Old 3rd November 2007, 22:55   #1
Cantresjr
Cantresjr's Avatar
Garage: M5 LMB
Battery Problems/wierd codes
ok thursday my batery died after having the flashers on for about 15-20 minutes. enough to not b able to start the car,but not all the way as to reset the clock and radio friday it died again a it was being washed, had to push start. this morning it started fine but after i went to work for about four hours the car had to be push started again.
i pulled this codes:
06 - Timeout SMG-CAN
6A - Brake light switch
A2 - “Crankshaft/Camshaft position correlation, Cyl #5-8”
this codes i pulled fter the car acted all weird, the fuel gage went to empty but i had a full tank. the outside temp said -40. after a while both readings slowly came back to normal.
is my battery on it's last legs or is my brake light swith sticking and draining the battery.
TIA
Cantresjr is offline
Old 3rd November 2007, 23:03   #2
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (3)
What year is your car? 2000 models had a recall related to the brake light switch
http://www.internetautoguide.com/aut.../m5/index.html
Diny is online now
Old 3rd November 2007, 23:33   #3
Cantresjr
Cantresjr's Avatar
Garage: M5 LMB
it's a 2001. thanks
Old 4th November 2007, 16:26   #4
Cantresjr
Cantresjr's Avatar
Garage: M5 LMB
bump
Old 4th November 2007, 16:50   #5
Osodog
Osodog's Avatar
Garage: M5
Via the onboard computer you can check your voltage. When my battery started to have problems, the car acted weird as well. Not like your is, but definitely weird.
Osodog is offline
Old 4th November 2007, 18:52   #6
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
The battery is 6 years old, so it's time for a new battery. Replace battery and see if codes and problems still persist. The CPS code is the CPS sensor gone bad. Rather easy fix, common problem. Sensors are consumables that will need replacing sooner or later.
Dinan Cans
Dinan Software
Beamer_usa is offline
Old 8th November 2007, 18:24   #7
Cantresjr
Cantresjr's Avatar
Garage: M5 LMB
witch cps sensor?
intake or exhaust?
New Battery for the beast. From Voltphreaks.com whatheheck E39 M5 and E52 Z8 Discussion 108 14th September 2007 05:19
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
Interstate MTP-93 Replacement Battery - check your installation greg E39 M5 and E52 Z8 Discussion 2 9th September 2006 01:10
Hold Codes While Changing Battery tervuren E39 M5 and E52 Z8 Discussion 6 8th February 2006 14:59
Page generated in 0.13433 seconds with 11 queries
