Front Bumper Cover Removal - BMW M5 Forum and M6 Forums
Old 5th November 2007, 14:04   #1
MAH
MAH's Avatar
Garage: 2001 Imola Red
Because I had heard it was so "easy" to remove the front cover, I tried it on Sunday and did not get very far. When you remove the black bumper guards there are these black plastic grommets that push through the cover to the bumper behind it. I could not get these plastic grommets out to save me. I tried all kinds of tools, including the grommet tool that is specifically built to remove these.
There has to be at least 8 of these plastic grommets holding on the bumper cover. How do you remove them?
Thanks,
Mark
MY2001 Imola Red
Lux. Black Interior
Painted Calipers,
Autowerke CAI
Powerchip Software Upgrade
Tubi Catback Exhaust
361RWHP
425HP and growing!
Red (angry eyes) Angel Eyes
MAH is offline   Reply With Quote
Old 5th November 2007, 15:14   #2
mad dem21
mad dem21's Avatar
Garage: 2000 m5 silverstone
The grommets are for the grill. All you need to do to get the bumper cover off is use trox tool. Their are two long trox bolts right above the grill. I think it a 6mm trox that you need. once the bumper cover is loose pull it forward and the bumper comes off. If you need to get the grommets out i just cut the front
(flat part) off and pull from the back with pliers. Buy new grommets at bmw there 95 cents. I hope this helps...
mad dem21 is offline   Reply With Quote
Old 5th November 2007, 15:17   #3
SeattleM5
SeattleM5's Avatar
Garage: 2003 M5 Chiaretto Red
I think you might be approaching this the wrong way. I removed my front bumper a month or so ago to install an AA CAI. I simply removed the two T50 torx bolts that are tucked away in the "roof" of the lower grill opening (just under where the front license holder goes). The bumper then slid forward. Don't forget to undo the bolts on the R/L lower fender liners first as they attach to the bumper. Once the bumper is slid forward a bit, disconnect the terminals going to the PDC units (if you have them) and disconnect the hose feeding the headlight washers, you'll find it on the passenger side of the bumper (US cars). For a more detailed explanation w/ photos go to the Beastpower website and select the AA CAI, you'll find instructions in pdf format. Hope this helps!
SeattleM5 is offline   Reply With Quote
The Following 2 Users Say Thank You to SeattleM5 For This Useful Post:
Blackrain (21st September 2010), Ted (1st March 2009)
Old 5th November 2007, 17:34   #4
mchin
mchin's Avatar
Garage: 97 M3
MAH,
I believe that there are screws that attach the bumper to the fender wells. I think there are either one or two screws per side. These are accessable by looking in the wheel well after either turning the wheel or removing the wheel.
These would be in addition to the screws that hold the lower pans in place. There are three lower pans; two on each side just in front of each wheel and then the middle one.
I did not even remove the bumper guards when I removed my bumper.
Hope this helps.
Michael.
Edit: here is a link I found which might help Removing Front Bumper?
mchin is offline   Reply With Quote
Old 5th November 2007, 19:03   #5
whatheheck
whatheheck's Avatar
Garage: 2009 M6 Convertible, black / tan
Sales Feedback: (4)
+ 1. Removing the front bumper is easy. Exactly as stated below.
Two T50 Torx bolts under the bumper needs to be removed. Then also remove the screws on the fender liner, then undo the 1/4 turn fasteners holding the panel underneath the fog lamps.
Bumper slides forward, disconnect the PDC connectors and windshield wash connectors.
Dan
Evolve ECU Tune, Tubi Rumore exhaust, BBS RGR rims; Polk Audio Tweeters, 5500K Osram Cool Blue HID,Valentine 1 Radar Detector; Laser Interceptor Laser Jammer; All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, 3rd brake light LED flasher, ash tray delete; LED license plate lights; RPI Ram Air Scoops + Block off plates; BMC Air Filters.......
whatheheck is offline   Reply With Quote
Old 5th November 2007, 19:10   #6
azaytsev
azaytsev's Avatar
Garage: 996 C4S 6MT
This should help you
http://www.540isport.com/DIY/M5front...ngupbumper.htm
azaytsev is offline   Reply With Quote
Old 6th November 2007, 04:58   #7
MAH
MAH's Avatar
Thanks everyone. Yes, I was trying to make this a difficult task when it should be much easier. I will try the easy way discribed by the above link.
Good info guys!
Mark
Old 6th November 2007, 05:33   #8
6spd
6spd's Avatar
Garage: 73 Pinto Babypuke Green
If you ever want to remove the bumper cover from the bumper. I suggest dike pliers that can reach behind the spike and make it easier to pull out.
It seems every weekend I have the bumper off the car fiddling with something new now days.
I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way.
Modifications
Chipped paint
Worn tyres
Dirty Carpet
Chipped windshield
6spd is offline   Reply With Quote
Old 6th November 2007, 05:37   #9
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
there are also little plastic trim tools to get those plastic "rivits" out, but that is after you've already removed the bumper from the car. The rivits hold the plastic cover to the metal bumper.
mottati is online now   Reply With Quote
Old 6th November 2007, 14:10   #10
MAH
MAH's Avatar
And I thought you had to remove the plastic from the bumper before it came off! Thanks for the clearing that up for me.
Mark
Alpina B8 Brake pads CHEAP! mill ALPINABoard.com | BMW Alpina Discussion 50 13th May 2008 11:28
Laser Pro Park (LPP) Group Buy (Laser Jammer) Road Runner M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 28 17th July 2007 02:56
How to attach front plates without drilling bumper ? d_russian E39 M5 and E52 Z8 Discussion 19 16th November 2006 17:58
Sources for M6 front bumper? BlackBear E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 1 1st September 2006 04:22
Front bumper removal mossy E39 M5 and E52 Z8 Discussion 1 5th January 2006 22:52
