Engine coolant temperature, Plausibility - Page 10 - BMW M5 Forum and M6 Forums
Old 15th January 2011, 19:44   #91
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel; 2007 Z4M Coupe
Originally Posted by CSBM5 View Post
My experience was that it will just get worse from the point you are at. The freeway speed temp will slowly drop over time and of course especially in cold weather. Only when temps get down to somewhere in the 60s when cruising will the plausibility code be set.
Don't wait -- just get the tsat changed along with other associated things (temp sensors, hoses, etc). There is nothing good done to an engine that is slow to warm up and operates below design temperatures. 75 isn't "awful" yet, but much below that and trouble is knocking on the door just waiting to be let in.
+1 Just get it changed. There are two ways the thermostat can fail (my indy gave me a detailed explanation of the two ways which I can share if anyone is interested); one way throws the 69 (obligatory heh heh) code but the actual oil temp gauge does not change too much from normal; the other way does not throw the code but the temp gauge will show sig lower temps, often at or below the first dot.
I just had mine done due to the code. I've been expecting it as I am at 70K miles, which appears to be the average life expectancy of the thermostat on our cars...
Kevin
2007 Z4M Coupe (#2) Silver Gray/Black
Too many kids' cars...
KevinM is offline   Reply With Quote
Old 15th January 2011, 20:10   #92
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
I thought it was less than that actually. I'm at 57k miles now, and tstat was done about 9 months ago (55k miles), but it was in need since perhaps 45-48k miles or so.
Current stable:
Dinan: springs, Konis, rear sway bar, monoball bushings, and exhaust;
Ground Control camber plates, Stoptech front BBK, Brake ducts opened,
Evolve AlphaN tune,
OE 9.5" rear wheels all around & 275/35-18 Pilot Super Sport
2011 M3 sedan 6MT Silverstone, no sunroof!
1996 Volvo 850R wagon
herd has been thinned, looking for some new acquisitions...non-sunroof E90 M3 = found
CSBM5 is offline   Reply With Quote
Old 15th January 2011, 21:08   #93
James (Jim) Knight
Garage: 2002 M5 Black/Black
It took me personally about three hours the first time I did it. I am somewhat mechanically inclined and that was my first T-stat change on my M5. I knew it would have to be done when I saw the temp gage low during a test drive. I didn't price the job until after I was the owner. My indy said about $350 so I decided to try it myself. Not so hard but I did notice it may have been alot easier by removing the plenum. I noticed how more accessable the housing tubes were when I renewed my tank vent valve. Also, if you had a leak at the tube mating point it would be easily detectable after refilling. Three and one half hours seems a little high if he is experienced in doing this job. If he is not experienced, I would consider finding someone who is.
James (Jim) Knight is offline   Reply With Quote
Old 15th January 2011, 21:14   #94
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Originally Posted by JCM55555 View Post
To remove and replace thermostat, test operation, and refill coolant, my INDY has quoted 3.5 hours for the job.
Does this sound right?
Less than 40 minutes for changing and bleeding the system is my quickest time(including changing the bloody sealant ring in the t-stat housing)....
So an indy should be able to do it in an hour if he has done it before and knows what to do...
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Old 16th January 2011, 10:01   #95
Richneerd
Richneerd's Avatar
Garage: 2003 ///M5 Carbon Black
Today I just got the P0128 code on the OBD-II and I just recently flushed the coolant fluid last week!
Money down the drain, now I have to go buy a new thermostat and coolant.
Richneerd is offline   Reply With Quote
Old 16th January 2011, 20:27   #96
Lunker325
Lunker325's Avatar
Garage: 02 Sterling Grey/Silverstone
Sales Feedback: (7)
Just replaced my thermostat and temp sensor on the top of the housing yesterday, not too difficult. I took the advise of many here and used some lube on the O rings, went in pretty easy. Previously the coolant temp was 73 tops on the highway and the temp needle was always parked on the left dot. Now the temp stays at 79, and the temp needle is just a hair left of dead center, very pleased.
12th Gen Bluetooth * Intravee II, Alpine KCA-420i, Alpine TUA-T550 HD Radio * Alpine SPX-17 REF 6.5" F & SPS-500 5.25" R Speakers * OEM Sirius * JL Audio XD600/6 6 Channel Amp(DSP Removed) * Audio Control DQXS * Custom ED Sub Box with 2 x SQ10's * Infinity 611a Sub Amp * Dinan Exhaust * Powerchip MAF-less tune * E60 SSK * ZHP Illuminated Shift Knob * Jet Black Rear Valance * Headlight Armor light smoke tinted tails * 18x10 SSR GT3 wheels F&R * Euro Hella Headlights * Predator Ice AE's with 5W Luxeon K2 Star and 1000 mA PowerPuck Driver * Seasonal OEM Heated Steering Wheel Retrofit * F & R Illuminated Door Sills * Ultimate Pedals * Full Interior LED's * 6000K HID Fogs * MKIV Nav * Passport 9500ci * Griots Italian Air Horn * Slimm's leather tilting armrest * Dinan Stage 1 Suspension *...
Lunker325 is online now   Reply With Quote
Old 17th January 2011, 00:29   #97
cab
cab's Avatar
Garage: 2002 LMB/Caramel (sold)
'Tis the season apparently (really we all just notice the t-sats that are just beginning to go out in the cold weather). Ordered mine last week as it is like several folks have described...floating around 74/75 on the freeway. Will EVENTUALLY get a bit warmer, but always sits well to the left of center in these Winter temps. Ordered a couple extra o-rings as other have recommended. Who knows, maybe it will even run a bit better afterwards.
cab is offline   Reply With Quote
Old 17th January 2011, 02:02   #98
JCM55555
JCM55555's Avatar
Garage: E39 M5
Sales Feedback: (3)
Would it be unwise for me to put this off for 2-3 more weeks? I already have to swap pads/rotors and a rear main seal tomorrow.
I don't have any codes currently present, but my engine temperature is pretty much always resting at the first dot, which doesn't seem normal.
___________________________
JetBlack ///M5
RK Carbon Stage 1 Supercharger
Aquamist HFS-3 Water/Meth Injection
Muffler Delete w/ Timmay Tips
SuperSprint 4-1 Headers
UUC V12 Clutch and Lightweight Flywheel
UUC Evo3 SSK + DSSR
Dinan Rear Sway Bar
Dinan Front Strut Bar
Bilstein PSS Coils
Brembo 4pot 355mm BBK
Formula 43 RAD 14 wheels (19x9.5, 19x10.5)
JCM55555 is offline   Reply With Quote
Old 17th January 2011, 02:29   #99
cab
cab's Avatar
I wouldn't sweat a couple of weeks.
The Following User Says Thank You to cab For This Useful Post:
JCM55555 (17th January 2011)
Old 17th January 2011, 11:30   #100
mz3stelios
Garage: m5 e 39 carbon swartz
temp
so here is my pic with 79c
i have 2 times chenge my t stat but the same result
and last night i run my car with bmw inpa and never droped lower from 79c
i am very hapy
when is in 12 o clock temp is 88-90
mz3stelios is offline   Reply With Quote
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 15:43
M5/M6 V10 a success in Australia Just_me E60 M5 and E61 M5 Touring Discussion 1 15th November 2006 23:53
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 21:23
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
E39 M5 engine temperature BigArnie E39 M5 and E52 Z8 Discussion 3 27th April 2000 21:01
