Engine coolant temperature, Plausibility - BMW M5 Forum and M6 Forums
post #1 of 106 Old 1st November 2007, 08:19 PM Thread Starter
KevN23
KevN23's Avatar
I have been getting this code for a while now. I reset it a few times and it always does come back on more and more often. It's the ONLY code I get and I am sure it's a 69 not b9. It would see that, after reading all the posts here, this is the coolant temperature sensor, OR the CPS. However, I haven't gotten any bad CPS codes yet so I thought I might change the temperature sensor first.
Does anyone know where on realoem can I get this? And is there an DIY on this?
Thank you all in advance.
KevN23 is offline
post #2 of 106 Old 13th November 2007, 08:54 PM Thread Starter
KevN23
KevN23's Avatar
Anyone??
How did you guys solve the problem? Could a (semi) bad CPS cause this also?
KevN23 is offline
post #3 of 106 Old 13th November 2007, 09:15 PM
wilsodh
wilsodh's Avatar
Could indeed be your temp sensor needs replacing. It may be sending info to the ECU that is 'implausible' based on other sensor input. If it keeps coming back, replace the sensor, clear the codes, and see if all's good again.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
wilsodh is offline
post #4 of 106 Old 13th November 2007, 11:47 PM Thread Starter
KevN23
KevN23's Avatar
Last week the SES light actually went away from a few days before coming back on. My temperature gauge sides on the first dot, when I am cruising on the freeway around 80mph most of the time in CA weather. Is this normal?
KevN23 is offline
post #5 of 106 Old 14th November 2007, 12:33 AM
gsfent
gsfent's Avatar
Unlock the OBC. It will check oil temp and water temp in celsius. Mine sit around 80 degrees in mild outside temps.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is online now
post #6 of 106 Old 14th November 2007, 04:42 AM
ReflexGTI
ReflexGTI's Avatar
If your coolant temp is sitting at the first dot on colder days or driving on the freeway on a cooler day while returning back to the middle in stop/go traffic, my bet would be the thermostat itself. I had the exact same issue and replacing the temp sensor didn't fix the issue. I have a new t-stat and associated parts sitting here. Anyone with a DIY for the thermostat replacement?
Steve
ReflexGTI is offline
post #7 of 106 Old 14th November 2007, 04:59 AM Thread Starter
KevN23
KevN23's Avatar
That's what my behaves like also. So looks like it's the thermostat.
Steve
KevN23 is offline
post #8 of 106 Old 14th November 2007, 05:08 AM
ReflexGTI
ReflexGTI's Avatar
post #9 of 106 Old 15th November 2007, 10:18 PM
sonicEVO1
sonicEVO1's Avatar
I've just had a new coolant temp sensor fitted to my beast and it comes up on the snap on scanner with the same thing.It was the double temp sensor i had replaced on the top of the water pump so i would'nt put too much faith in that being your problem as mines brand new and is still saying the same thing on the snap on code scanner!!
sonicEVO1 is offline
The Following User Says Thank You to sonicEVO1 For This Useful Post:
bmw_m5_albania (6th February 2011)
post #10 of 106 Old 15th November 2007, 11:23 PM
verhagke
verhagke's Avatar
I would suspect the thermostat also
I remember browsing through the TIS documents on how to change it. Looked like a real pain.
verhagke is offline
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 03:43 PM
M5/M6 V10 a success in Australia Just_me E60 M5 and E61 M5 Touring Discussion 1 15th November 2006 11:53 PM
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 09:23 PM
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 12:50 AM
E39 M5 engine temperature BigArnie E39 M5 and E52 Z8 Discussion 3 27th April 2000 09:01 PM
