Old 4th November 2007, 00:09   #1
sonicEVO1
sonicEVO1's Avatar
Garage: E39 M5 oxford green with black nappa leather
Temp sensor question
Hi guys i have a question which temp sensor does the ECU use on my E39 1999 M5,i did a fault code check today and the scanner flagged up a faulty Temperature sensor so i was presuming its the one in the middle of the water pump not the one on the water hose near the radiator (i'm presuming this ones for the cooling fan side of things?)Any help would be greatly appreciated.
sonicEVO1 is offline
Old 4th November 2007, 01:01   #2
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
What was the actual code? There is a water temp sensor, an oil temp sensor, and an outside air temp sensor...
d-
DouglasABaker is offline
Old 4th November 2007, 01:13   #3
sonicEVO1
sonicEVO1's Avatar
d-
It flagged the water temp sensor to the ECU up but there's 2 and i'm presuming its the one on the water pump.
Higher than normal oil temp tranck E39 M5 and E52 Z8 Discussion 5 6th August 2007 19:15
Oil Temp too low? BBM5 E39 M5 and E52 Z8 Discussion 3 29th December 2006 01:21
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
? coolant temp gauge mottati E39 M5 and E52 Z8 Discussion 4 18th December 2003 04:32
Page generated in 0.09158 seconds with 11 queries
