Old 9th November 2007, 23:09   #1
nik hrstic
Garage: 2001 stock M5 Le Mans Blue
experienced users - Stoptech vs AP Racing brakes
Hi Guys, My local dealer Scottall, Watford, UK, has told me that my (stock, 2001, E39 M5) brakes are 'severely' corroded.
Time for BBK ! I will go with either a full Stoptech kit (front and rear) or AP Racing brakes - front only (as rears are not supplied).
I've done the searching already and want to pick up on the mood music from those in the know. I've had Roy at CA Automotive and Kevin Bird make persuasive cases for each - in the most helpful and constructive way
Which way would you go ? Thanks for your help as always and kind regards, Nik
nik hrstic is offline
Old 10th November 2007, 01:10   #2
gra8fuldd ed
gra8fuldd ed's Avatar
Garage: 2003 M5 Carbon Black w/Imola Red
What size wheels do you have on your M5?
Do you still have the oem rims?
Check to see if Stoptech & AP Racing BBK's will fit behind OEM Rims?
Some BBK's require 19's wheels in order for the big caliper of a BBK to fit.
IMHO ... Brembo's are the best!
gra8fuldd ed is offline
Old 10th November 2007, 18:36   #3
nik hrstic
Thanks GD,
I do still have the original 18' OEM rims and both parties are telling me that ABS and DFC aren't impacted - different from what the Board concluded a while back !
Love to buy the Brembo's, but I think they are expensive - more than U$ 12,500 + fitting for a full set in UK !
Kind regards, Nik
Old 10th November 2007, 19:54   #4
dazren
dazren's Avatar
Garage: 01 E39 M5 - Anthracite
I changed my brakes in February this year. Standard M5 alloys. APracing BBK on the front axle (345*32 slotted discs), standard new BMW discs and Pagid pads on the rear axle plus uprated brake hoses and fluid (all supplied and fitted by Thorney Motorsport).
Have driven 7k miles on them ((including a 1,700 mile very high speed trip) and been very happy with the result, accordingly I'm not sure if it's worth the extra money going for a full rear axle BBK upgrade.
dazren is offline
Old 10th November 2007, 20:58   #5
Kin Mak
Kin Mak's Avatar
Garage: BMW E46 M3
Sales Feedback: (3)
Send a message via MSN to Kin Mak
Don't bother with the rear unless you want the "look". I had the front Stoptech ST-40 and with a lot of track abuse it has never faded. I use PFC-01 pads on the track.
BMW E46 M3 SMG Carbon Black/Cinnamon
BMW E39 M5 Avus Blue - SOLD
KinMak.com - Loads of Photos - Elara Online
Kin Mak is offline
Old 10th November 2007, 21:08   #6
Machtig
Machtig's Avatar
Garage: 2001 M5 in Jet Black
Same here. JCrist was the prior owner of my Stoptech ST-40s and he abused the hell out of them on the track and now I own them and have completed two track days with them using PFC-01 pads. It stops so fast it will suck your eyeballs out of your head. VIR has two straights where you brake from 140+mph and several from 90+mph and neither he or I have ever experienced any fade from them on the track.
2001 Jet Black///M5
Supersprint Headers, Race Cats, X-pipe, and Magnum mufflers, Dinan CAI, High flow MAF housings, Stage 4 Software, Ground Control suspension, Stoptech ST-40 BBK, Umnitza Predator Thinline demon eyes, Zionsville Super Duty Radiotor/Fan system, UUC short shift kit, Dinan brake duct kit, Odyssey lightweight battery, V1 w/ Stealth One, Blinder
1998 Cosmos Black ///M3
OEM LTW wheels, M50 manifold conversion and cold air intake, Stromung cat back exhaust, waiting to be installed: Ground Control coilovers/adjustable camber plates, SPC adjustable rear lower control arms, factory RTABS w/ GC shims, UUC Ultimate FCABs, new OEM front control arms, HMS motorsport reciever hitch, Michelin P/S A/Ss, factory motor mounts, UUC transmission mounts w/ enforcers, Sparco harness bar.
1985 Jeep CJ-7
Too much to list...
RIP
1995 Avus Blue ///M3
1997 TiAg ///M3
1986 Toyota HiLux 4x4
1979 Jeep CJ-7
Machtig is offline
Old 10th November 2007, 21:19   #7
leadfoot_mf
Garage: 2000 corvette blk
did you check on movit? kits see what the price with them would be?
leadfoot_mf is offline
Old 12th November 2007, 11:07   #8
nik hrstic
Hi Guys, You've given me homework to do and quotes to get. Will update by the end of the week. Thank you and kind regards, Nik
Old 12th November 2007, 22:01   #9
jaj
jaj's Avatar
Garage: 2008 M3 Coupe Space Grey
I'm coming to this thread a bit late, but maybe I can help. First, you didn't mention what you intend to do with the car - track requirements and I-want-to-make-it-look-better requirements are slightly different. I can speak to the track issues from experience.
Having lived with the M5 now for about six years and having tuned it for the track, here's how I'd figure this out.
First - decide about the rears. The stock rears are fine for track work, and with stainless lines you'll get good pedal feel and modulation. Use factory pads day to day, and PFC-01's for the track . The factory rear takes the same pad (and rotor) as the E46 M3, so there's a good choice of makes and materials.
If you decide to go for the BBK in the rear, then you need to assess your wheel strategy - many BBK's are too big (diameter or depth) for the stock rims to clear, so get ready for some knock-on issues. For Stoptech, Dave Zeckhausen's website has the best "what fits?" information.
See http://www.zeckhausen.com/BMW/E39_in...ion_photos.htm
The main point is that if you go to a rear BBK, you won't improve the braking but you might improve the looks.
Once you've figured out the rears, then decide on the fronts. If you are doing a 4-wheel BBK, then it's easy! If not, then I've used the Stoptechs for track work for four years and they're great! Perfect balance with the factory rears and easy to change pads. I suspect they're not the only setup that works this well, but my experience is that they're good. The best part is that stock rims fit just fine over them, including 17" snow-tire rims (Styles 66 and 49).
So that's my input - happy decision making!
jaj is offline
Old 13th November 2007, 01:21   #10
Gustav
Administrator
Gustav's Avatar
Here is what I have
Look what arrived from USA (StopTech kit)
Gustav is offline
TECH: Stoptech brakes are possibly causing problems? atomic80 E39 M5 and E52 Z8 Discussion 20 13th May 2002 00:56
Movit or Brembo or Stoptech brakes ? Black M5 E39 M5 and E52 Z8 Discussion 256 15th February 2002 08:44
HadE55NowM5 - latest on your StopTech brakes? stever E39 M5 and E52 Z8 Discussion 0 28th November 2001 18:28
AP Racing front brake kit gmajor E39 M5 and E52 Z8 Discussion 4 22nd November 2001 13:06
Stoptech Brakes bobafett E39 M5 and E52 Z8 Discussion 1 7th August 2001 01:02
Page generated in 0.15288 seconds with 11 queries
