Old 14th November 2007, 20:41   #1
S62M5
S62M5's Avatar
Garage: 2000 M5, Avus Blue Metallic
Sales Feedback: (4)
ABS, DBC and DCS lights are on
i have all three warning lights on ABS, DBC and DCS.
This all started about couple of weeks ago when i took the car for a drive. when i applied the breaks the pedal jerked back and forth and the lights went on. i removed the battery and the lights still remain on but the the break pedal does not jerk back and forth anymore. i was doing some research about this and many said it could be a faulty ABS sensor and there is a way to get them cleaned up using rubbing alcohol. just wanted to know where abs sensor box located under the hood? or any other remedy to fix the issue myself.
the car drives fine and the speedo reads correctly so i don't think its speed sensors. Full break job was done at the stealer about a month ago.
2000 M5, Avus blue
2005 GSXR 1000
http://www.youtube.com/watch?v=abo5aLzSRms
S62M5 is offline
Old 14th November 2007, 20:45   #2
S62M5
S62M5's Avatar
Sales Feedback: (4)
also "TIRECONTROL INACTIVE" comes on as well after driving for about 10-15 minutes, i dont know if its related.
2000 M5, Avus blue
2005 GSXR 1000
S62M5 is offline
Old 14th November 2007, 23:15   #3
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Tire Control is completely unrelated - it has to do with the pressure in your tires being dis-similar.
Now that I think about it, though, having a completely flat tire could cause it to rotate at a different speed and make the DSC and the ABS have a nutty - check your tire pressure.
d-
DouglasABaker is offline
Old 14th November 2007, 23:17   #4
DouglasABaker
I recognize Anti-Lock Brakes and I'm assuming DCS is Dynamic Stability Control, but I have no idea what DBC is.
I'd guess you have a bad wheel sensor - the pulsing in your brakes clearly indicates that the car believed it was losing traction. If you don't think you really did (ie. no snow, ice, sand, etc) then you must have a bad sensor or a bad control module.
d-
Old 14th November 2007, 23:21   #5
verhagke
verhagke's Avatar
Garage: 2000 BMW M5 (Titanium Silver)
most likely a wheel speed sensor
verhagke is offline
Old 14th November 2007, 23:26   #6
wentouch
Garage: 03 E39 M5 b/b
take it back to the stealer and have them correct it for free.
dbc = dynamic brake control
wentouch is offline
Old 15th November 2007, 15:21   #7
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
It has happened to me twice, first time an abs sensor went bad (cheap to fix) the second time it was the abs control unit (expensive). The unit itself is infront of the windscreen washer bottle on the left hand side as you look at the engine. It is the black plastic box which is attacted to a metal block with metal tubes coming out of it.
andy777 is offline
Old 15th November 2007, 17:57   #8
jclyman
jclyman's Avatar
It happened on my Wife's 2006 Mini two weeks ago. All the same lights were on (including the tire sensor, but it didn't come on until a short time after start up).
Left front wheel sensor solved it ...
- Daniel Boorstin
jclyman is offline
Old 15th November 2007, 18:04   #9
andy777
andy777's Avatar
There may be a way to reset the abs sensors if it is a sensor problem. I cant remember exactly how to do it but I think you start the car with the dsc button pressed and keep it pressed for 10 seconds, maybe.
andy777 is offline
Old 15th November 2007, 18:05   #10
jclyman
jclyman's Avatar
d-
Tire Control measures difference in wheel rotational speed, NOT TIRE PRESSURE.
If a sensor goes "south," it will illuminate the Tire Control after a short period of driving determines a difference in wheel speeds.
- Daniel Boorstin
jclyman is offline
Page generated in 0.13479 seconds with 10 queries
