I do my burnouts in the waterbox, but I don't generate lots of smoke. I let the car roll out.
Went to Atco yesterday for a rental and made literally 20 runs in under 11.9 seconds. My best was an 11.775 @ 118.69. All on PS2's. My 60' times were generally in the 1.71 to 1.74 range.
I have heard great things about the Toyo R888's. I think that they replaced the RA-1's.
Wow! Excellent 1/4 mile and 60' elapsed times! Congratulations. I think you may be on to something with your burn out/launch technique. BTW, are you running stock rear end gearing? Your 1/8 mile ET has to be incredible.
With regard to different tires, I think I'll go with a set of cheater slicks next rather than another set of Toyo's. I'm looking for a set of rims at the moment. If you know anyone who has some they'd like to sell let me know. TIA
2003 Jet Black lllM5 Dinan S3
621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2-T Intercooled Supercharger, S3 Oil Cooler, S3 Engine Management Software, OKD Plasma Direct Ignition Coils and Plasma Spark Boots, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Modified Cats & Free Flow Exhaust, BMW 545 Short Shift Kit, Stage 3 Dinan/JRZ Suspension, Dinan/Brembo Brakes, Rennline Pedal Set w/ throttle heel/toe ext,, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Subframe Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, Track: Toyo Proxes RA1 275/35R-18; Winter: 275/35ZR-18 Michelin Pilot Sport PS2; Drags: 2 Nitto NT-555R Drag Radials 285/35R-18; Blinder-M45-X-treme, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v31 Custom 'Beast' screen & Navtech 2009.1 DVD Map, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder
I'm running stock everything except for the PS2's (which are now 275 widths). I think the rear is a 2.62.
My 1/8th was a 7.580 @ 92.53 for my best run and ranged from 7.597 @ 92.32 to 7.610 @ 92.25 for my other 11.80 runs.
As for rims, Tirerack has some very cheap and very light weight Kosei wheels. They weigh like 18 - 19 lbs and cost 199. IMO, perfect for the strip. Does the S3 have strenghtened half-shafts? I am sure that you know that running true drag radials puts stress on parts of the car that normally don't see it. But if you want to run with the real big boys, you have to take those risks. I'm content to break traction.
05 E55 - Brilliant Silver/Charcoal; Best e.t. 11.775 @ 118.69 mph, 1.710 60' - BONE STOCK on PS2's http://www.dragtimes.com/2005-Merced...ecs-11697.html;
07 GL450 - Iridium Silver/Charcoal
07 Jeep Grand Cherokee Laredo - Silver/Gray
Hell if I could run a 1.760 60' time the way you can on your PS2s, I wouldn't need cheater slicks! The best we've seen is just under 2.0 which is when she ran a 12.3 at nearly 117 mph. It will be a whole new ballgame for us once we get the supercharger to put out 7.5 psig instead of 3 to 4 psig.
I am new to the board, I have a 2006 M5 that is all stock except for the charcol filters removed. I am currently using the BFG G-force 295/35R19 and my car has turned a best of 12:64 @ 114 with a best 60 ft time of 1.923 I have 26 psi in the tires and I do a burn out from the water box to the starting line.
26 psi? kool! Whats the psi on the stock tire?
__________________ Nik 00 Avus Blue ///M5 98 ///M3
The Mickey Thompson ET Street Radial tires (probably in a 275/40(ish)-17 for the back of the 5 would be a good choice.
Just keep in mind that with more traction you WILL find the next weakest link-whether its the driveshaft, the clutch, the axle/half-shafts or possibly the guibo.
And hopefully not the airbags.
Good luck!
Do you have G-Force KD's or KDW's ?
__________________ 2009 Toyota Tundra TRD Black/Gray
2008 Toyota Highlander Black/Gray
Still searching for a reliable race car...
"The car is the closest thing we will ever create to something that is alive"
