:23
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
